Door/Key in Ignition Chime Disable
Discussion in '2.5 Gen Tundras (2014-2021)' started by shockinyall, Mar 27, 2017.
  1. Mar 27, 2017 at 6:48 AM
    shockinyall
    shockinyall [OP] Hillbilly
    West Virginia
    2017 TRDOR CM
    In Queue...
    I have tried searching to no avail. Doe anyone know how to disable the chime when the door is open and key is in ignition?
    I often listen to music from my truck and was able to disable the chime in my Tacoma without affecting anything else, ex. interior lights still came on when a door was opened. I know that I can just shut the drivers door and use other doors, but I am looking for a workaround for the drivers door. Thanks in advance.
  2. Mar 27, 2017 at 6:56 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    On my 2010,I had to unhook the White connector behind the steering wheel cover. It also disabled the driver's side door staying unlocked with key in switch.
  3. Mar 27, 2017 at 7:26 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I used TechStream to make mine as quiet as possible as I still wanted it, but didn't want it to be intrusive or obnoxious so that like you, I can listen to music with the door(s) open. I don't recall if it can be turned off completely though.
