Door lock problem
Discussion in '2.5 Gen Tundras (2014-2021)' started by saramos, Oct 22, 2019.
  1. Oct 22, 2019 at 11:23 PM
    saramos
    saramos [OP] New Member
    Scott
    2014 Tundra
    Bilstien 6112s 2" rear shackles. LED headlights. Interior wood trim. 798Addict Wheels. Nitto Ridge Grapplers. Tonnaeu Cover, Fenders, Side Steps. 4 camera system
    A problem has developed with the door locks on my '14 Tundra. The first symptom was that the key fob would only work on the first operation in the morning. I would be able to unlock and lock the doors with the fob in the morning, but after starting and driving, the fob would not work. Soon, the button on the driver's side would not lock the doors, but would unlock them. Also one turn of the key in the driver door would unlock the driver door, and 2 turns would unlock all the doors.
    Now, the behavior is,
    There is no response to the fob at all.
    The door lock button on the driver side will unlock all doors, but not lock them.
    The key will only lock and unlock the driver's door.
    Placing the truck in park will unlock all doors.
    Moving the truck out of park will lock all doors.
    Any recommendations would be greatly appreciated.
  2. Oct 23, 2019 at 7:49 PM
    saramos
    Scott
    2014 Tundra
    Not yet, but I don't see why that would prevent the door lock buttons on the driver and passenger side from locking the doors or the key from unlocking all doors on a second turn.
  3. Oct 24, 2019 at 5:28 AM
    WillieMan
    WillieMan New Member
    Aaron
    2019 Silver Tundra Platinum
    We had similar issue on the wife’s 4Runner. It ended up that multiple lock actuators were bad. Dealership fixed it, luckily it was under warranty because if not I believe the total was $1700.
    OR18TRD likes this.
  4. Oct 27, 2019 at 6:46 AM
    Okielynch107
    Okielynch107 New Member
    2014 Tundra Platinum Crewmax 4x4
    I have '14 CM with the kind of problem. The left rear door is the only on that works. I ordered the motors (after gathering tons of info on the issue from here) and replaced the three that werent working. This did not fix the problem. After what should have been an hour job turned into all night (something didnt go back incorrectly on of the times and i couldnt open the driver door from inside or out), I am bout fed up with this issue. Contacting the dealership but i bought it used so i doubt they will be willing to help at all. Next move is dropping the $150 for the actuators and just replace those.
    If anybody can think of somewhere else to attack this issue, feel free to share. Im at my wits end with this truck and Ive only had it a week. (having the radio/bluetooth reset issue as well and the truck wont recognize the only thumb drive I own.
  5. Oct 27, 2019 at 6:48 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    The Toyota actuators are notorious for early failures...I literally replaced all four of mine within a five week period on my 2014 4runner. Good news is i could replace them in about 40 minutes. I may have a couple extra lying around if the tundra shares the same actuator.
  6. Oct 27, 2019 at 7:18 AM
    Opus5150
    Opus5150 Terminal Lance
    Live Free or Die
    2017 Tundra
    Theres a little white plastic bushing the door lock rod connects to. The drivers door actuator on my 2010 Tacoma had broken, (Pretty sure VERY similar to the Tundra mech), so it would still push the actuator to unlock, but not pull it to lock. Fairly simple swap, I bought a salvaged unit from eBay and watched the YouTube video on the repair. (Just make sure you get the right one - driver side has the keyhole). Not sure if this is your problem or not, but if you remove the problem actuator and one of the rods is loose, that's probably the culprit. Good luck with the repairs!
  7. Oct 27, 2019 at 8:01 AM
    Okielynch107
    I had 3 of the 4 actuators apart on the table yesterday. Seemed like they were all put back together correctly. Multiple functions test after reassembly (after the first one, driver door debacle). Pushed and pulled cables to verify correct operation and seemed to work. Mechanically, there was nothing wrong. Swapped the tiny motors and installed back in truck. Thought maybe if one was bad, it still wouldn’t work so went ahead and did all 3. No dice.
    I do believe they share all the same mechanism and I’d gladly send some beer tokens your way for compensation.
  8. Oct 27, 2019 at 11:26 AM
    shawn474
    MoCo, Maryland
    Ok let me check which ones I have; will
    Let you know. Off the top of my head I think I have rear driver and passenger
  9. Oct 27, 2019 at 2:19 PM
    Okielynch107
    More than I got now
  10. Oct 27, 2019 at 4:15 PM
    shawn474
    MoCo, Maryland
    722314D1-FEBF-411B-ADCA-DD1EC69F6AEC.jpg These are the ones I have - if you want to see if they are the same as one you need let me know.
  11. Oct 28, 2019 at 5:17 PM
    Okielynch107
    I have been doing a bit of research and honestly, I have no clue if those will work or not. There seems to be various pn for each door so my searching is inconclusive. However, I did see something about silicon build up on the contacts, so for science, I’m going to remove them, clean them up with alcohol, lubricate very lightly with aviation electrical CPC and reinstalled.
    Also heard back from the dealership and all they were willing to do is trade trucks back, which gets me nowhere.
    I was thinking also of doing a write up of the process with pics for all those in the future who could benefit from it. Not sure if it’ll be worth my time so let me know what y’all think....
  12. Oct 28, 2019 at 5:18 PM
    Okielynch107
    this is also with the new motors installed on 3 doors and original (not failed yet) on one door.
  13. Oct 28, 2019 at 5:21 PM
    Okielynch107
    I’m pretty electrically savy as well, so if anyone has a wiring diagram, I could also test the relay and such.
  14. Oct 29, 2019 at 4:47 AM
    2014 Tundra Boy
    2014 Tundra Boy New Member
    2014 White Tundra TRD
    I’m watching with interest. I have a 14 CM that has issues with the driver and rear driver doors unlocking and locking when I use the key fob. Some days they work great, other days they’re crap. Please post pics of your process.
  15. Oct 29, 2019 at 5:02 AM
    ab1653
    ab1653 Ew member
    TX
    2014 Tundra
    Same issue here. I will be replacing the actuator on the drivers door today. I bought all the parts through Amazon, and found a thread here about that specific problem. 736C96C7-2BB0-4670-8F85-C62C9067F63B.jpg
    classiccat, Okielynch107 and OR18TRD like this.
  16. Oct 29, 2019 at 6:08 AM
    Okielynch107
    I didn’t have a new battery but I had a known working one and tried that. Same same. Going to order new as well though to avoid future embarrassment
    OR18TRD[QUOTED] likes this.
  17. Oct 29, 2019 at 6:09 AM
    Okielynch107
    Yup. It’s a delicate process getting the actuators apart without break the little tabs that hold the together. And the plastic rivet at the front top of the door panel....you will break it. Trying to find replacement on Amazon but no luck yet
    OR18TRD likes this.
  18. Oct 29, 2019 at 6:11 AM
    Okielynch107
    Also, to help you avoid the foul up I had, I will emphasize test the actuator after install BEFORE shutting your door. That is not a fun process to correct....ask me how I know
    OR18TRD likes this.
  19. Oct 29, 2019 at 6:46 AM
    Okielynch107
    Always easiest and cheapest first. I know it’s not a fuse because one door still works just like it’s supposed to. My next thought was battery, then actuator motor(cheap and not too difficult), then actuator (easier than motor but more expensive), next on my list is relay, and after that is termite grenade.
  20. Oct 29, 2019 at 6:46 AM
    Okielynch107
    Thermite stupid phone
    TundraDude18 likes this.
  21. Oct 29, 2019 at 7:46 AM
    shawn474
    MoCo, Maryland
    After going through this with the 4Runner, save yourself the time, effort and headache. Just order the entire actuator from Amazon and replace the whole damn thing. Trying to get it alart without breaking something and putting it back together and getting everything lined up is a royal pain. My time and sanity is more valuable to me than the $20 I would save.
  22. Oct 29, 2019 at 4:27 PM
    Okielynch107
    I’ve already had mine apart. Was too difficult. Just make sure you get to it before too many shiners.
  23. Oct 30, 2019 at 4:42 PM
    RJN55
    RJN55 New Member
    2018 Tundra LIMITED DC (Flares, Rear Sway Bars, Timbrens, B&W Gooseneck Hitch, Running Boards, Visors, 18 inch rims with 10 ply Michelin AT/2's, Bed Lights, Tow Mirrors
    Did you change any of your lights to LED?...see other topic on this...my '18 DC Limited started doing weird things with respect to the key fob after I changed the exterior cab lights to led. Turned out to be known problem on this forum.
    Pudge and 15whtrd like this.
  24. Oct 30, 2019 at 10:21 PM
    saramos
    Scott
    2014 Tundra
    Put in LED headlights almost 3 years ago. No other light replacements. Replaced the HU with a Pioneer 7200NEX last July. Added an iDataLink Maestro RR at the same time. Interestingly, the doors do lock and unlock when I move in and out of Park when I enabled that feature. It's strange that the power lock buttons on the front driver and passenger doors will unlock, but not lock the doors. I don't see how the battery in the fob could affect that. Aslo, I don't see how the fob would prevent the second turn in the door lock with the key from unlocking all doors.
  25. Oct 31, 2019 at 5:00 AM
    RJN55
    RJN55 New Member
    The LED issue is tied with radio interference (on my Camry I will get FM Radio static with my led brake lights). you do have a strange issue when it is tied to actual physical buttons not working...
  26. Nov 5, 2019 at 10:56 AM
    Greybeard
    Greybeard Retiree in training
    Forsyth Georgia
    2014 SR5 Double Cab
    I have one door giving me grief the last couple of weeks. The front passenger door randomly doesn't work. When it doesn't, it's a pain to get into. Everyone knows how big these cabs are and the gigantic center console doesn't allow you to simply reach over from the driver seat and unlock it for someone. I have to open the console to lower the height and then it's still a stretch. I've tried unplugging the door lock switch and cleaning it good with CRC electrical cleaner but it only lasts a day or so. I just bought a driver door actuator for my wife's Highlander because I'm tired of her complaining about it but haven't installed it yet. It's like the two vehicles talk to one another in the driveway every night and plan which one will crap out for the day.
  27. Jan 15, 2020 at 9:16 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I’m beginning to have issues like this with my 15 CM. It’s not a chronic issue. Sometimes it works great. Any suggestions? I think I should just take it to the dealer.
  28. May 22, 2020 at 6:46 AM
    Greybeard
    Forsyth Georgia
    2014 SR5 Double Cab
    Just gonna start leaving mine unlocked...it’s turned into a circus act trying to get into either of our Toyotas. Today it’s one lock tomorrow it’s another. Getting tired of crawling across from the opposite side to manually lock/unlock.
