Driver's side lean
Discussion in 'Suspension' started by neirbot, Feb 4, 2019.
  1. Feb 4, 2019 at 5:54 AM
    neirbot
    neirbot [OP] New Member
    It appears that not all Tundras have the "lean." Mine doesn't on stock setup, however does that mean it won't after I install my 6112's?
  2. Feb 4, 2019 at 5:58 AM
    Boerseun
    Boerseun Super White
    Ferdie
    Sarasota Florida
    2018 White TRD Sport CrewMax 4x4
    I don't have any significant lean either, but I have read on some posts here that the lean is more pronounced after lifting, which I don't really understand what would cause that.
  3. Feb 4, 2019 at 6:12 AM
    15whtrd
    15whtrd Mr. Blonde
    TRD Pro suspension, +2 Coachbuilder shackles, 2015 TRD Pro headlights, 20% ceramic tinted windows, charcoal filter delete, aFe drop in pro s dry air filter, TRD airflow accelerator, TRD oil fill cap, TRD 18 psi radiator cap, BDX Bullydog tuner, Weathertech floor mats front and rear, rear seat fold down mod, Tyger soft tonneau cover, Linex with uv protection, TRD swaybar, TRD center caps, TRD Pro grille insert, aluminum oil filter canister, Real truck tailgate seal, Pop-n-lock tailgate lock actuator, rear diff breather relocate, RCI front skid plate.
    I never had significantl lean either. But I would assume a full tank of gas and the battery being on that side of the truck could cause it. I’ve heard of it on other vehicles as well. You would think they would remedy that and take it into account when they build the vehicle. I’m pretty sure the pro shocks take that into account as I still don’t have lean after installing. And I’ve heard on this forum that they compensate. Weird
  4. Feb 4, 2019 at 7:03 AM
    UTTundra
    UTTundra New Member
    Lou
    Utah
    @M C M has said that Toyota does use different spring rates. That's why the lean is less noticeable until you start changing things up.
    TheBeast and 15whtrd like this.
  5. Feb 4, 2019 at 7:13 AM
    neirbot
    Duh... yes of course, that's got to be it.
  6. Feb 4, 2019 at 7:28 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    2019 TRD Pro
    No mods yet
    Do to everything being on the drivers side (battery, steering and etc). Doesn’t Toyota have a shim in there to account for it? That’s what I was told. On Coilovers install do they not put it back in?
  7. Feb 4, 2019 at 7:32 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I am not aware of a factory shim. I agree with the fuel tank, especially the 38 gal, and the driver, battery etc. it is reasonable to expect lean on that side - I am just curious why some have it and some don't, and then when they lift it it gets worse. It almost makes sense then that Toyota OEM setup has some compensation for that.
    15whtrd likes this.
  8. Feb 4, 2019 at 7:40 AM
    15whtrd
    15whtrd Mr. Blonde
    What would be better? Compensate with a shim, compensate with heavier spring rate, or if you have adjustable coil overs to tighten down the driver side to make up for it? If you add a shim I would think you would need to add a bump stop extension just on that side so you don’t collapse the shock.
    But I feel that when you start messing with spring rates and extending everything that your truck will perform awkwardly when hitting bumps or high speed off roading. Left front is going to be more firm causing the truck to bounce awkwardly.
    Kerch71 and Tierhog like this.
  9. Feb 4, 2019 at 7:45 AM
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    I'm .5" lower on the driver's side. Gas tank is full right now.
    Jrocker likes this.
  10. Feb 4, 2019 at 7:54 AM
    neirbot
    Now that I think of it -- several years ago when I installed factory FJ springs on my 4Runner, there was definitely a left and a right (and marked as such). I believe it was for the same reason. The springs don't necessarily need to be different rates, but they were definitely different lengths. Of course we're talking about different vehicles here, but the concept is the same.
    TheBeast, Boerseun and 15whtrd like this.
  11. Feb 4, 2019 at 8:00 AM
    Tierhog
    Tierhog SIG-AHOLIC
    California
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories
    Use me as a foundation to your theory. I have a 38g tank, outside of a tonneau cover and bedrug I'm completely stock.
    The truck doesn't sag or dip, or perform offroad in any uneven matter. I even have stock tires and rims.
    I'd theorize that would ever changes you made demand some scrutiny. I'm not saying any mods you did are bad... Just trying to localize the issue so your not running in circles . :popcorn:
  12. Feb 19, 2019 at 5:14 PM
    Jbtaco2002
    Jbtaco2002 Almost a Tundra
    San Diego
    2008 TRD S/C Sequoia
    i came across this thread as i noticed the front of my sequoia sits slightly low on the driver's side front.
    i did some measurements, and driver front is 38.25" from ground to fender at the center of the wheel. the passenger front is at 39"!
    rear is nearly identical with 38.5" on driver and 38.75" on passenger (assuming that's the 1/2 tank of fuel)
    i checked both of my kings and they have exactly that same # of threads showing, so what the heck is causing the passenger front to sit that much higher?
    ideas?
    only things that's changed recently is the Icon UCA's, and alignment, but we didn't touch the lift, so can a bad alignment manifest this way?
    thanks for any advice!
    JB
    dcsleeper408 likes this.
  13. Feb 19, 2019 at 5:23 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    2019 TRD Pro
    No mods yet
    Seems like when you change coil overs the truck leans heavy on the drivers side from the extra weight compared to stock. I wonder how Toyota keeps it straight? Both stock springs are the same right?
  14. Feb 19, 2019 at 5:31 PM
    15whtrd
    15whtrd Mr. Blonde
    I want to say there is a right and a left. Maybe I’m wrong. My pro shocks have the truck sitting level in the front from side to side. Those have a right and a left spring. But if I remember there are 2 letters on both springs with an L and an R. It almost looks as if you clock the spring to get the proper preload. I’m just grasping now.
  15. Feb 19, 2019 at 5:33 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    2019 TRD Pro
    No mods yet
    I worked in manufacturing for years. Usually if something is marked “R” and “L” something is different.
  16. Feb 19, 2019 at 5:35 PM
    15whtrd
    15whtrd Mr. Blonde
    Haha ok enlighten me
  17. Feb 19, 2019 at 5:38 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    2019 TRD Pro
    No mods yet
    Easy. For the mere fact it cost money to mark it. Granted not much but times 250,000. Companies hate spending extra money for no reason. Like we told the new guys. If it’s marked different, then it’s different.
    15whtrd likes this.
  18. Feb 19, 2019 at 5:57 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    It’s best to measure center hub to fender.
    Toyota’s are prone to lean. Tacoma 4runner tundra sequoia I have done lifts on and about 90% got the lean. Mainly the the lifts that went up pretty high.
    Negative camber can give it that illusion that it looks lower on one side. It will probably give you a bad measurement too.
    Your lean isn’t too bad from the measurements you provided . I’ve seen worse.
  19. Feb 19, 2019 at 6:09 PM
    TheBeast The Beach
    add more preload on the side that is leaning. on my Tundra with Kings I have 14 threads driver side and 9 threads passenger side for example. I had almost 1" lean on the driver side. with stock suspension I had no lean.
    Jbtaco2002 likes this.
  20. Feb 19, 2019 at 6:10 PM
    Jbtaco2002
    San Diego
    this is my plan, then back for another alignment!
    TheBeast likes this.
  21. Feb 19, 2019 at 6:13 PM
    TheBeast The Beach
    how many threads you have showing right now ? with 3/4" i would probably add enough to show 4 more threads driver side. suspension also settle after you play with it so even if it shows the driver a bit higher after you adjust it will come down a little bit. that was my experience after adjusting them twice because I'm OCD :)
  22. Feb 19, 2019 at 6:13 PM
    Vizsla
    Vizsla AZ LT Bastrd
    Dave
    Arizona
    2018 Cement Crewmax
    Your left/driver coilover has the circlip set one groove higher for lean compensation when new. Same spring on both sides.
    joonbug, NewImprovedRon, LT75 and 2 others like this.
  23. Feb 19, 2019 at 6:15 PM
    15whtrd
    15whtrd Mr. Blonde
    Thank you for the clarification.
  24. Feb 19, 2019 at 6:16 PM
    Alexstundra
    Alexstundra Not a new member
    Northeast PA
    2016 MGM DC Trd
    I’ve thought about this a lot. Maybe it helps while driving since roads are slanted down usually to the right? I think about it on this one road by my that’s a one way and it dips way to the left in the left lane. And I feel like I’m flexing a lot on the right I look out my passenger window at the sky almost. Just food for thought?
  25. Feb 20, 2019 at 3:21 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    2019 TRD Pro
    No mods yet
    Then they are marked to know which is one groove higher. See you were right.
    15whtrd likes this.
  26. Jun 13, 2019 at 5:14 PM
    Wilbur
    Wilbur New Member
    Tennessee
    2014 Magnetic Grey Tundra SR5
    Has anyone had any excessive tire wear with a proper alignment and still leaning?
    kgryder likes this.
  27. Jun 13, 2019 at 5:16 PM
    Professional Hand Model
    Professional Hand Model Fred Brookes
    Hand Protectors
    Not that left. Your other left.
    hagrid and 15whtrd like this.
  28. Aug 9, 2019 at 6:50 PM
    DM 2018 Tundra
    DM 2018 Tundra New Member
    South Carolina
    2018 Limted Tundra
    6inch RC with upgrade struts. 295/65/20 Nitto Ridge grappers 20x9 fuel vapor with 0 off set
    My back passenger side is half in to a inch lower than my driver side. Anything to be worried about? 6 in RC lift on my ride
  29. Aug 9, 2019 at 8:02 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    So after reading this above info on driver side lean is ok to use stock springs with new shocks and not worry about the problem since my truck is the same measurement on both sides? And if I go with a aftermarket spring then it's necessary to get a shim to balance things out?
  30. Sep 25, 2019 at 4:23 AM
    kgryder
    kgryder New Member
    I have this issue. Ready to take it in to find out what can be done to fix lean and tire wear (after putting 4 new tires on yesterday).
