Do your fog lights jiggle? Try this.
Discussion in 'Lighting' started by Hoologan, Mar 17, 2018.
  1. Jul 16, 2018 at 10:47 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    Just put some behind the lip of the front edge. I cut the tape in a thin strip. Applied it just to one side.
    geno0506[QUOTED] likes this.
  2. Oct 15, 2018 at 6:51 PM
    zerch911
    zerch911 New Member
    San Antonio, Texas
    2016 Sky Silver Limited 4x4
    TRD Exhaust, 2018 Pro LED Lights, Bilstein Shock Leveling 6112 & 5160s, TRD Pro Color Matched Grill, Morimoto XB LED Fogs, 305/55/20 BFG KO2, Fuel Maverick Wheels
    Using the zip-ties mentioned above, I solved my shaky fog lights. I added a couple more zipties to make sure the lights stayed secure in the housing. I noticed they would try to rotate out when I tightened the zip ties. This solved that problem and I have zero movement now!
    NewImprovedRon and geno0506 like this.
  3. Oct 15, 2018 at 7:52 PM
    geno0506
    geno0506 New Member
    Michael
    I need to do that!
  4. Dec 7, 2019 at 10:24 AM
    easleycrawler
    Travis
    Easley, South Carolina
    2020 Limited DC 4X4 CEMENT
    Bumping this back up.
    I just replaced my halogen fog lights with oem led fog lights. Got them from a fellow member on here, got the lights and bezels. I noticed the light itself jiggled inside the bezel, zip ties took care of that part. The problem I've got now, is the whole bezel is pretty loose and moves around. I was able to pull bezel and all through the front of the bumper, installed LEDs and bezel is loose as hell, swapped my original bezel on new led, same thing. So, how can I get the bezel from juggling.
    On the driver's side, I went through the fender well, left bezel in place and just replaced light. No bezel jiggle.
    Just wondering why the bezel gets real loose after taking it out.
  5. Feb 7, 2020 at 11:20 PM
    m4sh33n
    m4sh33n New Member
    East Texas
    2019 Tundra TRD Sport
    BDS 7" Coilover Supsension Lift LEER 100XL Topper 20" Methods 37" Nitto Ridge Grapplers Amp Steps LED swapped every bulb in/on the truck
    This is far too common of an issue for Toyota to not do something about. I purchased my 2019 new in October and the fog lights were tight with no movement at all. 13k miles later and the entire bezel wiggles so much it almost falls out. There's got to be a better way to remedy this besides having to zip-tie a light housing on a brand new truck.
    easleycrawler likes this.
  6. Feb 10, 2020 at 10:56 AM
    tlpru
    tlpru New Member
    trent
    Southlake, Texas
    2016 Trd Pro
    added power mirrors, auto fold mirror, 2019 TRD head and FOG lights, FORTIN remote start, retrax tonneau cover, 18" fuel BFGK02, TRD sway bar, TRD intake
    yes, I have same problem..... even with the upgraded TRD RIGID fogs... they still jiggle
  7. Feb 14, 2020 at 4:14 AM
    Rustyscrew
    Rustyscrew New Member
    Rockledge,Fl
    15 Tundra Platinum
    TRD Front sway bar, TRD Rear sway bar, TRD red and blue shocks, 2018 LED headlights and fogs, TRD intake box lid, TRD air flow accelerator, AFE Super Stock Intake with dry filter, TRD radiator and oil cap, Radium PCV Oil catch can, StopTech SS brake lines, LED puddle lights, VLED interior lights, OEM metal oil filter housing, Fumoto oil drain valve, LED front turn signals, TRD Battery tie down.
    I bought those little blue clips. Went to install and noticed that they were already there from when I bought the oem led fogs so needless to say... still shaking
  8. Feb 17, 2020 at 1:25 PM
    chrisbusnut
    chrisbusnut New Member
    Pasadena, CA
    2020 Tundra Crew Max SR5 4x4 w/TRD Off Road pkg
    DiamondBack bed cover, SDHQ sliders, SwitchPro, Katzkin leather seats, TRD Pro grille, TRD Pro wheels w/Nitto Ridge Grappers, Toyota OEM leather steering wheel, SSO Slimline Hybrid Bumper w/Baja Designs S8 light bar, Warn Zeon Platinum 10-S winch, Baja Design rock lights & flush mount rear bumper lights
    Agreed. The TRD Pro Rigid fog lights seem to bounce around and it's pretty obvious when you are driving at night and have them on. Zip ties may be a good partial solution, however Toyota really should come up with a way to permanently address this. The blue clips with some rubber tape don't seem to work that well, and don't seem to have any effect on the loose bezels.
  9. Feb 17, 2020 at 2:44 PM
    multimile
    multimile New Member
    2020 Crewmax Cement
    Did this yesterday after swapping my BD squadrons into my 20'. I didn't really think they moved around much in my 17', but do like having some additional pressure holding them in. I think I finally figured out how to remove the splash guards without breaking the liner extension seal, only need to replace 1 this go around!
  10. Feb 1, 2022 at 11:46 PM
    rag9836
    rag9836 New Member
    Robert
    Riverside, CA
    2021 Tundra TRD Pro Crew Max
    275/70/18 BFGs, TRD Cold Air Intake, BRShine LED light swap, FRAC front camera, ESP Under Seat Storage, Rocky Mounts bike holder, tinted front driver and passenger.
    I have a 2021 TRD Pro and the Rigid fog lights bounce all over the place. There’s a ton of slop in them. Has anyone has a dealer solution… zip ties feels so weak.
  11. Feb 25, 2022 at 3:13 PM
    kevinrath
    kevinrath New Member
    Kevin
    2021 Lunar Rock Tundra TRD Pro
    295/70R18 Nitto Ridge Grapplers
    does your entire fog light housing shake or just the light itself? When I push up on the plastic bezel around the fog light, it moves up and down
  12. Jul 11, 2022 at 5:06 AM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    2021 Tundra CrewMax 4WD Limited Nightshade Special Edition MGM
  13. Jul 12, 2022 at 1:21 PM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    753920R010:
  14. Jul 12, 2022 at 2:34 PM
    PonyMan
    PonyMan Old Man
    Central, Louisiana
    Thank you @713Tundra!
  15. Aug 7, 2022 at 7:21 PM
    rocsteady
    rocsteady New Member
    Dave
    New Jersey
    2021 Super White SR7 Double Cab SX
    Just an FYI in case you think it'll work just fine to zip tire the one loop and then instead of going around the screw that holds it in, you use the lower "loop" on the side opposite the adjuster. Looks great. Right up until you don't check it before putting it back together and then because both zip ties are pulling in on the bottom of the lights... they, of course, point nearly straight down. I'll be pulling off the fender liner for the 237th time to correct my mistake.
