Do 275/70/18's make my truck better at truck stuff?
Discussion in 'Wheels & Tires' started by ND_Porkchop, Apr 18, 2019.
  1. Apr 18, 2019 at 2:14 PM
    ND_Porkchop
    ND_Porkchop [OP] New Member
    2008 Tundra 5.7 CM DSM
    I have stock size (275/65/18) E rated wrangler adventure Kevlar that were on the truck when I bought it.
    I am not planning on lifting in the immediate future(not in the next 2 years) but will need tires in the next 12 months.
    I've read that 275/70's fit without leveling.
    My question is, tire model being equal, are 275/70's going to make a positive difference in navigating off road mud, ruts, hills etc or positive enough to justify the MPG loss...or are they mostly for looks?
  2. Apr 18, 2019 at 2:17 PM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    95% looks if you have E rated tires already, but 275/70/18 may actually be slightly cheaper too
    Edit: I wouldn't expect you'd lose much in the way of MPG that wasn't already lost from switching to the E rated 275/65/18
    ND_Porkchop[OP] likes this.
  3. Apr 18, 2019 at 2:44 PM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    I bought the falken wildpeak at3w a couple months ago in 275/70/18 load range E. I paid $788 out the door mount and balance. I have no lift on my truck and there was no rubbing anywhere. I lost about 1mpg in the size change.
    ND_Porkchop[OP] and Black Wolf like this.
  4. Apr 18, 2019 at 3:13 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    They increase your ground clearance by about 3/8s of an inch
  5. Apr 18, 2019 at 3:23 PM
    DividedSky
    DividedSky New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    and decrease your MPG by .02mpg and 0-60 times go up .016 seconds
  6. Apr 18, 2019 at 3:26 PM
    Aerindel
    Aerindel New Member
    Montana
    No. Smaller rims, more rubber is what you want.
  7. Apr 18, 2019 at 3:57 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Yes. You're gaining a whole inch in diameter. You might not really notice it but it will make a substantial difference wheeling.
  8. Apr 18, 2019 at 4:12 PM
    gjcarving
    gjcarving New Member
    Since you already have E rated in stock size you aren't going to lose that much mpg's. If they were stock p rated to the E it would be a much bigger difference. They will give you more sidewall which is good for off road. They look better on the Tundra also and the price is similar. The only thing that might rub is the back corners of the skid plate at full lock. Easily remedied by slightly bending the corner.
  9. Apr 18, 2019 at 6:06 PM
    ND_Porkchop
    Thanks for the responses.
    Are there any other negatives I'm missing? Is it an issue in the snow or mud having less clearance in the wheel well? Chains still fit in the rear?
  10. Apr 18, 2019 at 6:17 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Its not THAT much taller. No clearance issues.
  11. Apr 18, 2019 at 6:25 PM
    Berettafan
    Berettafan New Member
    2017 CM
    oil changes are easier (I use a large plastic bin to catch oil)
    looks better
    downside is worse mileage, slower, less brake effectiveness, less tow capacity.
  12. Apr 18, 2019 at 7:59 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    It will look a hell of a lot better
  13. Apr 20, 2019 at 4:47 AM
    Philogynist
    Philogynist New Member
    NY
    That's is some good feedback. The Wildpeaks are on my short list and I was not aware they came in a Load Range E.
  14. Apr 20, 2019 at 5:47 AM
    Rica25
    Ricardo
    Tulare
    I've been the owner of my tundra for 11 yrs now when I purchased the truck kept it stock for a year then I went with 275 70 18s then next set was 285 65 18 and my last set was 295 70 18 the look was great but the power loss was noticed right away and the mpgs were changed drastically but it all happened gradually now I went back to the stock size Michellin LTX at2 275 65 18 and the power is back and absolutely love it also the ride quality is great and even better the Mpgs are now back I lost up to 5 mpge with my Nittos Ridge Grapplers that were 295 70 18 like I said the look was great but I dont do much off road so not worth it
    ocwill, Tzvia and Philogynist like this.
  15. Apr 20, 2019 at 2:45 PM
    Berettafan
    2017 CM
    that's what I just put on my truck this past winter/fall. overall very happy. would get the same again.
    Rica25 likes this.
