Door handle grease
Discussion in '2.5 Gen Tundras (2014-2021)' started by Predator Tundra, Jan 11, 2020.
  1. Jan 11, 2020 at 8:30 AM
    Predator Tundra
    Predator Tundra [OP] New Member
    Fallon, NV
    2020 Platinum
    I tried google first and they typical solution I’m seeing is to try and salvage the grease from the original handles. I want to be thorough when I swap them out though. Does anyone know what kind of grease is on the exterior handles.
  2. Jan 11, 2020 at 8:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I don’t know what kind. But I would probably use some type of silicone grease that is safe for plastic and rubber. Similar to the grease you would put on swaybar bushings. It’s also waterproof. If that wasn’t available I might go for some white lithium grease. Maybe somebody else will chime in with the exact type.
    Actually on my tailgate handle, when I put in my popNlock, I used Plumber’s heat proof grease. Because I’m a plumber and I had it LOL.
  3. Jan 11, 2020 at 9:21 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  4. Jan 11, 2020 at 9:55 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    PB Blaster has white lithium grease in a spray can. Put the little tube on and it's good for tight places
    Tundyfundy likes this.
