Does size on tires make the difference or just the weight?
Discussion in 'General Tundra Discussion' started by Rica25, Feb 25, 2019.
  1. Feb 25, 2019 at 5:19 PM
    Rica25
    Rica25 [OP] Got Bam? IG ......@TNDRA08
    Ricardo
    Tulare
    So I'm running 295 70 18 Nitto Ridge Grapplers E load and truck seems to be down shifting when going up certain small slopes on highway.....if I go to 295 70 18 in Non E load but only weigh 51 lbs where my Nittos weigh 68 lbs.....will the truck stop down shifting and also not waste as much fuel?
  2. Feb 25, 2019 at 5:25 PM
    deedubb
    deedubb New Member
    David
    2018 Tundra SR5
    I think it’s all about weight, rotational mass etc....but I’m curious now as well
    15whtrd likes this.
  3. Feb 25, 2019 at 5:25 PM
    15whtrd
    15whtrd Mr. Blonde
    I feel like it’s both. Size for sure will do it. But the weight adds resistance too. And not the same type as just throwing weight in the bed. Interested to see what someone will say with more knowledge.
    Rica25[OP] likes this.
  4. Feb 25, 2019 at 5:27 PM
    Rica25
    Ricardo
    Tulare
    I can get Nitto Terra Grappler G2 295 70 18 that weigh 51 lbs instead but only if the down shifting and fuel go back to when I had 275 70 18 few yrs ago
  5. Feb 25, 2019 at 5:38 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Both. Size is going to cause downshifting because the rpms are too low for your current speed. Weight makes it feel sluggish. Just going to e rated stock size tires my truck was much slower
    15whtrd and Rica25[OP] like this.
  6. Feb 25, 2019 at 6:27 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
    So my steelies are outfitted with 18s 255. Should I go 275 ?
  7. Feb 25, 2019 at 6:29 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    255/70 is about the same diameter as 275/65
    SiberianTundra likes this.
  8. Feb 25, 2019 at 6:31 PM
    Mnorris1206
    08 tundra
  9. Feb 25, 2019 at 6:33 PM
    Rica25
    Ricardo
    Tulare
    Yes sir
    Mnorris1206[QUOTED] likes this.
  10. Feb 25, 2019 at 6:35 PM
    Mnorris1206
    08 tundra
    Wonder what the diference is I'm running 35s dont get alot of chancing gears that everyone speaks of. Actually on the high way I run around 2k rpm sometimes lower. Depends
  11. Feb 25, 2019 at 6:35 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The one thing is. If your current 295s have lots of tread left, you’re going to lose more in resale than you will save in gas
    Inquiringone likes this.
  12. Feb 25, 2019 at 6:36 PM
    Rica25
    Ricardo
    Tulare
    Never had down shifting issue till these tires were installed
    Mnorris1206 likes this.
  13. Feb 25, 2019 at 6:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Mine downshifted like crazy on the highway with 35s
  14. Feb 25, 2019 at 6:37 PM
    Rica25
    Ricardo
    Tulare
    Mine does it on little highway climbs only but RPM at 75 is about 1900
  15. Feb 25, 2019 at 6:38 PM
    Mnorris1206
    08 tundra
    Idk wonder if intake amd exhaust would have much to do with it? I have a drop in k&n and straight pipe no mufler at all. It breathes a lot .
    Mountun Goat and Rica25[OP] like this.
  16. Feb 25, 2019 at 6:39 PM
    Mnorris1206
    08 tundra
    Man that's what I'm running pulling my camper .I'm lost right now.
  17. Feb 25, 2019 at 6:39 PM
    Rica25
    Ricardo
    Tulare
    I have drop in TRD with coolant bypass and also TRD air flow accelerator with BA muffler
    Mountun Goat and Mnorris1206 like this.
  18. Feb 25, 2019 at 6:41 PM
    Rica25
    Ricardo
    Tulare
    What kind of tires you have
  19. Feb 25, 2019 at 6:42 PM
    Mnorris1206
    08 tundra
    Also what tore pressure are you running that makes a big difference for me .
  20. Feb 25, 2019 at 6:42 PM
    Mnorris1206
    08 tundra
    Bfg ko2
  21. Feb 25, 2019 at 6:43 PM
    Rica25
    Ricardo
    Tulare
    295 70 18 as well......E Load?
  22. Feb 25, 2019 at 6:44 PM
    Mnorris1206
    08 tundra
    Yep E 10 ply 35 12.5 18
    Rica25[QUOTED][OP] likes this.
  23. Feb 25, 2019 at 6:48 PM
    Rica25
    Ricardo
    Tulare
    I was even willing to trade for any 295 70 18 NON Hybrid or down size to 285 65 18 or 275 70 18
  24. Feb 25, 2019 at 6:49 PM
    Rica25
    Ricardo
    Tulare
    Only have 8k miles on them less than year old and no off road yet only highway miles
  25. Feb 25, 2019 at 6:52 PM
    Mnorris1206
    08 tundra
    Irk of I didnt need to pull my camper I would go with somethimg other then a load E rated they are heavy. It may help you by doing that.
  26. Feb 25, 2019 at 7:49 PM
    SiberianTundra
    Greg
    War Machine
  27. Feb 25, 2019 at 7:51 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    With a rotating mass the diameter is also very important. It's why some differentials have carrier breaks.
  28. Feb 25, 2019 at 7:51 PM
    Rica25
    Ricardo
    Tulare
  29. Feb 25, 2019 at 7:54 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Just bite the bullet and regear Rica. Since you only have 2wd shouldn’t cost too much. You might change tires and still have the same problem and will end up spending a small fortune on tires.
  30. Feb 25, 2019 at 7:59 PM
    Rica25
    Ricardo
    Tulare
    That's my
    That's what I didnt really want to do though.....i would love to but I'm afraid who ever does the work might not do it right and have problems later.....my truck has always ran hood ams no issues I would hate to ruin something by re gearing.....
    Mountun Goat likes this.
