DON'T INSTALL LED TAIL LIGHTS ON YOUR SAFETY SENSE TUNDRA!!!
Discussion in '2.5 Gen Tundras (2014-2021)' started by GO DAWGS, Mar 14, 2019.
  1. Mar 16, 2019 at 10:47 PM
    atxtundra
    atxtundra New Member
    Damn you got your truck towed just for a fuse? A quick search and you’ll find your answer. There are 2 fuses that work with the taillights, TAIL and STOP.
    Pro tip: install one taillight at a time. LED taillights like your spyders need to have the plug installed a certain way. If your taillights/brake lights don’t work correctly, then reverse the plug. Buy a little box of extra fuses in case they keep blowing.
    I had the same problem you did, but once I realized what was wrong, they were super easy to install.
    Good luck!
    CO_Native and 15whtrd like this.
  2. Mar 17, 2019 at 5:24 AM
    LifeCycle
    LifeCycle Build..build..build..
    Hugh
    Barcelona Red SR5 XP CM 2017
    TRD Dual exhaust TRD headlights bedmat Elka with adjustment knobs, ARB leafs-ring Fuel Crush +1 offset 20 inch 5 in backspacing TOYO open country 275/65 R20
  3. Mar 17, 2019 at 8:12 AM
    Bergmen
    Bergmen New Member
    Ukiah, California
    2018 Blazing Blue Pearl DC 4X2 SR5
    Ah, gotcha.
  4. Mar 27, 2019 at 10:01 AM
    nmpeter
    nmpeter New Member
    South Florida
    18' Tundra Cement Crewmax
    Did you ever find out which fuse this was?
  5. Mar 27, 2019 at 11:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Here ya go
  6. Mar 29, 2019 at 1:00 PM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    Just did these this week. Everything works and no issues this early in the game.
  7. Apr 5, 2019 at 12:39 AM
    Tundra$
    Tundra$ White Trucks Matter
    Las Vegas
    2018 SR5 4x4 off-road CM 5.7 Super Fast White
    3/1 readylift, 35x11.5r20 ridge grapplers, 20’ fuel wheels, bakflip revolver bed cover, console safe, N-fab side rails, mini antenna, 2019 TRD Pro grill, color match hood bulge, front bumpershellz, baby car seat, to be continued...
    What’s the brand? I like the looks of those
  8. Apr 5, 2019 at 5:58 AM
    stevep1794
    stevep1794 New Member
    2019 Tundra Limited 2WD - Cement
    Yes there is...you can paint them (with a tinted base coat clear) I have them on my truck.
  9. Apr 5, 2019 at 6:51 AM
    bigzrs01
    bigzrs01 New Member
    Zack
    Charlotte, NC
    2018 Cement CM
    These were Spyders I got off eBay.
    IMO these look cleaner and simpler than the winjet version ones.
    Tundra$[QUOTED] likes this.
  10. Apr 24, 2019 at 11:59 AM
    Stevenbenji
    Stevenbenji New Member
    I’m probably late to this, but I found this forum thread useful, I had the same issue, I installed some smoked sounder tail lights, first light went of great. When I put the other light in, brake malfunction popped up on the screen, and didn’t let me shift into gear, turns out a fuse blew out. Changed the fuse and now both tail lights work, and brake override malfunction notice is gone...
    2018 Tundra... hope this helps.
    Fuse box is under driver foot leg, labeled STOP.
    Modsquad likes this.
  11. Oct 8, 2019 at 12:19 PM
    colossalcrewmax
    colossalcrewmax New Member
    2019 tundra crewmax
    S&B intake , nfab side steps , limo tint 5% and 35% front window , custom side exit exhaust
    1000% blew a fuse from plugging in the harness upside down and crossing the polarity . Change the fuse or fuses (should be one or two ) and problem will be resolved
    B737 likes this.
  12. Oct 16, 2019 at 6:36 PM
    Stick64
    Stick64 New Member
    Warren
    Las Vegas NV
    2018 White Tundra CrewMax Limited 4X4
    Headlight Revolution, I have the 2018 Tundra Limited and replaced all interior lights, cab and brake lights with LEDs from Headlight Revolution. It looks great and I have had no problems.
  13. Oct 31, 2019 at 4:07 AM
    SolidRock
    SolidRock New Member
    Bienve
    Cement Doble Cab
    tonneau cover. Seat Cover. Step bar
    I wish to know.. what brand are those and If you just put it and that It ??.. as you didn’t change anything else.
    Migraine likes this.
  14. May 13, 2021 at 8:34 AM
    nmjameswilson
    nmjameswilson New Member
    James
    Kansas City
    2021 Limited Nightshade Double Cab
  15. May 13, 2021 at 8:40 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Smart ass. :bananadead:
  16. May 13, 2021 at 9:04 AM
    nmjameswilson[QUOTED] likes this.
  17. May 13, 2021 at 9:04 AM
    nmjameswilson
    James
    Kansas City
    Thank you
    Tundra234 likes this.
  18. Oct 18, 2024 at 12:54 PM
    Totmacher
    Totmacher New Member
    Daniel
    West TN
    mesquite Tundra or blue 4Runner
    Some
    old thread but anyways, since I just had issue today and search saw a few threads of people periodically having same deal...
    There is a 10A fuse called STOP under the dash. That's the one that blew on my 2018 today and made a bunch of warnings light up. Brake Override Malfunction, Trailer Brake Error, Pre-Collision System Malfunction, plus the "brake" light in cluster and some other lights. Can't figure out why fuse blew on mine. No damaged wires or loose plugs that I could find.
