Do you have a touchy gas pedal?
Discussion in '2nd Gen Tundras (2007-2013)' started by azimuth, May 16, 2022.
  1. Dec 18, 2022 at 5:52 AM
    MartinBlank
    MartinBlank New Member
    Bruce
    Loveland CO
    2008 Crew Cab Limited
    TRD Sway Bars, TRD CAI, Bilstein 5100's, LED's, plus LED rear Plate backup light, Aluminum oil filter housing, ECGS Needle Bearing upgrade.
    I had the same experience. While I didn't remove the shim in the original pedal, I did replace it with the 04000-0440C part. Drivability is better. Like you, I didn't fid this to be "dramatic" but it did help the "jump" off the line deal. I also installed the Banks Pedal Monster so I have the ability to adjust the pedal response as well. It works much better with the upgraded pedal than it did with the old one. The old one was just too touchy. Going through an intersection where the lanes were worn down, it would buck because the least little bit of throttle input would cause the truck to lurch forward. Much better now.
  2. Jan 24, 2023 at 5:26 AM
    rjspainhower
    rjspainhower Not so new member
    Utah
    2020 DC Limited Cement; 2007 RCSB 2WD SR5 Slate Metallic
    2020 Mods: Center console magsafe charger, rear seat cig port to USB charger, bullet bedliner 2007 Mods: New Head unit, Backup Camera, Trailer backup camera, Airbags, Airlift WirelessOne Controller, Rough Country 2 inch Leveling Kit Loaded Strust in front, N3 REAR SHOCKS
  3. Jan 24, 2023 at 5:58 AM
    jbrnigan
    jbrnigan New Member
    Midwest
    2007, 5.7L, 4x4, Crewmax,
    My original pedal had a shim installed by the dealer, and they may or may not have flashed the ECU???
    When I installed the replacement pedal, I did not have the ECU flashed.
    rjspainhower likes this.
  4. Jan 24, 2023 at 6:13 AM
    MartinBlank
    Bruce
    Loveland CO
    I did not have the ECU flashed either. I just replaced the pedal. I did notice that my old pedal had the shim, so at one point the dealer had modified it per the TSB. I did not see any need for the flash of the ECU, the new pedal is much better than the old one.
  5. Jan 24, 2023 at 6:27 AM
    rjspainhower
    Utah
    @jbrnigan @MartinBlank Thanks guys that is the exact information I needed. The jerkiness has been bothering me and when I pull my trailer my wife thinks I can't drive so I'm looking forward to having a smoother pull and this very well may save me from having a car sick wife!
    I went ahead and click the purchase button on the 04000-0440C part, when it arrives and I swap it i'll report back.
    FreemanHunter61 likes this.
  6. Jan 24, 2023 at 7:55 AM
    RichBarr2600
    RichBarr2600 New Member
    2010 Tundra crew cab
    i upgraded to the new pedal 04000-0440C part, it helped with take off not being so jumpy. before it felt like a runaway stallion, now it feels like a stallion under the controls of the reins.
    I wont say it was dramatic change, but noticeable.
  7. Jan 24, 2023 at 8:18 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    On the older trucks, I think that there was an ECU flash to update so that if the throttle was open, a brake application would cut power. Possibly part of that runaway vehicle settlement thingy.
  8. Jan 25, 2023 at 7:10 PM
    tyr0981
    tyr0981 New Member
    07 TRD Tundra 5.7
    Head unit, sub's , components, front / back camera's, too many lights to mention, dual battery, winch / bumper, TRS projector headlights, roof nest hard-shell, integrated backup spot lights, vault, all aluminum radiator / water pump, tailgate storage, plenty of dents and scratches
    Huh that was informative read! i also read somewhere it was 50/50 replacing the pedal would be better or not :annoyed:. so I spent ~180$ on a pedal controller that plugs in-line with the peddle cable, there's 4 different modes on it, from HOLY SH:eek2:T! to "eco mode" which didn't save me any MPG... Putting her into 'Ultimate' and turning on the tow haul = Traction Controller never off :militarypress:
    I-Drive system
    https://www.ultimate9.co/evc-thrott...vWHP7ZRVmnslH_XR6EgZlzsHD9ZEob6UaAuJtEALw_wcB
    MTRock and RobertD like this.
