Do I need to add a diff drop kit?
Discussion in 'Suspension' started by bigoltater, Nov 15, 2016.
  1. Nov 15, 2016 at 5:05 PM
    bigoltater
    bigoltater [OP] New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    I just picked up a pro suspension, I will be installing on my limited crewmax. I would like to add 2 CB shims which will add 1 inch. Two questions
    Will a TRD Pro skid plate fit with the shims and diff drop kit?
    Thanks for the info.
  2. Nov 15, 2016 at 5:35 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    @Coachbuilder1 can answer with more certainty.
    Should not require the drop kit with 2 shims so the skidplate is a non issue
    What did you give for the pro parts?
    veg hed likes this.
  3. Nov 15, 2016 at 5:58 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    $1000 for front and rear.
    veg hed likes this.
  4. Nov 15, 2016 at 6:06 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    You don't NEED a diff drop but I would recommend it, especially for how much they are. Nice peace of mind.
    The skid plate should fit but someone else will give you a certain answer.
    Law323 likes this.
  5. Nov 15, 2016 at 6:16 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    I agree with the Capt. It is a inexpensive piece of insurance. It drops down the whole front diff and relieves the stress on the drive train components. I have the 5100s at top setting with no shims for a total of about 2-3/8" lift. For $40.00 it's well worth it. Good luck with the truck.
    geno0506, Law323 and CaptTyler like this.
  6. Nov 15, 2016 at 7:32 PM
    veg hed
    veg hed Thug
    Utah
    2016 Ta-Tundra Barcelona Red
    I did NOT do the diff drop on the front when I did the Pro suspension swap; 2 shims on each side up front and the +3 shackles in the back. I did the diff drop kit on my Tacoma when I raised it about 2-3" and the CV boot fins still rub. So I have mixed feelings about front diff drops. Especially if you're only going 1" above the factory Pro set up.
    However, when I bought my stuff from @Coachbuilder1 the kit he sent me came with a "bearing drop kit". I think that was what it was called but someone correct me if I'm wrong.
    I also put a Pro skid plate on mine. If I had to choose between a front diff drop and Pro skid plate it would be skid plate all the way!
  7. Nov 15, 2016 at 11:58 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Great info thanks fellas
  8. Nov 17, 2016 at 12:25 PM
    Tundracm16
    Tundracm16 New Member
    Southwestern pa
    2016 tundra crewmax trd
    Trd exhaust, trd sway rear sway bar,spray in bed liner, fold a cover,tint
    When I did my 2-1 level I had them send me the diff drop figured it wouldn't hurt. After a hour of messing around trying to get it on I realized why most say you don't need it under 3 because it's impossible to get on. I don't think just 2 raises everything enough to get the drop right that's why I could get it to work. So I don't have it on. I checked the boots and everything after a 3k road trip and everything looks good so I'm not worried about it. Checked out a buddy's pro and factory didn't drop it angle it about the same as mine giving the fact mine sits almost a inch higher than pro
    geno0506 likes this.
  9. Nov 17, 2016 at 2:44 PM
    FlashCulprit
    FlashCulprit ColoradoTJ's whipping boy/Gino's illegitimate son.
    Joe
    Salt Lake City, UT
    2010 Super White SR5 TRD 5.7 4x4
    2nd'ed if anything it's reassurance when you're on the beaten path.
  10. Nov 17, 2016 at 4:09 PM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    @bigoltater please text/call David Ekstrom (Coachbuilder1) at (801) 635-4872. I'd bet he'll recommend a front diff drop.
    The pro suspension raises the front of a "stock" Tundra 2". Two CB spacers raises it 1" more - as you've stated in Post #1.
    The consensus here and on other forums seems to be that you should drop the front diff if you're going above 2.5".
    The bearing drop kit mentioned by @veg hed - included with his CB +3" rear spring shackles - is for the carrier bearing. It improves drive shaft/rear diff alignment when longer than +1" shackles are installed. Consequences of not installing it are usually felt as driveline vibration under acceleration. I hope veg hed installed his.
    Probably missing from your Pro Suspension is this:
    http://parts.toyotaofcoolsprings.com/oe-toyota/ptr1334140ab
    It's a spacer for the speed sensor wire. See attached pdf for the instructions for the whole suspension kit.
    Step 3 and Fig. 3-1 talk about the spacer.
    The Pro Skid Plate fits very close to the suspension/frame/front diff. With a diff drop, I doubt you'll be able to install it. I recently saw some posts or a thread about this, either here or on Tundra Talk, but can't find it right now. Sorry.
    Best luck with you're mods!
  11. Nov 17, 2016 at 7:59 PM
    veg hed
    veg hed Thug
    Utah
    Yep. I put it on it took about 5 minutes.
  12. Nov 20, 2016 at 9:42 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Thank you for the info and the heads up on the spacer!!! I would have never known!!!
    jburson250[QUOTED] likes this.
  13. Nov 20, 2016 at 10:51 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    You'll know by looking at your cv angels if you need the diff drop. I could see it when I lifted my front and I'm no genius. Also, I've seen skid plate spacer kits so you can keep your skid plate w/ the diff drop.
  14. Nov 21, 2016 at 8:55 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    General consensus seems to be, anything over 2 inches and a diff drop is called for. The TRD skid plate can be used with a diff drop with some minor modifications. specifically, you need to either extend the 3 spacers and bolts on the middle row, or as I did, just leave them off. The plate will flex around the diff drop using the front and back rows of bolts.
