Door harness
Discussion in 'Audio & Video' started by xj2202009, Sep 11, 2018.
  1. Sep 11, 2018 at 10:13 AM
    xj2202009
    xj2202009 [OP] New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    Does anyone knows how to pull this plug out..is the passenger rear door that goes from the center pillar through that rubber channel and into the door20180911_125328.jpg
  2. Sep 11, 2018 at 10:39 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    5100's @ 1.57, 295 55 20 nitto ridge grapplers, texas edition wheels (20x9 +50mm), TRD dual exhaust, TRD rear sway bar
    push the tab(s) in :notsure:
  3. Sep 11, 2018 at 10:40 AM
    saybng
    saybng New Member
    Gary
    16 Tundra 1794 CM
    Maybe push this tabs in using small flathead..
  4. Sep 11, 2018 at 7:35 PM
    perry3182
    perry3182 New Member
    2018 trd sport crewmax
    Pretty sure I pushed in a tab in the middle slot with a very small flat screwdriver.
  5. Sep 12, 2018 at 6:58 PM
    xj2202009
    x
    Lutz, Fl
    I was able to push on those tabs at the ends which allowed the plugs to separate enough to pull the outside one out enough to push the middle pin and completely separate them.
    Thank you.. That helped
