Do you change your own oil in your Tundra?
Discussion in '3rd Gen Tundras (2022+)' started by tstex, Jan 27, 2025.
  1. Feb 18, 2025 at 6:53 AM
    #151
    tstex
    tstex [OP] New Member
    Houston & Colorado County TX
    2024 Silver Tundra TRD
    I have come to the realization that the smaller, independent auto shops that knew each of their customers well and took pride in their wk, is not what lg dealerships embody. They're paid bonuses if they can squeeze in extra jobs/hr. Oil change "tech's" are the newest and first rung on the skill chart and do so many, by the law of avg's alone they are going to screw up. You just don't want it to be your vehicle
    When I changed my oil, I let both engine & filter drain for an hr+ while i did other things. I thoroughly cleaned the funnel/hose drain nipple. I covered the engine cover w a towel just incase i spilled any oil, but i did not, i also added exactly 7.7 qts & dip stick was rt on the money. I put a piece of cardboard under oil change area over night snd no drips. All bolts torqued to specs. Did the same thing 25 times every 5K w my F-150.. never an issue.
  2. Feb 18, 2025 at 7:02 AM
    #152
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Exactly. You'll never get that level of detail at a dealership. An oil and filter change is a "get it in, get it out, go on to the next one" job for the rookie techs that may or may not give two shits about doing it right. Only fast.
    Tom976 and Raven67 like this.
  3. Feb 18, 2025 at 9:18 AM
    #153
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    So do you all still take your trucks in for a tire rotation and the other free inspection items? Or do you just go through the list yourselves and document?
  4. Feb 18, 2025 at 9:22 AM
    #154
    Tom976
    Tom976 New Member
    Tom
    i have a basic excel spreadsheet for the cars i maintain.
    When i do my oil changes I snap a few pics of the job.
    Want proof of me doing the oil change? No problem.
  5. Feb 18, 2025 at 9:30 AM
    #155
    tstex
    If they want proof of my oil changes, they can come to my ranch and see the old oil filters, used synthetic oil and cases of both new oil
    & new oil filters i bought from them (the dealership)
    i take the old oil filters and place them upside down on my larger (barbed-wire) end posts. This treats them from splitting & rotting over time. When the filter is empty, i fill it up again & repeat.
  6. Feb 18, 2025 at 9:34 AM
    #156
    Retroboy1989
    Northern Utah
    Yeah, I'm keeping my oil receipts along with my own spreadsheet including date and mileage.
    I'm more curious about the other, inspection items.
  7. Feb 18, 2025 at 10:49 AM
    #157
    BlackNBlu
    Rich
    MN
    No and yes. For the same reasons I do my own oil changes.
    If I had a dealer close to home, and if I trusted said dealership's service department, I would consider it. Maybe.
    My own service department is as close as my garage, has nights and weekend hours if convenient, and I never have to worry if it was done right. :thumbsup:
    Tom976 and ScottieBones like this.
  8. Feb 18, 2025 at 11:23 AM
    #158
    Twin2turbo
    Twin2turbo New Member
    Pacific NW
    2023 Hybrid MGM Platinum
    I would like one too when you have the time.
    TIA[/QUOTE]
    Please send me the file. Thanks!
  9. Feb 18, 2025 at 12:48 PM
    #159
    ScottieBones
    ScottieBones New Member
    NC
    2025 Limited 4x4 TRD OR
    Me as well, thanks!
  10. Feb 18, 2025 at 2:11 PM
    #160
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    It’s all there and snug. Haven’t seen drips in the driveway.
  11. Mar 3, 2025 at 8:05 AM
    #161
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I have twice added half a quart to my engine in 8500 miles. I changed it at 5000 and I'm not alarmed but in my experience with new vehicles this is unusual. Has any one else noticed this?
  12. Mar 3, 2025 at 8:08 AM
    #162
    Retroboy1989
    Northern Utah
    I don't have enough miles on mine to say.
    My 5.7 tundra didn't use a drop.
    That said, half a quart over an average of 4250 miles is low consumption. I suspect Toyota would consider it normal.
  13. Mar 3, 2025 at 8:11 AM
    #163
    tstex
    Have you seen any oil spots under your truck? Put a large piece of cardboard under your truck that covers both the oil-pan bolt and oil filter and see if it is leaking. Other than that, if youre not blowing a lot of smoke, I cannot see you using that much oil, unless your towing something 7x24...let us know?
    ScottieBones likes this.
  14. Mar 3, 2025 at 8:21 AM
    #164
    ScottieBones
    NC
    What prompted you to add more? Were you watching the gauge, checking the dip stick? Neither is very precise for tracking oil level, much less consumption.
    Edited: quoted wrong post
  15. Mar 3, 2025 at 8:22 AM
    #165
    AZBoatHauler
    So.Arizona
    Gauge?
    Ausfahrt likes this.
  16. Mar 3, 2025 at 8:27 AM
    #166
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    It's been noted here that the oil level is difficult to accurately determine. I let my truck sit on a level surface with the dipstick out for at least 15-20 minutes and then check it. If you leave the dipstick in, the residual oil in the dipstick tube can result in false readings.
    Anyway. I am going to monitor it more closely going forward and hopefully it was just an anomaly or error on my part.
  17. Mar 3, 2025 at 8:28 AM
    #167
    ScottieBones
    NC
    Not sure if it's exclusive to the full digital gauge cluster, but I have a oil level indicator
    Edit: indicator is for oil pressure, not level
  18. Mar 3, 2025 at 8:35 AM
    #168
    BlackNBlu
    Rich
    MN
    Someone please post a pic of this.
  19. Mar 3, 2025 at 8:37 AM
    #169
    Ausfahrt
    Ausfahrt New Member
    Vermont
    2024 SR5 4X4
    I agree and I may have slightly underfilled it when I changed the oil.
  20. Mar 3, 2025 at 8:46 AM
    #170
    ScottieBones
    NC
    To the right of the ODO
  21. Mar 3, 2025 at 8:47 AM
    #171
    AZBoatHauler
    So.Arizona
    99% sure that’s for oil pressure - not level.
  22. Mar 3, 2025 at 8:49 AM
    #172
    ScottieBones
    NC
    If so, my bad!
    Looks like you are correct. Added a note to my post
  23. Mar 3, 2025 at 8:50 AM
    #173
    tstex
    Yes, there's nothing that provides the exact oil level, only if your oil level becomes really low, then the light will indicate so.
  24. Mar 3, 2025 at 9:03 AM
    #174
    Retroboy1989
    Northern Utah
    Glad to know I am not the only one who has noticed that checking the oil in this truck is tricky. The oil really gets dragged up the dipstick tube. If you check the dipstick more than once, the readings are garbage.
  25. Mar 3, 2025 at 9:07 AM
    #175
    ArcticEd
    ArcticEd New Member
    Jacksonville
    '24 Plat Hybrid Crewmax 6.5 CSM
    I changed the oil at 1k & 5k with zero issues, and had the dealer do it at 10k (lifetime warranty on the engine if you have dealer do changes). Went to change it at 15k yesterday (I plan to do every other 5k) and couldn't get the filter off. They must have tightened it down with a wrench. Had to order a different filter wrench & hope it will remove it. I hate letting the dealer change the oil.
    Tom976 and Ausfahrt like this.
  26. Mar 3, 2025 at 9:22 AM
    #176
    Retroboy1989
    Northern Utah
    What?? I thought the engine was 5yrs unless you buy a Service Agreement?
  27. Mar 3, 2025 at 9:32 AM
    #177
    oddhours
    oddhours AS IS
    Barry
    Georgia
    24 SR10
    Probably something his dealer does.
  28. Mar 3, 2025 at 9:39 AM
    #178
    Retroboy1989
    Northern Utah
    Regardless, I'll take the two freebies then document my DIY. I am keeping my oil receipts and the lid from the OEM oil filter box.
    660 Miles - Complete
    2,000 Miles
    5,000 Miles
    10,000 Miles - Dealer
    15,000 Miles
    20,000 Miles - Dealer
    25,000 Miles
  29. Mar 3, 2025 at 12:26 PM
    #179
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Just an FYI. An old chunk of garden hose works perfectly for the anti-spill pan under the oil filter.
    ScottieBones and 22whatwedo like this.
  30. Mar 3, 2025 at 12:39 PM
    #180
    ArcticEd
    ArcticEd New Member
    Jacksonville
    Yep, it was from the dealer
