Does A Cheep Foam Cannon Cut It?
Discussion in 'Detailing' started by bullockdl, Aug 5, 2020.
  1. Aug 5, 2020 at 8:43 AM
    bullockdl
    bullockdl [OP] New Member
    2019 Limited 4wd
    I gave my new Tundra its first proper wash last night and was testing a cheap foam cannon out to see if it is as good or better than the high dollar jobs. Check it out!
    Rica25, YotaFan05, saybng and 3 others like this.
  2. Aug 5, 2020 at 8:55 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    Looks to do a fairly good job. I do not have or use a foam cannon, I may have to finally get one.
    Thanks for the video!
    Rica25, ToyoMafia and bullockdl[OP] like this.
  3. Aug 5, 2020 at 9:03 AM
    usmealgle
    usmealgle New Member
    orjan
    White 2017 Tundra Limited CrewMaxx
    so after you use the foam cannon do you still go over the vehicle with a foam pad or mitt and wash it or is the foam supposed to do that for you?
    Thanks
    Rica25 likes this.
  4. Aug 5, 2020 at 9:06 AM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    You still have to wash it. The cannon just applies the soap and let it soak since the foam sticks to the surface, making it easier to wash.
  5. Aug 5, 2020 at 9:07 AM
    usmealgle
    orjan
    Thank you.
    Boerseun likes this.
  6. Aug 5, 2020 at 9:07 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I think the cheap ones work just as well as a more expensive one. The type of soap and how/if you dilute it is more important to get a good sticking soap.
  7. Aug 5, 2020 at 9:11 AM
    owb2gp
    owb2gp New Member
    ID
  8. Aug 5, 2020 at 9:12 AM
    bullockdl
    2019 Limited 4wd
    That was what I thought coming out of it. I think there are better performing soaps than what I used. Would love to hear what soaps you guys have had a good foam experience with.
  9. Aug 5, 2020 at 9:12 AM
    usmealgle
    orjan
    from what little i know about the foam cannons i like but is it worth dragging out the pressure washer every time you wash the Tundra?
    just asking really.
    bullockdl[OP] likes this.
  10. Aug 5, 2020 at 9:14 AM
    bullockdl
    2019 Limited 4wd
    I think so however I would prefer to have an electric power washer of the same PSI. Just dont like all the noise.
    usmealgle[QUOTED] likes this.
  11. Aug 5, 2020 at 9:21 AM
    Trooper2
    JR
    Just remembering that they require a pressure washer. Not as interested again.
    Is there on that just hooks up to the hose? Probably not :(
    Darkness likes this.
  12. Aug 5, 2020 at 9:25 AM
    Boerseun
    Ferdie
    Sarasota Florida
    I have a small electric pressure washer that I use for washing the cars. I am using it to clean the underside, wheel wells and wheels anyways, so plugging in the soap cannon is no extra effort.
  13. Aug 5, 2020 at 9:37 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
  14. Aug 5, 2020 at 9:38 AM
    bullockdl
    2019 Limited 4wd
    What electric power washer do you have?
  15. Aug 5, 2020 at 9:50 AM
    Boerseun
    Ferdie
    Sarasota Florida
    It's been working really good for the cars, around the back porch/lanai etc. I have a gas pressure washer for the heavy duty jobs, but almost never use it anymore.
    bullockdl[QUOTED][OP] likes this.
  16. Aug 5, 2020 at 10:12 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    I have the same pressure washer as @Boerseun and it works great for washing vehicles. Mine is going on 6 years old and I use it for the vehicles, concrete patio, lawn furniture, siding, etc. They also have a foam cannon attachment for it.
  17. Aug 5, 2020 at 10:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I got an inexpensive cannon from Lowes when I purchased one of their greenworks 2000 psi electric washers. Both work like a champ. I have only used meguiars gold class wash, but performance is good. There are much better soaps out there that will be slicker and have more foam, but they also cost 2x more.
    shawn474 and bullockdl[OP] like this.
  18. Aug 5, 2020 at 10:28 AM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I have an expensive foam cannon (Torq) and inexpensive pressure washer (ryobi) and it gets the job done very well.
    Skew12 and bullockdl[OP] like this.
  19. Aug 5, 2020 at 10:38 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    I have a decent pressure washer and a $20 Amazon foam canon. It does fine by my standards
    I've been very happy with it.
  20. Aug 5, 2020 at 11:22 AM
    owb2gp
    owb2gp New Member
    ID
    I use CarPro Reset and Shine Supply Shift. Both have worked well for me.
  21. Aug 5, 2020 at 11:27 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
  22. Aug 5, 2020 at 11:28 AM
    owb2gp
    owb2gp New Member
    ID
  23. Aug 5, 2020 at 11:34 AM
    alpinepro4
    Pat
    Ok I am running Green Works 1500. Don’t think it has quite enough pressure. Waiting for GW to die so I can replace it. Bastard won’t die!
  24. Aug 5, 2020 at 12:22 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
  25. Aug 5, 2020 at 12:31 PM
    War Machine
    War Machine SSEM # 5 3MW
    Great video! I’ve been using a twenty dollar MATCC cannon from Amazon for three years now with no issues. I’ve tried a couple of the more expensive ones and couldn’t tell a difference. Definitely not a product you need to spend a lot of money on.
    I use Chemical Guys Honeydew Snow Foam in mine and it works great. It’s not my go to soap for normal washes, but works better than anything else I’ve tried in the foam cannon.
    I use a Greenworks electric pressure washer. I believe it’s a 2200 psi.
    ToyoMafia and BravoDeltaRomeo like this.
  26. Aug 5, 2020 at 12:34 PM
    War Machine
    Chemical Guys Honeydew is my favorite.
    I use hot water in my mixture. I find it helps make more foam and it’s not as runny.
    BravoDeltaRomeo likes this.
  27. Aug 5, 2020 at 12:35 PM
    War Machine
    I drag the pressure washer out every time any way unless doing a rinseless wash.
  28. Aug 5, 2020 at 12:36 PM
    Squatting Pigeon
    Holden
    North Texas
    GR Corolla
    I second @War Machine’s recommendation of CG honeydew. It makes great foam! Mr Pink from them is a very close second too.
  29. Aug 5, 2020 at 12:40 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    Yup...me too. It smells good too. Warm water in canon and warm water in my soap bucket if I'm wash mitting it.
    Yup...me too. Pressure washer sits in front of Tundra and I just move the hose around to wash. It's on wheels and not like I have to carry it on my back.
    About the only time I use it is to wash the vehicles. If I didn't pull it out for that, I may as well sell it
  30. Aug 5, 2020 at 12:54 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    Great video. I’m not a foam cannon user but I can appreciate them. I do use a sunjoe electric pw almost every wash it is just easier then dragging out the gas one. I really want a comet installed on the garage with a sediment filter on the intake.
