Drivers side grab handle / A pillar question
Discussion in '2.5 Gen Tundras (2014-2021)' started by Bigjoe, Jul 1, 2020.
  1. Jul 1, 2020 at 3:29 PM
    Bigjoe
    Bigjoe [OP] New Member
    ..On my 2019, drivers side A pillar, the tab that reads "SR5 Curtain Airbag", I can pop it off to access a bolt. Now, on the grab handle kit I ordered from "Sparks Parts", the "SR5 Curtain Airbag" does not open up. Is this a problem? Is the airbag deployed thru this oval tab?
    BrunoTheRescuePup likes this.
  2. Jul 2, 2020 at 1:20 PM
    Anthony605
    Anthony605 New Member
    Anthony
    2020 Limited Double Cab
    The air bag does not deploy through the tab. It is a "curtain" that deploys out of the lower seam of the trim piece. The tab just covers the bolt on the original trim piece. The trim piece with the handle does not have the tab because the handle actually has the bolt cover tabs. I just installed the kit in my 2020 Limited.
    Tundrastruck91 likes this.
  3. Jul 2, 2020 at 1:53 PM
    Bigjoe
    Yea.....That's kinda what I thought, but wasn't sure. Thanks for the reply!
  4. Jul 2, 2020 at 1:56 PM
    Anthony605
    Anthony
    No prob! It is an easy install. Just make sure you cut the notch out if you have the speaker wire on your truck!
    Bigjoe[OP] likes this.
  5. Jul 2, 2020 at 2:15 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    And kill the battery so you don't fire off the air bag by accident.
    NewImprovedRon likes this.
  6. Oct 4, 2021 at 6:06 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    Just installed my grab handle 21 limited tundra. The trim running along the windshield looks deformed. Just curious if this normal?PXL_20211004_155705993.jpg PXL_20211004_155720711.jpg PXL_20211004_155705993.jpg
  7. Oct 4, 2021 at 6:12 PM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    no
    Alexjdm[QUOTED] likes this.
  8. Oct 4, 2021 at 6:14 PM
    Do58
    Do58 New Member
    Umm nope
  9. Oct 4, 2021 at 6:25 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    Ok great because I emailed Sparks with pics showing them the defect. I was pretty sure that wasn't supposed to be like that lol. Thanks
    Do58 likes this.
  10. Oct 4, 2021 at 6:28 PM
    donbun68
    donbun68 New Member
    Kentucky
    2017 Black Tundra
    TRD exhaust, cold air intake, interior mods.
    If I’m not mistaken, you have to cut a notch to clear airbag harness at base where it meets dash. That could be issue with deforming.
    Alexjdm and biebs96 like this.
  11. Oct 4, 2021 at 6:29 PM
    biebs96
    PA
    loose the bolts. Adjust it to your liking and re-snug would be my first suggestion.
    ..but, looking at where it is deformed, maybe you need to reassess the area you cut out. If it wasn’t cut deep enough, it could be hitting the wiring harness and not fully seating.
  12. Oct 4, 2021 at 6:40 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    I cut the notch for the speaker wire far I could almost touching the long trim piece. I tried resetting the trim along the piller a few times thinking it was me forcing it, but no same thing. I even took the entire piller trim off and it clearly without a doubt had the defect in it. So it's not like I'm forcing it into a weird shape. At the point I gave up and just installed it until I can figure out a solution atleast use the grab until then.
  13. Oct 4, 2021 at 6:43 PM
    biebs96
    PA
    Did you install the speed nut in the correct location? Maybe it is too high up inside the pillar?
    maybe the bolt it too long?
    Just some troubleshooting ideas.
  14. Oct 4, 2021 at 7:44 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    Yeah atleast I believe I did it right. The flat part of the speed nut facing the plastic. I did take the whole assembly out and it still had the bulge in it. It didn't go flat again. It seems like it was a deformity during manufacturing or it got packaged while it was still warm from stamping or casting. I have ocd and it's gonna bother me especially after paying a good chunk for this lol
    biebs96 likes this.
  15. Oct 6, 2021 at 10:07 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    Tonight I removed the piller trim. Completely out of truck. Is this normal? PXL_20211007_044938110.jpg PXL_20211007_044938110.jpg PXL_20211007_045125003.jpg PXL_20211007_044938110.jpg PXL_20211007_044938110.jpg PXL_20211007_045125003.jpg
  16. Oct 6, 2021 at 10:18 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Looks like it was impinged and retained some memory...
  17. Oct 6, 2021 at 10:25 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    I received it just like it is, thought it was designed that way from Toyota.After installing I noticed not aligned like it should along the windshield and just didn't look right. reason I made the Post asking you guys. In reality not a big deal, functions find, as it should but the whole setup wasn't cheap either.
  18. Oct 6, 2021 at 10:56 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Heat it up with a hair dryer and try to bend it in a little..
    Although the summer sun may flex it back out..
    As trivial as it may seem, that would bug me too...:thumbsup:
    Alexjdm likes this.
  19. Oct 10, 2021 at 1:06 PM
    batman900
    batman900 Yep
    24-RAM 2500, 05-Tundra, 11-Accord
    Just now had mine come in from Sparks. Most beat up box I've ever seen plus it was open..... People need to stop using Fedex. Mine looks a little warped in various areas as well but I think everything is in the box. I'll have to see how it goes tomorrow and maybe use the heat gun to straighten it out. Sigh
    Big Papi likes this.
  20. Oct 10, 2021 at 1:51 PM
    GCanuck
    GCanuck Member since 2020
    Gary
    BC,Canada
    2020 Tundra DC MGM TRD Sport
    TRD Swaybars. Line-X bed liner. Toyota Tri-fold Tonneau. N-fab side bars. TRD cold air. AMP bed extender. Rough Country Level kit. BFG A/T K02. RCI Skids. OEM Tow mirrors. TRD exhaust
    I find the drivers side pillar is a bit of a blind spot. Does the grab handle add to that?
  21. Oct 10, 2021 at 2:24 PM
    LTundra
    LTundra New Member
    Did Sparks say that you can return it?
  22. Oct 10, 2021 at 3:27 PM
    Bradleybb
    Bradleybb New Member
    Georgia
    2021 CM TRD OR
    Transmission cooler TRD REAR SWAY RCI front skid
    Just opened up one I received yesterday, yours definitely defect ,
    Parts warranty
  23. Oct 10, 2021 at 4:08 PM
    batman900
    batman900 Yep
    Update: Just installed mine and I was able to get out about half of the bend using my heat gun. Opposite of OP, mine was bowed inwards but in the same area.
    @GCanuck no it doesn't add to the blind spot. The only way I could see that happening is if you are extremely tall and have the driver's seat all the way back. Then it might take about 1/4 inch of your forward view. I'm 6ft for reference.
  24. Oct 10, 2021 at 4:15 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    Spoke with Sparks they wanted me to send it back they would pay for shipping. They would inspect it and if it was defect they would replace it if not I would have to pay for shipping back to me. Even after all the pics they still wanted it back for inspection. Now the weirdest thing happened now. Late last week we had a very sunny warm day here in upstate NY. The truck sat all day in my driveway, which it gets direct sunlight pretty all day till about 6pm. In which I believe temps in the cab must of gotten the piller very warm , darn thing straighten it self out. Still has a small very unnoticeable bulge nothing has before and it aligns straight with the window. So instead of going through all the BS shipping etc. I kept it and told sparks we're all set. It looks awesome now and doesn't bother at all now.
    After
    Before
    NewImprovedRon and batman900 like this.
  25. Oct 10, 2021 at 4:18 PM
    batman900
    batman900 Yep
    Nice! I was hoping the same will happen with mine. No biggie either way since I fixed most of it already. Glad it worked out for you, the handle helps so much.
  26. Oct 10, 2021 at 4:24 PM
    Alexjdm
    Alexjdm New Member
    2021 tundra limited
    I absolutely love the handle use all the time. I don't know why would Yoda leave it out. Also when I reinstalled it, after taking pics for Sparks I tightened the bolts just enough, which it may of helped smooth it self out with all the heat build up in the cab. Extremely happy with it now! And Sparks treated me fairly, enough that I bought painted match mirror caps, hate Chrome!
  27. Nov 2, 2021 at 10:47 PM
    rugerm44
    rugerm44 New Member
    2021 Tundra
    Where did you get grab handle.Not familiar with Sparks.Sparks Toyota?Feel naked without a grab handle another Toyota goof
  28. Nov 3, 2021 at 3:33 AM
    RobertD
    Robert
    DFW, Texas
    Taco-Spike likes this.
  29. Nov 3, 2021 at 5:38 AM
    Taco-Spike
    Two Trucks
    And you can also use a code for 5% off. I think most of them are YouTube content streamers.
    I’m drawing a blank at the moment for some. I’ll edit once I think of one or find one… or someone will drop one
  30. Nov 4, 2021 at 1:03 AM
    donbun68
    donbun68 New Member
    Kentucky
    2017 Black Tundra
