Dobinsons IMS Struts and Shocks for 2007+ Tundra's (IFP Monotubes)
Discussion in 'Suspension' started by crikeymike, Jan 14, 2021.
  1. Jan 29, 2021 at 3:33 PM
    #61
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    Yea, I just got the email! Thanks!!!
  2. Jan 30, 2021 at 8:37 PM
    #62
    eick
    eick New Member
    2020 CrewMax TRD Off Road
    What’s the general thought on these shocks but stock rear leaf pack left in?
    farm&forest likes this.
  3. Jan 30, 2021 at 8:45 PM
    #63
    rjsimz
    rjsimz New Member
    Rob
    2015 SR5 CrewMax 4x4
    I'm actually curious about the same. Interested in this set up as well.
  4. Jan 30, 2021 at 8:55 PM
    #64
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    If I wanted to achieve 3 inches of lift in the front, what clip height would it be set to, and could I still use a shim to correct the Toyota lean?
  5. Jan 30, 2021 at 9:23 PM
    #65
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    It is possible to use lift coils with the Falcons? I have a set of Eibach springs to use if it works.
  6. Jan 30, 2021 at 9:59 PM
    #66
    TundraLaw
    Northern Nevada
    Also, should I get the HD 3” springs or the regular 3”. I have a 78lb ADD front bumper on with light bar and RCI skids. And are the front and rear in stock? I just purchased the rears.
  7. Jan 31, 2021 at 4:56 AM
    #67
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    They specifically tell you not to if you ask them.
    I would presume it may not play nicely with the ZRT (internal progressive bump stop for down travel).
    Probably same goes for the up travel bump stop.
    They also said they have no plans for a full coilover assembly where you don’t reuse the factory spring and top hats.
    So I guess they feel they have it dialed in pretty well.
    Likely just fine like all the other kits if your use requires no need for something other than the stock leaf pack.
    They sell everything separate without indicating one would need an aftermarket leaf.
    crikeymike[OP] likes this.
  8. Jan 31, 2021 at 7:20 PM
    #68
    TundraLaw
    Northern Nevada
    I placed an order for front and rear! Thanks
  9. Feb 1, 2021 at 7:17 AM
    #69
    crikeymike
    crikeymike [OP] ExitOffroad.com
    Jacksonville Beach, FL
    Lowest/stock clip height setting, then add 3" coils.
  10. Feb 1, 2021 at 7:18 AM
    #70
    crikeymike
    Yep that's right, the Dobinsons IMS front and rear can be used with stock coils/leafs or lifted parts.
  11. Feb 1, 2021 at 8:10 AM
    #71
    eick
    eick New Member
    If you select strut assembly is it the $90 one or the $180 one? Also which top plate for a 3rd gen tundra? Didn't see it in there.
  12. Feb 1, 2021 at 8:16 AM
    #72
    Black
    If one were to use stock coils am I understanding correctly a maximum of only 1.18” of lift can be obtained.
  13. Feb 1, 2021 at 8:23 AM
    #73
    crikeymike
  14. Feb 1, 2021 at 8:33 AM
    #74
    dorton
    dorton #RockCreekOverland
    North Carolina
    2020 Black Tundra SR5
    CBI Off Road Front Bumper, Rock Sliders, Skids, and Bed Rack. Prinsu Designs Roof Rack, CVT Hybrid Rainier Tent, Old Man Emu lift, Fuel Vectors, Yokhama 305/70r18s
    @crikeymike Unrelated to the topic, but curious if Dobinsons is going to offer a Tundra equivalent
    of the Part# L59-112-R Super Heavy Load (for 800lbs). Those things were awesome on my 16'!
    Whats the + rating for the L59-121-R thanks
  15. Feb 1, 2021 at 8:35 AM
    #75
    crikeymike
    Yes, that's right
  16. Feb 1, 2021 at 8:38 AM
    #76
    crikeymike
    It hasn't come up so far, no one has needed heavier than these. They're rated to be run with a minimum of 400LBS of constant load, but there's no max rating. More weight equals less lift, and GVM shouldn't be exceeded
    Tundra's with a flat bed conversion and 4 Wheel Camper are running them no problem, like "Bound For Adventure" on IG and Youtube.
    dorton[QUOTED] likes this.
  17. Feb 1, 2021 at 8:56 AM
    #77
    dorton
    North Carolina
    Ltaco17 and crikeymike[OP] like this.
  18. Feb 1, 2021 at 10:07 AM
    #78
    TundraLaw
    Northern Nevada
    For anyone on the fence, Mike at ExitOffroad is a real professional. Customer service is great. I would not hesitate to buy Dobinson's from him.
  19. Feb 1, 2021 at 1:53 PM
    #79
    TundraLaw
    Northern Nevada
    Do you have the spring rate on the non HD version of the 3 inch springs, and what weight they're rated to?
  20. Feb 1, 2021 at 1:59 PM
    #80
    crikeymike
    662LBF/IN. They're rated for 3" lift with no front weight
  21. Feb 1, 2021 at 2:04 PM
    #81
    TundraLaw
    Northern Nevada
    Thanks!
    with 1.75" of lift in the rear being provided by CB shackles, and 90lb front bumper ADD Stealthfighter, what lift height would you recommend in the front to maintain an inch of rake?
  22. Feb 1, 2021 at 2:38 PM
    #82
    crikeymike
    3"
    Usually you lift the rear 1" less than the front to keep 1" of rake.
  23. Feb 1, 2021 at 4:17 PM
    #83
    NWPirate
    Zach
    WA
    @crikeymike Looking to upgrade the stock suspension on my 04 Sequoia. It won't see high speed off road, but definitely some decent trails. Would like to maintain on road performance too as it'll be a daily driver.
    Would you mind giving a first hand opinion on these two setups?
  24. Feb 2, 2021 at 6:59 AM
    #84
    crikeymike
    Probably the twin tube setup is all you'd need if you're not going hard offroad. The IMS will ride better in all conditions due to their biggest piston size and IFP, but it depends if you want to spend the extra $500 for the better struts/shocks. It's kind of like all terrain vs mud terrain, one can do everything, but the mud terrains are better in the mud. That's the best analogy I've come up with on TT vs IMS. You wouldn't buy mud terrains if you don't go in the mud, but maybe you will branch out and want to get dirty? hahah
    RJVA and NWPirate[QUOTED] like this.
  25. Feb 2, 2021 at 8:03 AM
    #85
    NWPirate
    Zach
    WA
    Appreciate it! Great analogy, so it's 1.75 inches of lift front and back correct?
    Do you guys have a forum discount or promo code going?
    I missed out on the 15% black Friday.
    Thanks!
  26. Feb 2, 2021 at 8:05 AM
    #86
    crikeymike
    Correct on the lift height.
    Yes, in my signature.
    NWPirate[QUOTED] likes this.
  27. Feb 2, 2021 at 9:05 AM
    #87
    NWPirate
    Zach
    WA
    Perfect, thanks.
    One more thing sorry, would you recommend the SPC UCA's for both setups?
  28. Feb 2, 2021 at 9:15 AM
    #88
    crikeymike
    Yes, to get the best alignment and articulation with that limited travel front suspension setup.
  29. Feb 2, 2021 at 10:12 AM
    #89
    NWPirate
    Zach
    WA
    :hattip:
  30. Feb 2, 2021 at 2:08 PM
    #90
    eick
    eick New Member
    I can tell everyone I have LT suspension. ‘Limited travel’
