DON'T LOWER THE @#$##@%*$## TAILGATE
Discussion in 'General Tundra Discussion' started by pop's, Oct 2, 2018.
  1. Oct 2, 2018 at 2:38 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    2017 Tundra 1794 Blue Pearl / 1995 T100 4x4 DX
    $7500 in upgrades
    Switching from a Sequoia to a Tundra isn't that big of deal when it comes to driving, but towing is a whole different story. Ok wait what?... The issue is with the way the tailgate drops down on the 3rd leg of the trailer!
    The easy way out of the woods is to buy a class 3 Hidden Hitch. The hitch is long enough to custom tailor the length to your tailgate clearance needs. IMG_1699.jpg
  2. Oct 2, 2018 at 2:46 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Did you find out the hard way? :boink:
  3. Oct 2, 2018 at 2:46 PM
    417Tundra
    417Tundra New Member
    Levi
    2013 platinum
    Put it on the list. That there is another extension I need.
    rons23 and pop's[OP] like this.
  4. Oct 2, 2018 at 3:00 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    Almost
    Casper3[QUOTED] likes this.
  5. Oct 2, 2018 at 3:03 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    Same here :rofl:
    pop's[QUOTED][OP] likes this.
  6. Oct 2, 2018 at 3:07 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    Buddy of mine found out the hard way on his truck. Thanks for posting.
    pop's[OP] and 4x4_Angel like this.
  7. Oct 2, 2018 at 3:19 PM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    You wondered right. Your defiantly dealing with a Fat guy on a Teeter-Totter when it comes to leverage. 8" is all I needed to clear my tailgate.
    Sunnier and Watt maker like this.
  8. Oct 2, 2018 at 4:59 PM
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    IMO the extended receiver hitch is a bandaid solution.
    The real solution is lock your tailgate or move your jack.
    Don't get me wrong, electric lift is a nice feature, nice like you never want to crank another manual jack in your life again nice.
    Increasing receiver length increases of leverage on your hitch. This directly affects front / rear weight distribution which will impact truck & trailer handling characteristics
    Max tongue weight is 980lbs @9-10in from pin (standard length receivers)=816ft-lbs of torque on hitch
    Max tongue weight @14in = 1143ft*lbs(+327ft*lbs or 40% increase) or the equivalent torque @ 14in would reduce tongue weight to 588lbs.
    I picked 14in length but my best guess in photo the ball park of 15-18in. I didn't break out the mitutoyos to scale it.
    class III hitch receivers are suppose to only be rated for 600lb tongue.
    It is easier to balance loads on a larger tandem axle but this solution is not for everyone's setup
    pop's[OP], landphil, Sunnier and 3 others like this.
  9. Oct 2, 2018 at 5:21 PM
    Ya’ll make me proud.
    https://www.etrailer.com/question-93372.html
    People run into this problem a lot when owning a slide in camper, and want to tow a trailer.
    Frame/hitch damage is common without one of the high dollar hitches. This is a cheap one...
    https://www.carid.com/torklift/32-s...gAUGyMzdC7aDqAHiv6OEHVTpvyGc189oaAkweEALw_wcB
  10. Oct 2, 2018 at 6:13 PM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    My WDH has a proprietary hitch, no extensions. If I open my tailgate, it'll break the jack light so I don't open it unless I'm unhooked.
    That's a good solution though for your scenario!
    pop's[OP] and Watt maker like this.
  11. Oct 2, 2018 at 6:18 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    One of my trailers I bought extended tongue to avoid this, for the others when I went to the Gen y hitch it set me back just enough that I am able to open the gate of I'm straight. If the truck is turned with the trailer hooked its still a no go.
    https://genyhitch.com/
    pop's[OP] likes this.
  12. Oct 2, 2018 at 10:10 PM
    Bmwinter
    Bmwinter New Member
    2016 White Tundra SR5
    I was bummed when I first connected my trailer and learned that I could not drop the tail gate. When I purchased my Blue Ox WDH, I was happily surprised that the shank was long enough to allow me to open the gate! The Atwood jack also added clearance compared to my old unit since it didn't have the large forward facing motor.20181002_220242.jpg 20170305_094315.jpg
    pop's[OP], Watt maker and Y0TA PR0 like this.
  13. Oct 2, 2018 at 10:39 PM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    WELCOME
  14. Oct 3, 2018 at 4:48 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    Tomball, Tx./Lafayette, La.
    2010 Super White Tundra CM
    TRD Supercharger, TRD Big Brake kit, MotoMetal wheels, Undercover Tonneau with dual swing out saddle bag tool boxes.
    OK I may be a bit naive but I've never pulled a large travel trailer before so forgive me for this question: What is this Blue Ox thing and how does it work? I have driven 18 wheelers and pulled goosenecks but never a travel trailer.
  15. Oct 3, 2018 at 6:18 AM
    pop's
    pop's [OP] 1794
    Michael
    North Aurora IL
    $7500 in upgrades
    The 2" ball is 9" out of the receiver instead of 4" so adding 5" isn't going to damage a class 4 hitch or create a hazard towing a single axel trailer. There are forged hitch extensions that are rated at 14,000 pounds for $90
  16. Oct 3, 2018 at 7:19 AM
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    I am not trying to bash your solution.
    This thread reminds people to check before you drop the tailgate to prevent damage.
    Tailgate clearance is not the 1st thing I would check when being hooked up to a trailer. I appreciate the heads-up
    An enclosed single axle trailer (6x12) already has around 180lbs tongue weight
    The extended ball mount will drop your safe max tongue weight to 600lbs
    600-180= 420lb Then add electric jack + (battery to power jack?) etc.
    My point is mathematically, anything over 600lbs in the nose of your trailer without a counterbalance is likely to create an overloaded condition when using the extension. Maybe it's less, I don't your truck or trailer set-up.
    If you are aware and confident that your setup is OK great
    My intention is to educate someone new to the community that may not be familiar or even aware that this solution reduces towing/ payload / limits.
    pop's[OP] and JoshuaA like this.
  17. Oct 3, 2018 at 7:29 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    https://www.etrailer.com/faq-weightdistribution.aspx
    You would get the WDH rated for your GTW and TW. I believe the difference in TW rating for the Blue Ox is in the bars and visually the number of dots.
    https://www.etrailer.com/question-49962.html
    The main competing WDH brand is Equalizer, there may be others.
    pop's[OP] and Deuxlatch[QUOTED] like this.
  18. Oct 3, 2018 at 7:46 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Totally agree! Handling/safety will suffer if weights are high, this solution requires math and is for lighter setups.
  19. Oct 3, 2018 at 7:48 AM
    Deuxlatch
    Deuxlatch AirBus
    Chris (Latch)
    pop's[OP] and JoshuaA[QUOTED] like this.
  20. Oct 3, 2018 at 9:42 AM
    WrigglingWilly
    WrigglingWilly Well used Member
    2018 Tundra 4x4 5.7 8.1bed
    LineX
    An unsaid solution at this point, remove the tailgate when towing! I would not, but you could.
    Also, I do not know if you know, but I feel you should know, LineX can color match that lovely blue paint when you get a bed liner installed.... :spending:
    pop's[OP] and stuckinohio like this.
  21. Oct 3, 2018 at 10:00 AM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    First thing I did when I bought my 4 wheeler trailer was to move the jack.
  22. Oct 3, 2018 at 11:08 AM
    Over the LINE
    New Orleans
    I have not tried it with this truck and bumper, but my last truck you couldn't put a beer bottle on the bumper and open the tailgate.
  23. Oct 3, 2018 at 11:14 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    My dad did the same time first week I bought it. Only ding on the whole truck.
  24. Oct 3, 2018 at 8:23 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    I've done the same thing lol.
    I use a geny hitch which extends trailers with a jack on the tounge far enough. I had a cheap 90 dollar drop hitch the holes where the pins go turned into ovals after 1 year of use. You get what you pay for.
    Geny hitchCheap rated for "12k" hitch.
    Watt maker likes this.
  25. Oct 3, 2018 at 8:42 PM
    TundLee
    TundLee New Member
    Pyrite Mica 08 Tundra Rough Conutry
    3.5” Rough Country Lift Kit 20 inch Fuel wheels 33X12.5R20 LT ATTURO TRAIL BLADE X/T NGK Iridium ix sparkplugs FLOWMASTER DUAL Straight out back Heavy Duty General Springs (Extra leaf)
    Get the heavy duty leaf spring from General spring on it, if you ever replace yours. You’ll see big different of not worried about that issue. I like mines though.
  26. Oct 4, 2018 at 6:54 AM
    ktugboat42
    ktugboat42 New Member
    Pete
    Cape Cod
    2018 Cement Tundra TRD Double Cab
    Too late for me. Just add it to the other bunch of scratches i already have on an 8 month old truck.
    Seems like these new trucks scratch way to easy.
    WrigglingWilly likes this.
  27. Oct 4, 2018 at 8:37 AM
    WrigglingWilly
    LineX
    I feel Toyota paint is thin compared to the GMs and Fords I have experience with. One of the few downsides of the Toyotas vs The big 2.
    stuckinohio likes this.
