Drive away ..no FOB
Discussion in '3rd Gen Tundras (2022+)' started by Frank_TRD23, Jul 25, 2025.
  1. Jul 28, 2025 at 9:42 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I doubt it, since the engine shuts off when you open the door after a remote start.
    It appears the device in your video can only be used to hack the unlock and lock data, but not the data to start the engine.
    That said, I'm sure some sophisticated thieves have figured out how to hack the starting data too.
  2. Jul 28, 2025 at 10:04 AM
    Technology is a two edged sword isn't it? Awesome to have, but can be used against you.
    kirkb and Matt2015Tundra[QUOTED] like this.
  3. Jul 28, 2025 at 10:59 AM
    PNW Tundra Mike
    Back in So Cal
    MX4 Tonneau, Talon's Trans/Cat Shield, Vantrue Cam
    They have. Look at any of the theft vids on YT from Canada. Once inside and laptop plugged into OBDII port it’s about 5 to 10 mins to initialize a new key. ** Million Dollar idea - an OBDII Port Locking cover! One of you guys with a 3D printer can get on that!!
  4. Jul 28, 2025 at 12:08 PM
    Matt2015Tundra
    2023 1794 CrewMax
    So, we've progressed from punching a hole in the steering column and hot wiring the ignition to plugging in a computer and initializing a new key? Great progress...
    The locking OBDII cover is a good idea. Or, how about software that renders the OBDII port inoperative unless it detects an initialized FOB?
  5. Jul 29, 2025 at 8:59 AM
    jtweezy
    jtweezy New Member
    Jeffrey
    Not that they'll see it, but I'll throw in my idea on how to make this work without jeopardizing all the safe guards and "terrible" outcomes Toyota has designed for...
    If the fob can be energized by the start button (or something in/around the start button) to enable starting the truck with a dead fob battery, it could do the same to enable shifting out of Park when the fob is not detected.
    So if you forget something and hop out of the truck, when you get back in without the fob (fob not detected) it won't let you shift out of Park. In the case where you have the fob, but the battery is dead, you put the fob next to the shifter and pull it out of Park.
    Uses existing tech and a little more programming.
    There's a new edge case though...
    1. Get in
    2. Shift to Reverse
    3. Realize you forgot something
    4. Throw on the parking brake while in Reverse
    5. Get out of the truck
    Could maybe solve that the same way. Put the fob next to the shifter to release the parking brake AND/OR shift out of Park.
    Tundrastruck91 likes this.
