Dobinsons Suspension Review
Discussion in 'Suspension' started by lagranger, Aug 5, 2019.
  1. Mar 8, 2022 at 8:03 AM
    #841
    900exdriver
    900exdriver New Member
    Yeah, came with the kit. It look like it was also for the 200 series LC as the instructions were for that platform.
    Btw, your truck was my inspiration. Love your setup.
  2. Mar 8, 2022 at 8:12 AM
    #842
    wvtriple
    wvtriple New Member
    2010 Super White RW CM
    Apreciate the kind words. I think I might out source a Ready Lift SS 4" diff drop to get my angles better, I feel like I'm on borrowed time........
  3. Mar 8, 2022 at 8:19 AM
    #843
    900exdriver
    I’ll take a picture of my angles when I get home this weekend. The spacers/pucks were thick. I have an extra one that came with the kit you can have if you locate another one.
    wvtriple[QUOTED] likes this.
  4. Mar 9, 2022 at 8:41 AM
    #844
    Hugemoose
    Hugemoose New Member
    David
    Philly
    2016 Tundra Crewmax
    Not enough....
    Looks great!!! Damn near exactly the same set-up I have, except I have the Toytec shackles set to 1" of extra lift. I agree the diff drop did help a bit, and I think I gained a bit under 3.5" up front with the 778, twin tubes, and shims. I also added a carrier bearing spacer. After a few thousand miles it's still great. And the leaf springs are so much better than OEM when it comes to handling some weight.
    brevard828, ZPhilip, Kernal and 3 others like this.
  5. Mar 9, 2022 at 3:16 PM
    #845
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    I thought the consensus on here was that diff drops do nothing on our trucks but make things worse.
  6. Mar 9, 2022 at 4:50 PM
    #846
    crikeymike
    crikeymike ExitOffroad.com
    Jacksonville Beach, FL
    Some people were spreading that info here in the past, while I've been saying the whole time that it's worth adding to reduce the CV angles when lifting so much.
  7. Mar 9, 2022 at 5:10 PM
    #847
    cran2
    cran2 New Member
    Folly Beach, SC
    07 Crewmax 4x4 and 03 Sequoia 4x4
    Since the Pro was 2” over stock and didn’t use a diff drop, I didn’t. My Dobinsons netted 2.75 lift, so I didn’t add a diff drop since the cv angle isn’t very far off from where the Pro would be.
    I would love a definitive, evidence base answer on this.
  8. Mar 9, 2022 at 7:00 PM
    #848
    AggiePhil
    College Station, TX
    There have been many many posts on here about how a simple spacer type diff drop does not reduce CV angles on the Tundra and may actually serve to starve the diff of oil in some cases, due to the angle it places it in.
    equin, JLS in WA and cran2 like this.
  9. Mar 12, 2022 at 5:30 PM
    #849
    900exdriver
    Here are some under carriage photos. Cv’s still have some angle. Time will tell if the diff drop helps.
    [​IMG][​IMG]
    Kiddnapped Tundra, DZ_ and AggiePhil like this.
  10. Mar 17, 2022 at 11:10 AM
    #850
    AggiePhil
    College Station, TX
    Are those of you running the Dobinsons suspension using their front bump stop kit? Or a different type of front bump stops?
  11. Mar 18, 2022 at 5:04 PM
    #851
    900exdriver
    I bought CB extended bump stops but found it way too much for my truck. If you look at my photo of the front you see there isn’t much need for it.
  12. Mar 18, 2022 at 5:17 PM
    #852
    AggiePhil
    College Station, TX
    Too much as in they were too tall?
  13. Mar 18, 2022 at 5:23 PM
    #853
    900exdriver
    Yes, too tall. Would restrict travel more than it needs to be. That said I’d sell my one if you’re interested.
  14. Mar 18, 2022 at 5:28 PM
    #854
    AggiePhil
    College Station, TX
    What’s the formula for figuring out the height of bump stops needed after a lift? Both front and rear?
    Factory bump height + lift height = new bump stop height?
  15. Mar 18, 2022 at 5:40 PM
    #855
    900exdriver
    CB says 3”-4” lift you should run it. That’s what my reasoning was to buy them. But by looking at it I wouldn’t have much travel if I install them.
  16. May 3, 2022 at 7:06 AM
    #856
    crikeymike
    TRDblvd and DZ_ like this.
  17. May 14, 2022 at 8:49 PM
    #857
    gabex35
    gabex35 2020 Limited 4x4 with mods coming...
    San Diego
    2020 Cement Limited 4x4
    Got some HD leafs on today and I think they’re going to work out great. Pretty tall but will settle in with the weight of my build out I think.
  18. May 16, 2022 at 6:59 PM
    #858
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    I have a 17 double cab rwd with the toylift 3" leveling kit front and 1" block in the back, everything else is stock. I have a small rub at full lock, I want to get a full suspension and due away with the spacers. What Dobison's should I go with?
  19. May 17, 2022 at 6:42 AM
    #859
    crikeymike
    Being a 2WD, you'll have to go with 1 step down of coils so that it doesn't overlift without the front axle in place. I'd suggest the 2.5" coils up front which will lift it 3", and in the back I sell a 1" add-a-leaf kit or a 2" full leaf spring replacement. Not sure if you want the rear height to go up or not.
    The rubbing won't necessarily be cured by changing the lift. If it rubs at any position during the range of suspension movement, then you can either adjust the steering stops so it doesn't turn as much and doesn't rub wherever it's rubbing, or trim the contact point back.
    You have your choice of twin tube or IMS. Since it's a 2WD, I'm betting it's just an on-road truck, so the twin tube would get you going without any issues. It is softer than the IMS due to the shock design and it uses low pressure gas, compared to high.
    This is the page with an add-a-leaf rear option: https://exitoffroad.com/product/dobinsons-tundra-2-25-to-3-0-quick-ride-kit-for-2007-2020-4x4-v8/
    This is the page with the full rear leaf pack option: https://exitoffroad.com/product/dob...toyota-tundra-2007-to-2020-double-cab-4x4-v8/
  20. May 17, 2022 at 7:23 AM
    #860
    xj2202009
    x
    Lutz, Fl
    Thank you for the that, She is a daily driver, On road/camp ground truck. I tow a 7k 30' camper, what would it be best Twin tube or IMS? What is the difference between Twin tube and IMS?
  21. May 17, 2022 at 7:44 AM
    #861
    crikeymike
    I'd still just go with twin tube.
    Twin tubes are fully sealed, non-serviceable, lower in cost, long lasting, and they ride very well.
    IMS are high pressure monotube shocks, higher performance for more offroading and heavier vehicles, and they're also rebuildable. I only suggest these usually for people that are going offroad often and need higher performance to handle rougher stuff. It's like you wouldn't put mud terrains on your truck if you don't ever take it in the mud, unless you like to spend extra money and like the look of them. haha
    AggiePhil likes this.
  22. May 17, 2022 at 7:55 AM
    #862
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    There were also past issues with IMS system running very high, too much lift with extreme angles. Not sure if Dobinsons worked that out but details should be earlier in this long thread.
  23. May 17, 2022 at 8:04 AM
    #863
    xj2202009
    x
    Lutz, Fl
    :monocle: I added the hybrid tires, my camper is stored in an area that stays wet pretty frequent and I like the look, but I will do the Twin Tubes.:bananadance:. Thank you kindly for all the info and the links.
    crikeymike likes this.
  24. May 17, 2022 at 8:14 AM
    #864
    crikeymike
    Yeah, they told us the wrong clip height to use on the IMS to start with, but that was realized after just a week or so.
  25. May 22, 2022 at 1:40 PM
    #865
    Kernal
    Kernal New Member
    Kyle
    Charleston SC
    ‘18 4x4 4x4 DC
    10k mile update on my 778s and twin tubes. Stock leafs for now with a 2” block. No sways. Bud built 3/16 full skids and wkof sliders. (+/- 500pounds of armor)
    the ride is far better than stock, does very well off-road. Measures out at 3” of lift upfront still. Very impressed by this setup. 120s are on the short list.
  26. May 29, 2022 at 12:11 PM
    #866
    AggiePhil
    College Station, TX
    Dobinsons-inspired HydroFlask. :cool:
    JLS in WA, Hugemoose and crikeymike like this.
  27. May 29, 2022 at 12:43 PM
    #867
    rruff
    rruff New Member
    2016 Tundra SR DC Long
  28. Jun 19, 2022 at 2:56 PM
    #868
    crabbymcnab
    crabbymcnab New Member
    2016 Inferno SR5
    I’ve got an issue, not necessarily a dobinsons issue, more of my leaf packs I think. Put on the dobinsons 2-3” front and rear shocks with coachbuilder 3” shackles 18k ago. I noticed this week that the driver side rear is 2” lower than passenger rear (24” vs 26” measured hub to fender). I don’t have excessive weight in the bed, simple tools and diamondback cover. Measurements taken at 1/2 tank of fuel (38 gallon). Tried to get a pic of the spring pack which seems to have a neutral or slight negative arch. 1st photo is passenger side, 2nd is driver side. I’ve read that tundras seem to have more of a low or neutral arch, but this seems excessive. FYI, front height at 24.5” both sides
    any thoughts?
  29. Jun 19, 2022 at 3:15 PM
    #869
    rruff
    rruff New Member
    Shackles will put more stress on the springs if you carry a load or offroad. The springs have to bend farther before you hit the bumpstops.
  30. Jun 19, 2022 at 3:45 PM
    #870
    AggiePhil
    College Station, TX
    EXTENDED shackles
    crikeymike and rruff[QUOTED] like this.
