Driver door when it gets hot outside it won't open???
Discussion in '1st Gen Tundras (2000-2006)' started by Tundra02, May 9, 2019.
  1. May 9, 2019 at 10:04 PM
    Tundra02
    Tundra02 [OP] New Member
    2002 SR5 3K4 Red Crew Cab
    Driver door when it is hot outside won't open until it cools down but still opens hard in AZ.
  2. May 9, 2019 at 11:57 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    I have this problem with lots of cars in Hawaii when they sit in the sun. The rubbers and plastics and various coatings get tacky from heat. Thus your door gets “stuck” to some extent.
  3. May 10, 2019 at 4:08 AM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    I second the idea of using a fine powder.:headbang: I am a devoted fisherman and in the course of my activity I have often sprung a leak in my chest waders that I have to patch. A quality product, Aqua Seal, patches very well but remains very "grippy" and grabs at my legs when I try and put on after the patching - a real pain. To remedy it, I take a material patch that looks like sheep skin and I apply a small coating of baking powder to it and use it to pat down the Aqua Seal patch and thereby remove the grip. I have never had to repeat the process, though were you to do it, I would think it may need a touch-up now and then, but it should work.
    Taking it to another level, I would look for a graphite powder as probably being more weather resistant. Which brings to mind the "anti-seize" thread coating I recently applied to my spark plugs. It seemed to be a graphite + paste compound, and quite possibly more durable and weather resistant than any powder, though a bit more expensive. I would give it a try.:tinfoilhat:
