Do these maintenance costs seem high?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 2015TundraCrewXP, Aug 7, 2019.
  1. Aug 7, 2019 at 8:40 AM
    2015TundraCrewXP
    2015TundraCrewXP [OP] New Member
    Charles
    SC
    2015 Black Tundra Crew Max XP
    20" blacks wheels, trd pro grille, color matched fender flares and handles, steel rear bumper, black leather, bakflip cover, spyder led headlights
    My 2015 is about to hit 100k. I bought the truck in Oct 2018 with 68k and haven't done anything but oil changes, new battery and brakes. No other fluid changes. I asked a local shop to quote me on all fluids as well as spark plugs. Seems high to me. thoughts?
    1. spark plugs : $330.
    then they are also saying I should/need this: Is this a good thing to do or need to be done?
    BG Fuel/Air Induction Service ***Performed with spark plug replacement***
    Connect equipment to fuel delivery system, add chemicals to clean system contamination. Fluid additives and/or conditioners may be
    required to complete system service. Leak test vehicle system. Perform final road test where applicable. BGKF65-N1TD - Fuel Injection System Kit BG 4073 - Mass Air Flow Sensor Cleaner
    $185.00
    1. coolant exchange : $130.00
    2. power steering fluid : $115.00
    3. front and read diff fluid exchange : $125/ ea = $250 total
    4. transfer case fluid exchange : $110.00
    5. transmission fluid change : $230.00
    Parts
    $636.83
    Total Labor
    $711.67
    Total Before Taxes & Miscellaneous Charges
    $1,348.50
    (*) Shop Supplies
    $23.99
    (E) Environmental Fee’s
    $24.99
    (S) Sales & Use Tax
    7 %
    $44.58
    GRAND TOTAL : $1442.06!!
  2. Aug 7, 2019 at 8:52 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Here is my take on the pricing:
    1. spark plugs : $330. - Outrageous, I changes these myself with OEM part for $60 and an hour of my time.
    $185.00 - Not sure, might be worth it. Do you run a lot of ethanol gas?
    1. coolant exchange : $130.00 - Reasonable
    2. power steering fluid : $115.00 - Crazy!
    3. front and read diff fluid exchange : $125/ ea = $250 total - Too high, did this myself for $40 each and and hour of my time.
    4. transfer case fluid exchange : $110.00 - Outrageous, did this for $20 and 20 minutes of my time.
    5. transmission fluid change : $230.00 - Reasonable
    Y0TA PR0, blizz86, Black Wolf and 2 others like this.
  3. Aug 7, 2019 at 8:53 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    A bit high for my blood!!! I might be in on about half.......
    You can probably do all of these yourself for a fraction of that.
    kenomouth64 likes this.
  4. Aug 7, 2019 at 8:54 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    All the fluid is easy easy easy. Don’t pay them exorbitant rates
  5. Aug 7, 2019 at 8:56 AM
    kenomouth64
    Tetrus
    I would say including parts, labor, fees, Tax, all of this should not exceed $1000. Should be between $850-$1000.
  6. Aug 7, 2019 at 9:10 AM
    Trooper2
    JR
    Have heard good things about BG products. IMHO, if its running fine then not interested. I am always leary of "Up selling" services like this. Most likely a big money maker for them.
  7. Aug 7, 2019 at 9:12 AM
    LML 3500HD
    This^^^
    kenomouth64[QUOTED] likes this.
  8. Aug 7, 2019 at 9:45 AM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    I would let them do front and rear diff, super messy. Everything else is a easy garage job and they're charging way too much. I live by a rule, get 3 quotes. At least you'll know you're paying industry standard for any services you're receiving. Email or call that list of services, without prices, to two other shops and see what they say.
  9. Aug 7, 2019 at 10:35 AM
    RussellVaughan
    RussellVaughan New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    pay for the transmission drain and fill. it's too complicated to do it correctly.
    I haven't done coolant yet, but in general coolant is usually an easy task.
    everything else is VERY easy. differentials and transfer case are even easier than an oil change. hell, you don't even need to measure anything. you just make sure the truck is level and you keep pumping until you get some coming out the fill hole.
  10. Aug 7, 2019 at 11:14 AM
    Openroad98
    Openroad98 New Member
    Abraham
    Loveland, CO
    2019 Cavalry Blue SR5 TRD
    Stock for now...
    So as a service manager for an independent shop, I’m a little biased of course. I will say I don’t know the labor rates or going rate for shops in SC, but in CO our our hourly rate is $128 and that is very normal in the Fort Collins area.
    That said, the spark plugs do seem high although it’s likely the markup on OE plugs which are expensive.
    The BG ink/induction service is kick@$$, I strongly recommend it with the so-so fuel we find at most pumps, and that is $30 less that we charge for it.
    I don’t want to confuse things, so if they are offering BG Coolant Svc, BG power steering fluid service and BG transmission fluid service, those are good prices. Doing it yourself you won’t get the same result at all and it is a lot messier. I’ve done coolant and PS fluid at home and usually you won’t get s full exchange of fluids or the cooling system and PS system cleaners that are added prior to servicing.
    That said, I do most of the mechanical work on my own vehicles (but not fluid Svcs) for much less as most of those are labor intensive. Parts and taxes for the above quote you’d be around $700... so how handy are you?
    Not sure if the shop told you, but any vehicle under 100K that has BG Svcs performed is automatically enrolled in their Lifetime Protection plan. As long as you perform the fluid services every 30K you’ll have coverage up to $2,000 on the cooling system, trans, and PS components. Nice backup once your cruising past the 100K mile range.
    Not trying to sway you one way or another, but those prices aren’t out of line FOR a reputable shop, but you can ALWAYS find a cheaper shop... it’s up to you and your skill level and time available.
    #rantmode And my personal beef after years in the industry, not directed at you but in general: don’t b!tch about pricing WHEN you’re comparing DIY pricing to a shop, both are viable options but don’t compare them and demand the Saturday-garage pricing from a shop.
    I agree with @JimboSlice, get several quotes!
    Luckydog and Blueknights75 like this.
  11. Aug 7, 2019 at 11:17 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    The diff change isn’t messy. It has a drain plug
    irhunter, lewi3069 and RussellVaughan like this.
  12. Aug 7, 2019 at 11:20 AM
    Openroad98
    Abraham
    Loveland, CO
    Stock for now...
    Agreed, diffs and t-case are simple. That’s why I specified PS and trans as the messy ones. And that quote shouldn’t be for a drain and fill, should be a full trans service fluid exchange.
  13. Aug 7, 2019 at 11:28 AM
    RussellVaughan
    Houston
    i see this said a lot regarding transmission fluid changes on the tundra. the Toyota specified transmission service is a drain-and-fill NOT a flush. i would not flush the transmission, especially if Toyota isn't telling us it needs to be done. the other item - the drain-and-fill process on the tundra is not simple. its time consuming and complicated. i researched it because I try to do all my servicing myself. i paid $229 at the dealership for mine.
    irhunter and Openroad98[QUOTED] like this.
  14. Aug 7, 2019 at 11:34 AM
    Trooper2
    JR
    The drain and fill process is fairly easy. Measure the amount removed and replace with same amount. Recently did this, having the needed supplies makes it no more difficult than an oil or diff change.
    The level check is not that simple. I did not attempt, felt very certain that the same amount went back in.
  15. Aug 7, 2019 at 12:54 PM
    2015TundraCrewXP
    Charles
    SC
  16. Aug 7, 2019 at 12:56 PM
    2015TundraCrewXP
    Charles
    SC
    This shop is a great place but I feel like their prices have started to creep up. I’m def going to get at least 2 other estimates. Any national chain recommendations?
    There is a small”good ol boy” Toyota shop that has fantastic reviews 10 min from me. I’ve never used them but when I called today to ask he said these fluids last well beyond the mileage recommendations to change and that he goes by look, smell, texture. He mentioned most of the time fluid changes are a money grab at the recommended mileage. He didn’t want to quote anything until he sees the current state of he fluids in my truck. Pretty honest place if you ask me.
    I know i could do it myself but just not sure I want to deal with buying the right tools, supplies, and then disposal. Could be a fun thing to learn to do though. You tube is great for this type of thing.
    irhunter and Openroad98 like this.
  17. Aug 7, 2019 at 1:19 PM
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    BG is good stuff but not necessary if the truck runs well. Buy some BG44K online and put it in your gas tank for clean up or preventive maintenance . I am in strong favor of using Toyota antifreeze. When I worked for Toyota most cars and trucks with blown headgasket had aftermarket antifreeze. All the best.
  18. Aug 7, 2019 at 1:58 PM
    rustynail11
    rustynail11 New Member
    Scott
    Mansfield,TX (DFW Area)
    2017 Grey Tundra TRD
    The price on the differentials is the one that always makes me laugh. It is easier than changing your oil and can be done by you in lass than hour for less than half the price.
    RussellVaughan and kenomouth64 like this.
  19. Aug 7, 2019 at 3:56 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Is it a good idea to push cleaning chemicals through the trans or are they just making stuff up? Trans fluid has a ton of cleaning properties. It doesn’t get dirty, as there is no explosion happening in the transmission. It just is broken down mechanically from heat/friction
    RussellVaughan likes this.
  20. Aug 7, 2019 at 4:09 PM
    Heeler13
    Heeler13 21MGM
    Eastern NC
    2021 Sr5 XP
    Bilstein 5100 Front @ middle setting Bilstein 5100 Rear @ stock height Oem older Pro wheels 285/75/18 Maxxis Razr a/t
    This is a pretty typical cost analysis if you're taking it to a Toyota dealer. I know, i work at a dealer. Now for an independent shop, this quote is high.
  21. Aug 7, 2019 at 4:10 PM
    Y0TA PR0
    Y0TA PR0 Dirt biking & fishing
    Rafael
    2017 TRD PRO
    @ARamirez73
  22. Aug 7, 2019 at 5:34 PM
    Openroad98
    Abraham
    Loveland, CO
    Stock for now...
    I would say after seeing enough GM and Ford trucks and SUVs coming in at 90-120K miles with moderately dark fluid and bearing/drivetrain noise and issues that I’m a stickler for mileage based maintenance even if the fluid looks “ok”. That’s how I’ve done it with my wife’s 2014 Honda pilot, time will tell as I hit the 200,000 mile mark (only have 81k so far). I would say most mileage based services are designed to prevent issues 75k or 100,000 miles down the road, not immediate gratification like brakes or tires. But it’s also for a specific type of person, and one that plans to keep their vehicle awhile
    SouthBoundSteve likes this.
  23. Aug 9, 2019 at 8:43 AM
    2015TundraCrewXP
    Charles
    SC
    Maybe these prices are not that far off. Second quote I got from AAA car care was 1432.00.
    Openroad98 likes this.
  24. Aug 9, 2019 at 9:31 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Dude how much was the truck? Think of what % of the cost of the vehicle these things are? I would keep shopping around if you really want to pay someone to do the stuff
  25. Aug 9, 2019 at 4:23 PM
    Openroad98
    Abraham
    Loveland, CO
    Stock for now...
    I agree with your post, but would probably take it in a different direction. For a $45,000 truck to cost $1400 at 100K miles is very reasonable if you ask me, it’s about 3.2% of initial purchase for the main “big service” that won’t be needed again for a long time. If there’s no value in that, then I guess we disagree. Also, these trucks don’t have “usually” a major out of service breakdown before that 100K Svc. Don’t overpay or waste your money, if you can get it done well by a reputable shop for $1050, awesome! But it that is the price in your area, I’d say it still has value...!
  26. Aug 9, 2019 at 4:28 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Agreed. I should have specified that i don’t consider this particular list big money preventative or repair work.
    If someone is scared to do there own brakes, then absolutely it is worth the labor to pay a shop for example.
  27. Aug 9, 2019 at 5:24 PM
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    The level check is easy too. Its complicated if reading service manual instructions, as it makes it appear like 30 steps. Literally takes 2 min to get er done.
    Exchanged 13qts of trans fluid with Amsoil at 150k miles. Glad I did cause the stock fluid looked like shit.
    kenomouth64 and Openroad98 like this.
  28. Aug 13, 2019 at 12:18 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Shops will have a markup for parts and labor. I did most of those myself. Not including spark plugs and the fuel/air induction service, I paid maybe about $500 in fluids and I still have a ton left over for the next service. Granted, I'm not buying OE fluids, they are pretty highly regarded based on what I was able to find.
    Coolant fluid = Zerex Red Asian Formula
    Transfer case and Diff = Mobil 1 75W-90
    Transmission and Power steering fluid = Valvoline Maxlife ATF
    I still have to do the brake fluid. I had a can of mass air flow cleaner so I just took it off and sprayed the MAF, let it dry and reconnect. Did the same for throttle body with throttle body cleaner I'm an amateur wrencher and did most of these over the course of a few weeks, only spending a day a week. And by a day, more like 3-4 hours max. I'm sure I could have tackled it all in a weekend but both kids are home on the weekends which severly limits my availability. Just watched a lot of youtube videos and felt comfortable doing it myself.
    Power steering fluid is one of the easiest ones to do. Just get a suction gun and suck that fluid out. Replace with new fluid, rotate the steering wheel and rinse and repeat if you'd like, or just do it again every oil change.
    Another thing is greasing the driveshaft joints. Easy job after you have the grease and grease gun.
    I understand that not everybody wants to wrench and I certainly didn't with my BMW X5. I paid out the @$$ for an independent mechanic to change all the fluids and fix oil leaks. After that, I decided I was not made of money and will be doing it myself going forward.
    Trooper2 likes this.
  29. Aug 16, 2019 at 6:42 AM
    Twheatley32
    Twheatley32 New Member
    Vermont
    '23 Limited - Crewmax - JB4 Tuned
    I'm looking at your invoice....They put 75W-140 in your front and rear diffs.....Toyota recommends 75-85 Fluid......I'm no fluid expert so maybe the 75W-140 is fine???
