Do I need a leveling kit?
Discussion in 'Suspension' started by Bluemonster, Mar 30, 2017.
  1. Mar 30, 2017 at 3:29 AM
    Bluemonster
    Bluemonster [OP] New Member
    Paul
    2015 Tundra SR5 4x4
    Hi new to the Tundra Family. I just bought this 2015 Tundra SR5 4x4 blue monster and was wondering if I should put a leveling kit on it?
    If so, how high would it have to be to match the back? Trying to figure out how to upload a photo so you all can see. Any thoughts?
  2. Mar 30, 2017 at 5:37 AM
    Bienvenidos de Tejas! Sweet rig check out toytec.com
    15whtrd likes this.
  3. Mar 30, 2017 at 6:05 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Welcome to the forum.
    If you are wondering if you should level your truck, then don't.
    It's not necessary for you to level your truck. If you level it, you do have to do something to rear end since your truck will squat with a moderate load. Steering rack going out seems to be more common with lifted/leveled trucks. You mpg will go down, even without any change of tires/wheels. People level their trucks primarily because they like to upsize their tires and secondarily (I think) they like the look. But if none of these matters to you, leave it stock. Toyota did an excellent job in streamlining their vehicles.
  4. Mar 30, 2017 at 6:20 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toytec all the way.
    Haven't heard much if ANY on steering racks going out on 3" and under. I may be wrong.
    BUT racks have gone out on stock tundras too. It's not just leveled tundras.
  5. Mar 30, 2017 at 6:23 AM
    r4z0r51o
    r4z0r51o have fallen off the forum, but I’m still alive.
    Dave
    Northeast San Francisco Bay Area
    2016 Silver Sky Metallic Crewmax 5.7L TRD 4x4
    22x12”HostileRage/33”NittoRidgeGrap/StealthFighter/FOX-BDS
    Well said ... and agreed upon. Unless your planning on changing your wheels and tires, I'd do what Chphilo said.
    If you just want to spice it up a bit without going crazy, may I suggest some 1.25" spacers to push the wheels out. It will make a huge difference in how your Tundra will look.
    joonbug likes this.
  6. Mar 30, 2017 at 7:47 AM
    mad4sax
    mad4sax New Member
    Tom
    I thought I was the only one on this forum that likes the look of the stock stance better than leveled.
    :thumbsup:
    joonbug and gosolo like this.
  7. Mar 30, 2017 at 8:42 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Welcome! You know the old saw....If you have to ask....
    Figure what your style and needs are first, and then plan your mods accordingly. Do a lot of night driving? Headlights first. Use your truck as a storage shed? consider a cover. Like to off road? start with the suspension. you get the idea.
    TundraDude18, 15whtrd, Law323 and 2 others like this.
  8. Mar 30, 2017 at 8:46 AM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Welcome!!!!
    Leveling out is a good option if you are looking for a more aggressive stance or wanting to put larger tires under your truck.
    What is the truck used for? is it for looks or is it being used heavier for towing or wheeling at?
    PaRunnerd, Law323 and GNTundra like this.
  9. Mar 30, 2017 at 10:12 AM
    Bluemonster
    Paul
    2015 Tundra SR5 4x4
    Just for looks. I hate how it looks like it nose dives in the front.
    SouthBoundSteve and Law323 like this.
  10. Mar 30, 2017 at 12:43 PM
    chphilo
    Western PA
    In that case, I would say that you are not wondering about the leveling kit, haha.
    Avoid spacer leveling kit. About 2 inches will make most Tundras level, it seems. Bilstein 5100 is a good option and also budget friendly. The sky is the limit on how much more you want to spend on suspension.
    15whtrd likes this.
  11. Mar 30, 2017 at 6:13 PM
    Fly'n Family
    Fly'n Family New Member
    TX / CO
    2014 CM Limited
    I went with 5100's, probably the least expensive way while still accomplishing the goal and improving the ride. I had mine set to the mid setting, leaving a little rake in. Rake is in their for a reason, just like sports cars - so I went with a happy medium of leaving a little while lifting at the same time.
    A lot depends on use. If you're going to be towing anything that has some weight, I would leave it alone. If not - do whatever is visually appealing and meets your performance needs. If I wasn't cheap - I would have gone with the Toytec Boss - that's an awesome kit.
    Here's mine with description in siggy...
    KELZ84, MakMurph and Law323 like this.
  12. Mar 30, 2017 at 9:17 PM
    Maddsilence
    Maddsilence New Member
    2017 MGM SR5 Tundra
    I think a 2" would be perfect to level out the looks. Bilsteins seem to be the ticket.
  13. Feb 4, 2019 at 2:29 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    @Fly’n Family what side tires are you using?
  14. Feb 6, 2019 at 4:50 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    2019 Tundra TSS SR5 8W2
    Bilstein 5100 3/1 Pro Comp 1" Blocks, 12Volt Remote start.
    So I assume that adjustable shocks would be better than spaces up front for leveling? I’m thinking about doing the same thing and I already have bigger tires on mine.
  15. Feb 6, 2019 at 5:09 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
  16. Feb 6, 2019 at 5:17 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    I have Yokohama Geolander 275/65/18’s
  17. Feb 6, 2019 at 5:33 PM
    Iowa12tundra
    Iowa12tundra New Member
    2012 tundra crew
    I'm new to this but isn't that size stock?
  18. Feb 6, 2019 at 5:35 PM
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    I have 285/55/20, i want to go taller especially after i get the Bilsteins in the front 2.5”
  19. Feb 6, 2019 at 5:48 PM
    Jsnake89
    Jsnake89 New Member
    Dane
    Stock on mine was 275/55/18, and I mistyped I have 275/70/18’s plus my wheel offset is +1
