Door lock failure
Discussion in '2nd Gen Tundras (2007-2013)' started by Jayhawk89, Nov 9, 2021.
  1. Nov 9, 2021 at 12:58 PM
    Jayhawk89
    Jayhawk89 [OP] New Member
    Albert
    2013 tundra crew max rock warrior
    Has anyone here had their electric door locks go out ? Mine went out slowly one door at a time and even started working again for brief periods. Now all 4 have quit. Replacing the switch was not successful.
  2. Nov 9, 2021 at 1:07 PM
    audiowize
    audiowize New Member
    Paul B.
    2008 Tundra SR-5 4x4 5.7
    Some have indeed had to replace actuators.
  3. Nov 9, 2021 at 3:20 PM
    Danny3737
    Danny3737 New Member
    2012 Tundra Limited Platinum
    My neighbors Tundra has issues with his locks when the temps drop below 50 degrees. When the temp is higher, they work normally
  4. Nov 9, 2021 at 8:37 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
  5. Nov 11, 2021 at 8:37 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
    Two of mine went out. It was a weird intermittent thing at first.
    finally took the plunge and went with replacing actuators.
    seller on eBay sells reman OEM units with lifetime warranty and gives you prepackaged shipping boxes and labels for your cores.
    “Actuatorplus” is the seller on eBay that I used and highly recommend
    Danny3737 likes this.
  6. Nov 11, 2021 at 10:40 AM
    BlueTSS
    BlueTSS New Member
    TX
    2014 Blue Tundra TSS
    Exterior - ReadyLift 4” SST Lift - BFG KO2 285/65/R20 - GST black wheels (2021 TSS) - MGP red caliper covers - TRD exhaust with black tips - TRD rear sway bar - Toyota blackout emblem overlays - Toyota bed rail system - Toyota bed light kit - AlphaRex headlights - AlphaRex style taillights - OEM LED fogs - OEM honeycomb grill - VLEDS Interior - Katzkin black leather seats - TRD black shift knob - Toyota all weather floor liners - SET wireless charger - Taco Tunes starter system - JL Audio 10TW3 - 3M 35% front tint - VLEDS
  7. Nov 11, 2021 at 10:55 AM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    I did my two door for under $100 and about 15 min each. Depending on how fast you can get door panels off.
    I have had mine off more than a few times and it’s easy at this point
  8. Nov 11, 2021 at 11:00 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I have replaced 2 of my motors and will soon have to do the 3rd. I bought a 4 pack of motors on Amazon for about $20 and replace them as needed. It's a little bit of a pain to pull the actuator apart, but it takes about 30 minutes total for me to replace one so it's well worth the savings from taking it to be done.
  9. Nov 11, 2021 at 3:38 PM
    Danny3737
    They are who I used Highly recommend them
  10. Nov 11, 2021 at 6:04 PM
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    I also got all four of mine through Actuatorsplus. I tried my hand at disassembling the acutator motor and cleaning it and ended up boning the whole thing. If you like taking apart stuff and snapping clips, buy the motors and replace them. If you just want to take out the old actuator and replace it with a refurbed unit, just buy 'em from actuatorsplus on ebay. It'll run you about $50-60 per unit, but it's way quicker and easier than futzing with disassembling the whole thing to swap the motor.
  11. Nov 12, 2021 at 10:29 AM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    Mine had 2 bad ones when I bought it-made the dealer fix it before I bought it. As soon as I got the truck, I had the automatic door lock feature (when you hit a certain speed) and automatic unlock feature (when you put it in park) disabled. I figured the constant locking and unlocking of all 4 doors is a major wear and tear issue, and in my case, I don’t want it anyway. I’m usually by myself in the truck, and can very easily just lock the door manually once I get going somewhere. And the doors open from the inside without needing to unlock it.
  12. Nov 12, 2021 at 10:45 AM
    Danny3737
    You bring up a good point. However, I’m guilty of hitting my lock and unlock button 2X when I’m either locking or unlocking the truck. I’m sure that adds excessive wear and tear on those mechanisms. I’m not sure why I do it, it’s probably my OCD. I do have mine set to either lock or unlock all the doors with one push on the fob. Being is usually just me as well, I could probably set it the other way to save wear and tear on the other 3 mechanisms. If they where a lot harder to replace ( like my old Denali) I’d probably do that.
    Rph74[QUOTED] likes this.
