Drill bits for slider install
Discussion in 'General Tundra Discussion' started by fisherman951, Apr 11, 2019.
  1. Apr 11, 2019 at 5:55 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The ADD sliders have only two attachments and they are body mounts and not frame mounts. Will bend as soon as i think about touching a rock.
  2. Apr 11, 2019 at 6:04 PM
    Only two? Dang..
  3. Apr 11, 2019 at 6:12 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    How are you gonna finish this beast Tony? :popcorn: Bolt on with welds sure sounds good. With either attachments would the sliders make a good point for a hi-lift jack to fix a flat?
  4. Apr 11, 2019 at 6:16 PM
    fisherman951
    fisherman951 [OP] MT dreams
    Tony
    2017 crewmax 4x4
    Finish them I’m thinking rattle can them would be good. But I found a guy that would powder coat them for 200 bucks so I’m on the fence primer and paint adds up also I need to remove the surface rust. If I knew some1 that would weld them for cheap I wouldn’t mind. I’ll be bolting them up as steps first and then drill the holes slowly if I don’t get them welded. I heard u can lift up the whole truck from the slider but I’m not 100 % sure
    Black Wolf and Pinay[QUOTED] like this.
  5. Apr 11, 2019 at 6:17 PM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Crappy photo, dude. Who the heck took that? Oh, wait... ;)
  6. Apr 11, 2019 at 6:21 PM
    $200 isn't bad for the powder coat. Once you get them mounted you can definitely do some serious side lifting.
    dcsleeper408 likes this.
  7. Apr 11, 2019 at 6:22 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    Some cool guy lol
  8. Apr 11, 2019 at 6:28 PM
    sdde4n
    sdde4n New Member
    This is what I used (bought two #4s and tossed one when I was done). Eye protection is a must. Those burrs are hot too!
    Black Wolf likes this.
  9. Apr 11, 2019 at 6:37 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would think a good welder could get those on in 1-2 hours. And you won’t have any bolt heads exposed underneath. I would weld them on for that reason alone.
    I paid $160 to get my sliders pc’d, was totally worth not having to paint them myself. Those suckers are huge and heavy AF. And mine didn’t have any rust. Removing the rust will probably suck too.
    Black Wolf and dcsleeper408 like this.
  10. Apr 11, 2019 at 6:41 PM
    fisherman951
    Tony
    2017 crewmax 4x4
    160?? Dayum that’s cheap. It’s only surface rust but the guy said he would blast them and then powder coat them for 200. So I guess not to bad. I just don’t know any welders besides the. Shops and those guys rates aren’t cheap. I’ll have to ask around if not when u coming to big bear? U have the experience I’ll provide the beer and food and you drill? Lol
    Black Wolf and Pinay like this.
  11. Apr 11, 2019 at 6:59 PM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    2x! I can do the same! My Demellos wont be in till end of May/ early June. Summer Mod party!
  12. Apr 11, 2019 at 8:17 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    This, if you don't want to weld it, then step drill it with straight bits.
    I've never found a unibit that didn't leave an unsatisfactory hole. Start with a 1/8 hole and then step up in 1/8 increments to get the hole size you need. Use lubricant, machine tool lubricant is expensive and meant to preserve bit life in a production environment. I would use whatever is laying around, used motor oil is cheap. New motor oil is also cheap. WD40 is too thin and would need a constant stream.
    Use inexpensive bits, consider them disposable. With lubrication you should be able to get all of the holes you need with one bit for each size.
    A good transfer punch and center punch would be more important to me. Without an indent, any hand drilled hole will tend to walk. With that many holes it won't take much walking to make you start cussing.
    Good luck, pics when done.
    joonbug[QUOTED] likes this.
