do you know what this button is?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pulido69, Sep 23, 2020.
  1. Sep 23, 2020 at 1:24 PM
    Pulido69
    Pulido69 [OP] Made in Texas!! Fight for what you love !!
    2016 black Tundra TSS off road
    I have a 2016 tundra tss off road. I found this button. Don't know what it does. Does anyone know what this is for? Resized_Resized_20200923_135614.jpg Resized_Resized_20200923_135614.jpg
  2. Sep 23, 2020 at 1:24 PM
    sotex
    sotex Sic 'em Bears!
    Jeff
    San Antonio, TX
    2020 White Tundra SR5 Double Cab 4x2 SX
    To calibrate TPS?
    zlaneb, HulkSmurf14 and Pulido69[OP] like this.
  3. Sep 23, 2020 at 1:24 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Thats the tire pressure sensors. Not sure how to use it tho
    Pulido69[OP] likes this.
  4. Sep 23, 2020 at 1:25 PM
    Pulido69
    Thanks
  5. Sep 23, 2020 at 1:25 PM
    Kung
    KG, VA
  6. Sep 23, 2020 at 1:26 PM
    Pulido69
    thanks
    Kung likes this.
  7. Sep 23, 2020 at 1:57 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    What about the 2nd picture? Sounds like a trailer brake controller but almost looks factory. Toyota offered that?
    Pulido69[OP] and FrenchToasty like this.
  8. Sep 23, 2020 at 2:00 PM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
  9. Sep 23, 2020 at 2:09 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    You press and hold it until the TPMS light blinks 3 times.
    I use it when I air down when I'm driving on sand to get rid of the warning, then again when I air back up.
  10. Sep 23, 2020 at 2:26 PM
    Medic343
    Medic343 5+4+3=2
    Kenny
    New Mexico
    '22 SR5 TRD off-road
    Set all the tires at the minimum PSI you want before the light turns on. Press and hold the button for 5 seconds the TPMS light on the dash blinks three times and it's set for that PSI.
    Rocko9999 likes this.
  11. Sep 23, 2020 at 2:28 PM
    Azblue
    The Dirty T ( ^_^)_且
    Yes, standard on all 5.7s 2016+.
  12. Sep 23, 2020 at 2:29 PM
    P-Factor
    P-Factor New Member
    Relearn Procedure when Resetting the Tire Pressure or after Rotating the Tires.
    1. Ensure all tires are inflated to the pressure listed on the tire placard.
    2. Apply the parking brake and turn the ignition to ON position with the engine OFF (not the ACC position).
    3. Hold down pressure warning reset switch (located under the steering wheel or in glove box) until the TPMS telltale light blinks three (3) times.
    4. It will take several minutes for the ECU to receive the signals from the sensors and complete initialization.
    Pulido69[OP] and panicman like this.
  13. Sep 23, 2020 at 3:14 PM
    KayakTundra707
    KayakTundra707 New Member
    Wrong, it's NOS!! Careful though, your floor pan might fall off when you press/use it lol.
  14. Sep 23, 2020 at 3:18 PM
    Kanobi13
    Kanobi13 New Member
    Passanger seat ejector
  15. Sep 23, 2020 at 3:26 PM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
  16. Sep 23, 2020 at 6:12 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    only works if you have a No fat chicks sticker tho
    Pulido69[OP] and Cpl_Punishment like this.
  17. Sep 23, 2020 at 6:15 PM
  18. Sep 23, 2020 at 6:19 PM
    Azblue
    Fat chicks need lovin too.
  19. Sep 23, 2020 at 6:19 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    thats the alternate sticker
    Azblue[QUOTED] likes this.
  20. Oct 5, 2020 at 5:47 PM
    Pulido69
  21. Mar 17, 2021 at 12:30 PM
    Pulido69
    Yes it was factory installed
  22. Mar 17, 2021 at 12:38 PM
    Kung
    KG, VA
    On second thought....maybe it's this button...
    WILLINH likes this.
  23. Mar 18, 2021 at 4:22 PM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    You didnt push it? No guts no glory...:yes:
    Cpl_Punishment likes this.
  24. Mar 18, 2021 at 4:27 PM
    ToyoMafia
    Magic carpet.
    Hopefully it’s not a button for a pickle injector. That gets uncomfortable.
    TILLY, Prostar 190 and jewsNbrews like this.
  25. Mar 18, 2021 at 4:48 PM
    :eek::itllbuffout:
  26. Mar 18, 2021 at 6:04 PM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
    Speak for yourself. I just upgraded mine
  27. Mar 18, 2021 at 6:08 PM
    HidetownRed
    HidetownRed Buffalo Hunter
    Top O Texas
    2020 Sky Silver Limited 4x4
    3/1 285/60/20 RG tint and red toes
    Ive been jammin on mine trying to make my tires into 295’s. Must be broke, I will ohm the switch out in the morning.
  28. Mar 18, 2021 at 6:17 PM
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Nice! Changing spring rates actually allows cucumber usage. We need a build thread for this.
  29. Mar 18, 2021 at 6:29 PM
    Makoy339
    Makoy339 Simplicity = Reliability !!!
    Super White TRD
    TRD parts
    That's the Balls Warmer button.
  30. Mar 18, 2021 at 6:36 PM
