Does front Diff need a breather mod?
Discussion in '2.5 Gen Tundras (2014-2021)' started by DividedSky, May 17, 2018.
  1. May 17, 2018 at 3:55 PM
    DividedSky
    DividedSky [OP] New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    So I bought an ARB Diff Breather kit and was all set to do front and rear.
    Then, In my research, I found folks that say the front isn't necessarily bc it is already up in the engine bay.
    What about the caps though? Are they the 1-way caps? So if you go through water and the diff contracts, these close up and water gets sucked in through the axles?
  2. May 17, 2018 at 4:15 PM
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Engine bay breathers are pretty high up. You can do the engine bay breathers and extend/relocate, but if you are getting into any water that high I would be more worried about other things sucking in water.
    joonbug likes this.
  3. May 17, 2018 at 4:39 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Sounds about right... :bowdown:
    dcsleeper408[QUOTED] likes this.
  4. Dec 17, 2018 at 8:34 AM
    Liferider98
    Liferider98 New Member
    2018 tundra DC magnetic grey
    Where are the front breathers located?
    Thanks
  5. Dec 17, 2018 at 8:54 AM
    DividedSky
    Jeff
    If I recall, they are near the fuse box
  6. Dec 17, 2018 at 8:58 AM
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    In the area below the brake booster
  7. Dec 17, 2018 at 9:17 AM
    gosolo
    Ray
    NW Oregon
    I have never heard anyone say that they got water in the rear differential from the check valve failing, so that one is probably not needed either.
    However, the rear differential breather mod is so easy and inexpensive, it’s pretty good insurance against a potential failure.
    because_wumbo-truck likes this.
