Doubling up. 2 Add-a-Leafs back to back in the stack
Discussion in 'Long Travel Suspension' started by CHOSCAM, Feb 2, 2023.
  1. Feb 2, 2023 at 1:52 PM
    CHOSCAM
    CHOSCAM [OP] New Member
    CHOSCAM
    BLK O7 Tundra LTD 4X Lifted 3" 5.7 BORLA
    Black Rhino 18 on A/T GENGRABRS w/ 1.25 at R/C 3" Lift. -12 OFFSET A tad of Rub-Dub
    Fishing for opinions out there. What if one doubled up on an add-a-leaf kit. To be clear, it would be add-some-leaves. Like doubling the Zone add-a-leaf to 2 leafs. Advantages? Consequences? Feasibility?
    It maybe a ridiculous idea to some, then again, someone out there maybe running it already. Just seeking experienced opinions to help me comprehend trade-offs in leaf spring robustability. Thx fellas
  2. Feb 19, 2023 at 9:38 AM
    NCred
    NCred New Member
    NC
    2019 CM TSS 4x4
    I'll add some insight, I don't think (keyword there) it would be an issue in adding them, there are custom leaf packs with 8 leafs. The question is lengthening the center bolt that holds them together and the alignment clamp brackets need to be large enough to accommodate the 2 extra leafs. Each leaf will provide lift and stiffness. If you're not carrying a constant load it may be too stiff to you're liking. That's my 2 cents. :notsure:
  3. Feb 19, 2023 at 10:17 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Don't forget bumps or your going to flatten them quick.
