Drivers side window switch doesnt work properly
Discussion in '1st Gen Tundras (2000-2006)' started by sandbarjonny, Oct 8, 2017.
  1. Oct 8, 2017 at 5:47 AM
    sandbarjonny
    sandbarjonny [OP] New Member
    2004 tundra double cab limited
    My drivers side front window switch isn't working properly.The switch works on my left front window,but the other switched don't work.They work on the other door ok.Need a little help on this one Thanks
  2. Oct 8, 2017 at 6:03 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    05 S45 4x4 Double cab Jade Green Mica
    2.5" eibach coils/springs
    I'd pull up the switches to make sure everything is plugged in. If not, sounds like you've got a faulty master switch panel. Junkyard for a cheap replacement, or hit up @ramonortiz55
    NewImprovedRon and ramonortiz55 like this.
  3. Oct 8, 2017 at 6:23 AM
    @Roman parts guy or scrap yard (pick a part place) round you
    Roman likes this.
  4. Oct 8, 2017 at 7:28 AM
    whiteTRD'02
    whiteTRD'02 New Member
    I'd test the switch and/or motor with a meter before throwing any new parts at it.
  5. Oct 8, 2017 at 7:30 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    he's saying his master control switch wont run the other 3 windows in the truck.
  6. Oct 8, 2017 at 7:39 AM
    ramonortiz55
    ramonortiz55 I don't Even Own A Tundra
    Ramon
    2001 4runner, 2015 tacoma
    are you on t4r? :confused:
  7. Oct 8, 2017 at 7:54 AM
    whiteTRD'02
    We all are on t4r. Bwahahaha
  8. Oct 8, 2017 at 8:02 AM
    ladywolf
    ladywolf New Member
    Kristen
    Clarksville TN
    yes i am. Why?
  9. Oct 8, 2017 at 10:33 AM
    ramonortiz55
    Ramon
    i thought i saw you on there
  10. Oct 8, 2017 at 2:46 PM
    sandbarjonny
    All the other switches work like they are supposed too..........
  11. Oct 8, 2017 at 2:48 PM
    sandbarjonny
    No master switch will not run the other switches
  12. Oct 10, 2017 at 6:58 AM
    whiteTRD'02
    Ok. So your master switch isn't working. Have a look inside the switch. It could just need a cleanup. Wiping the copper contacts with q-tip, contact cleaner and a small file works great.
