Does this truck use blinker fluid?
Discussion in '3rd Gen Tundras (2022+)' started by TundraDan723, Aug 27, 2023.
  1. Dec 24, 2023 at 12:17 PM
    #61
    mayan
    mayan One pull a day keeps the engine debris away.
    Mayan
    DFW
    2023 SM Tundra Limited
    Very interesting. I’m thinking maybe the wiper plumbing system primes itself on startup thus lower fluid level but if you didn’t use any fluid tank level should be the same after powered off so I guess that doesn’t make sense. Unless you didn’t get the Toyota General Usability Subscription.
  2. Dec 24, 2023 at 12:28 PM
    #62
    DRP
    DRP Old Member
    Dave
    Exactly. And when the subscription runs out the washer fluid tank self destructs:thumbsup:
  3. Dec 24, 2023 at 1:00 PM
    #63
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    Just grab the truck and shake it.
    Markus and TundraDan723[OP] like this.
  4. Dec 25, 2023 at 1:21 PM
    #64
    TundraDan723
    TundraDan723 [OP] Not as new as I used to be...
    2023 Celestial Silver Tundra 1794 TRD CM
    When I first purchased my truck and saw the filler neck empty, I wondered if there was any fluid in the tank, so I filled it up. A couple days later I noticed it was empty again. After three times of this experience, I wondered if there was a leak (or the truck used blinker fluid :rofl:)
    Mattedfred likes this.
  5. Feb 26, 2025 at 5:33 PM
    #65
    Lunar * Rock
    Lunar * Rock New Member
    I have a 24 tundra and 25 sequoia and having the same issue on both. Anyone have an update on this? Is it an air pocket in the reservoir?
  6. Feb 26, 2025 at 5:41 PM
    #66
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
  7. Feb 26, 2025 at 8:06 PM
    #67
    DRP
    DRP Old Member
    Dave
    Yes
  8. Feb 26, 2025 at 9:34 PM
    #68
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    Definitely an air pocket.
  9. Feb 26, 2025 at 9:36 PM
    #69
    Lunar * Rock
    Even though I don’t see fluid anywhere at all? And Do I just keep filling it until it’s gone?
  10. Feb 26, 2025 at 9:37 PM
    #70
    Lunar * Rock
    Do I just keep topping it off until the neck starts stays full?
  11. Feb 27, 2025 at 5:26 AM
    #71
    DRP
    DRP Old Member
    Dave
    Yes
  12. Feb 27, 2025 at 7:10 AM
    #72
    Lunar * Rock
    thank you! So just keep topping it off until it stops going down and that’ll mean the air pocket is gone?
  13. Feb 27, 2025 at 7:17 AM
    #73
    DRP
    DRP Old Member
    Dave
    Yes. At least that's what I assume since you can't actually see the whole reservoir. I don't actually check it after every fill up because I really don't care about getting the last micro ounce of fluid into it. Fill it up to the neck and go on with life.:thumbsup:
  14. Feb 27, 2025 at 7:31 AM
    #74
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    Machining debris causing engine failures and now this!!!!!!!!!!! Toyota sure aren’t what they used to be!!!!! If they change the part numbers on the wiper fluid reservoir, then you know that it’s a conspiracy!!!!’
    TundraDan723[OP] and astrength22 like this.
