Drive In Theatre B-day
Discussion in '1st Gen Tundras (2000-2006)' started by lionscourt, Jun 23, 2019.
  1. Jun 23, 2019 at 8:30 PM
    lionscourt
    lionscourt [OP] 2006 DC SR5 4X4
    Ray
    CA
    2006 SR5 Tundra 4x4
    NO RUST, step bars, weathertech window and hood protectors, weathertech floor mats
    So the night before my daughter's bday or the morning of, as we stayed late, we had a party for her at the drive-in, it's still pretty awesome here in Cali. Got there early, great music on semi-large Bluetooth speaker-which you need for the drive-in, and perfect geographical position to let the kids sit on the blow up beds and blankets in the bed while the adults drink and talk in nearby cars/trucks. Set to watch the new MIB and Godzilla (my choice)... but... as I'm going to pull down tailgate so blow up bed can extend out, my martial art grip pulls the whole plastic handle piece away from tailgate...!
    It didn't blow the night but didn't have the tools there to at least drop it down as the tailgate was stuck in the up position.
    Now home, i've removed the tailgate handle but need the replacement part that works but doesn't cost OEM. I have tried the search engine but nothing notable.
    Daughter and her friends still had great time but that tailgate, what are the chances...? Oh and putting basic Toyota tool kit in truck...
    Darkness and Sunnier like this.
  2. Jun 23, 2019 at 8:44 PM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
  3. Jun 24, 2019 at 12:59 AM
    AV8R4AA
    AV8R4AA New Member
    Greg
    Justin Texas
    2005 Tundra XSP
    Me also, fits perfect!
    PS And more importantly, way to be a Dad!
    lionscourt[OP] likes this.
  4. Jun 24, 2019 at 3:24 AM
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I'm a firm believer that fate gives us little hints here and there just before dropping a bomb on our heads. I'd take a little reminder to get a tool kit in my truck as a red flag yelling "get a tool kit in the truck".
  5. Jun 24, 2019 at 4:23 AM
    Professional Hand Model
    Hand Protectors
    Think I replaced mine with a Doorman about 7 years ago. I greased everything (all contact points) really well including the new handle and the attachment points/rods where they lock onto the bed posts.
    Dry latch/pivot points caused the failure, which puts strain on the plastic handle, I believe if memory serves proper.
  6. Jun 24, 2019 at 6:02 AM
    Outbound
    Aaron
    Northern Alberta
    Same here, used a Dorman from Amazon to replace mine as well.
  7. Jun 24, 2019 at 6:42 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Somewhat off topic question. Does anyone know if the cables can be adjusted? One of my cables has slack so the other one is holding 100% of the weight. I'm not sure if I need to buy new cables or if there is an adjustment to be made.
  8. Jun 24, 2019 at 6:45 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Drive in on Van Buren?
    Marty McFly likes this.
  9. Jun 24, 2019 at 6:50 AM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    They're actually solid steel rods that run to each side. If one has slack then it may have come out of the little plastic clip. Wouldn't really explain how you can still open the tailgate though.
    Just grab you a T30 and take the access panel off the inside of the tailgate. There isnt a whole lot to these systems.
  10. Jun 24, 2019 at 6:52 AM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm sorry, I'm talking about the tailgate cables that hold it when you lower it.
  11. Jun 24, 2019 at 6:56 AM
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    Just re-read your post, I'm an idiot.
  12. Jun 24, 2019 at 7:01 AM
    Hand Protectors
    I read it that way as well.
    Not sure those cables slack can be adjusted.
  13. Jun 24, 2019 at 7:23 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Make sure you have both the correct cables, the DC ones are a little longer so it's possible one was replaced with the wrong length.
  14. Jun 24, 2019 at 7:25 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    If your tailgate is bent for whatever odd reason causing the slack on one side, try swapping the 2 cables - maybe that evens things out (or makes it worse, which would confirm that something is out of whack). If it is still the same amount of slack but just on the other side, you know the issue is with the cables.
    Darkness and speedtre like this.
  15. Jun 24, 2019 at 7:44 AM
    Boerseun
    Ferdie
    Sarasota Florida
    We also like to go to the drive-in - great experience for the kids before that is also a thing of the past. Not many of them around anymore.
  16. Jun 24, 2019 at 9:06 AM
    02goes
    02goes New Member
    2002 Tundra Limited 4X4
    Martial art grip. Your joking, I hope.
    Darkness likes this.
  17. Jun 24, 2019 at 1:04 PM
    Hand Protectors
    He’d be no match to my Himalayan Yoga Death Grip training style. I proved it already by breaking my tailgate handle first 7 years ago.
  18. Sep 9, 2019 at 4:02 PM
    lionscourt
    Ray
    CA
    2006 SR5 Tundra 4x4
    Brown Bear[QUOTED] likes this.
