Driveshaft carrier bearing movement Normal or Not
Discussion in 'General Tundra Discussion' started by Jettech, Feb 19, 2018.
  1. Feb 19, 2018 at 10:57 AM
    Jettech
    Jettech [OP] New Member
    Jesse
    Nashville, TN
    08' Tundra CM
    TRD Exhaust, DC 305/55/20s, TRD PRO Shocks, HID's, JOBOX, Bully Dog Tuner, TRD sway bar, Shorty FM Int,
    2008 Crewmax with 125K. Need some thoughts on if this movement is normal or not? I cannot seem to find an specs on how much movement this should have. But the rubber boot does have a small split at the bottom.
    https://youtu.be/ghSNGGAaihs
    Rica25 likes this.
  2. Feb 19, 2018 at 10:59 AM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Picture of the split at the bottom
    Rica25 likes this.
  3. Feb 19, 2018 at 11:22 AM
    Hattori
    Hattori STOP SHIMMING COILOVERS!!!!
    Tommy
    Nashville
    2012 Tundra CM TRD
    Me.......
    You've got a few more miles left in that one until the bearing completely wears out and chews up the rubber. Then you'll hear a singing noise that resembles light brake squealing That mileage was right where mine decided to blow out. The OEM unit is around $170, I did that and busted it 6mo later. I swapped in a $70 Orielly one and haven't had any trouble since. Get your U-joints inspected too since you'll have to break it apart to service the carrier. Its typically around $300 for a driveshaft shop to rebuild it. If I were back in Nashville I could help ya!
    NewImprovedRon likes this.
  4. Feb 21, 2018 at 12:34 PM
    Jettech
    Jesse
    Nashville, TN
    08' Tundra CM
    Sweet... I'm sure it will take a shat this summer right in the middle of peak season. I will definitely go the o'rilleys route though. Thanks
    Rica25 likes this.
  5. Mar 31, 2021 at 2:43 PM
    BobTTundra
    BobTTundra New Member
    Bob
    2004 Tundra 4WD TRD Limited
    Usually when the center bearing is worn out the U-joints are worn as well, putting more stress on the center bearing and hastening its demise. My mechanic recommended always replacing U-joints when replacing center support bearing, I do so, removing the shaft myself and sending it to Oceanside Driveline http://www.oceansidedriveline.com/. They disassemble, new U-joints, new carrier bearing, service slip yoke, clean, paint, and balance. Good as new! Here is a link to my build thread with more details: https://www.tundras.com/threads/the-6-million-dollar-tundra-revival-story.84992/#post-2171272
