Dobinsons IMS Struts and Shocks for 2007+ Tundra's (IFP Monotubes)
Discussion in 'Suspension' started by crikeymike, Jan 14, 2021.
  1. Feb 6, 2023 at 10:10 AM
    #271
    crikeymike
    crikeymike [OP] ExitOffroad.com
    Jacksonville Beach, FL
    The standard coil they come with is a 3" x 16" x 650lb rate coil. Technically you could go a little less lift by removing preload, since these are preloaded from above, the lower strut clearance won't be an issue, but the intention was to have 2" of lift at a minimum. Usually lower strut/coilover clearance to sway bars and other parts is the issue.
    JLS in WA likes this.
  2. Feb 18, 2023 at 11:15 PM
    #272
    blenton
    blenton New Member
    Tow more dumb questions for you, @crikeymike ..
    - Product literature says "Direct Bolt-On Design, does require lower mount clearancing". Could you elaborate on the lower mount clearancing?
    - I love those deliciously tantalizing teal coils, but boring black coils are more my speed. Rowdy red or simply silver would work as well. Any chance we can get these pre-assembled in colors other than titillating teal? I suppose I could just order them sans coil and assemble at home.
  3. Feb 20, 2023 at 6:43 AM
    #273
    crikeymike
    Hey bud. I've updated the wording on it. I was only told about it last week.
    The lower leg of the Dobinsons coilover is too thick (too much beef) for the lower mount to have the right amount of clearance at full droop, so that mount on the LCA just needs to be trimmed back a little. Photo attached.
    I'd love silver too!! The Dobinsons coilover coils these use will only be made in teal though. You can use another brand of coil if you want that's a different coil and just buy the MRA59-A710 by itself (without coils). https://exitoffroad.com/product/dobinsons-3-way-adjustable-mra-front-struts-toyota-tundra-2007-2021/
    It uses 16″ coils with a 3″ inner diameter and 650LB Spring Rate as standard, but there will be stronger options coming too for heavier loaded trucks.
    AggiePhil and chugs like this.
  4. Feb 20, 2023 at 10:56 AM
    #274
    rruff
    rruff New Member
    2016 Tundra SR DC Long
    What brand exactly? The universal coils (like Eibach) are all constant diameter and ground flat on the ends. The Dobinson coils are tapered and not flat on the ends. You'd need new perches (at least) to fit an Eibach coil.
    chugs likes this.
  5. Feb 20, 2023 at 11:02 AM
    #275
    crikeymike
    I was referring to the 2022+ Tundra coilovers from Dobinsons that use flat ground coils top and bottom. The 2021 and earlier use the OE style pigtail bottom and flat top.
    chugs and rruff[QUOTED] like this.
  6. Feb 20, 2023 at 11:04 AM
    #276
    blenton
    blenton New Member
    Well crap. Mine's a 2013. I was just about to order some Eibach coils..
  7. Feb 20, 2023 at 11:27 AM
    #277
    crikeymike
    The 2021 and earlier front coils from Dobinsons are offered in teal, black and red for twin tube and IMS struts.
  8. Feb 20, 2023 at 12:05 PM
    #278
    rruff
    rruff New Member
    Wait... you wanted MRAs, right? I was looking at IMS, and that is the photo I posted! The MRAs for 2nd gen do appear to have constant diameter and flat ends. It also looks like there is plenty of room for a longer coil too, if you want. Shouldn't be any clearance issues at the top.
    chugs likes this.
  9. Feb 20, 2023 at 12:41 PM
    #279
    blenton
    blenton New Member
    Funny, I was staring at them scratching my head, wondering if the stock photo was for a different setup. Those sure look like flat top coils to me...
    @crikeymike - can you confirm this?
    And as a side note, I see that Dobinson also offers IMS kits and parts for my sequoia, too. Crap. I had a bear of time trying to find rear shocks for that rig and ended up with another set of stock black shocks. When is this all going on sale?? My wallet might just be getting a bit lighter..
    rruff[QUOTED] likes this.
  10. Feb 20, 2023 at 12:49 PM
    #280
    crikeymike
    You guys keep jumping all around. The 07-21 Tundra MRA's come with coilover coils and only in teal. You can use other brands of coilover coils if you don't like the color. Each product page has the specs of what the options are.
    The photo of the Tundra MRA'S is of the actual product.
    AggiePhil and rruff like this.
  11. Feb 20, 2023 at 1:21 PM
    #281
    blenton
    blenton New Member
    We like to keep you on your toes, Mike. Now back to wo... SQUIRREL!! .. sorry, what was I saying?
  12. Mar 19, 2023 at 2:49 AM
    #282
    blenton
    blenton New Member
    Darn. Waited too long to get MRA's up front. Any idea when more stock might arrive? May just have to start with the adjustable rears and roll with my existing 6112's up front...
  13. Mar 19, 2023 at 6:26 AM
    #283
    crikeymike
    Next month I think
    chugs likes this.
  14. Apr 4, 2023 at 10:03 AM
    #284
    blenton
    blenton New Member
    Fedex crafts day??
    JLS in WA and chugs like this.
  15. Apr 4, 2023 at 12:50 PM
    #285
    don3032
    don3032 New Member
    don
    2021 Tundra Limited Crewmax Nightshade
    debadged, diamondback, window tint, dirty deeds exhaust.
    I just had a 5 ft weight bar delivered by de ex, and the managed to open it, and bend almost a ft.
  16. Apr 4, 2023 at 1:51 PM
    #286
    blenton
    blenton New Member
    UPS training videos leaked..
    And I’m retarded and don’t know how to attach a gif from my phone…
    don3032 and JLS in WA like this.
  17. Apr 14, 2023 at 8:33 AM
    #287
    blenton
    blenton New Member
    Any idea when the front MRA’s will be back in stock? I notice the website changed from Sold Out to Backordered..
  18. Apr 14, 2023 at 8:38 AM
    #288
    crikeymike
    Looking at mid-May approximately.
    chugs likes this.
  19. May 12, 2023 at 3:19 PM
    #289
    blenton
    blenton New Member
    Front MRA’s INCOMING!!! Now, the only question is… did Mike remember the stickers…?:monocle:
    bumpyride13, JLS in WA and chugs like this.
  20. May 18, 2023 at 11:44 PM
    #290
    bumpyride13
    bumpyride13 New Member
    2018 Silver Tundra TRD OR 4x4
    Lol I got the IMS on my truck and they sent me 8 MRA stickers…
  21. May 19, 2023 at 6:48 AM
    #291
    blenton
    blenton New Member
    So THAT’S why I didn’t get any…
  22. May 19, 2023 at 7:04 AM
    #292
    crikeymike
    Sounds like you guys need to make a new thread about stickers. LOL
  23. May 19, 2023 at 7:30 AM
    #293
    blenton
    blenton New Member
    Stickers add horsepowers... didn't you know? So really, we are just talking about horspers. That makes this a performance thread - more horspers to go with out our go fast suspensions... :D
  24. May 19, 2023 at 6:36 PM
    #294
    bumpyride13
    Maybe we will.. with blackjack and hookers!
  25. May 24, 2023 at 7:25 PM
    #295
    Js18tundra
    Js18tundra New Member
    18 Tundra sr5 TRD 4x4
    Diamondback se tonneau
    Are the IMS or the MRS considered extended travel?
  26. May 25, 2023 at 4:48 AM
    #296
    crikeymike
    Yes they are
  27. May 28, 2023 at 7:59 PM
    #297
    Js18tundra
    Anyone else have any updates on how their mrr’s or IMS coilovers are doing?
  28. May 31, 2023 at 8:11 AM
    #298
    Jeremy323
    Jeremy323 New Member
    Jeremy
    2011 Tundra CM
    Just installed the leafs, which shocks is everyone running with them? Will use them for mainly DD, but I also need to tow and travel a lot of dirt/washboard roads. The stock shocks seem to not be long enough, as the leafs are compressed a bit. My stock shackle is moved back with no load.
  29. May 31, 2023 at 2:35 PM
    #299
    rruff
    rruff New Member
    The shock has nothing to do with leaf compression. The bumpstop should limit your max compression, and the shock length the max extension. At rest with no load, the shock does nothing.
  30. May 31, 2023 at 2:37 PM
    #300
    Jeremy323
    Jeremy
    2011 Tundra CM
    Im at a loss then as to why my leafs are compressed and the shackles are pressed back as if…..the shock isn’t long enough. I had to compress the leafs to get the shocks on.
