DIY: Unistrut Bed Rails - Cheaper option than OEM
Discussion in 'General Tundra Discussion' started by csuviper, Jun 8, 2015.
  1. Dec 6, 2020 at 7:47 AM
    #241
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    I was looking for ideas on tie down anchors and I notice I never posted a pic of my set up. Had mine on for about a year now. Works great. The tool holder I brought over from my old Taco. Got directions off TacomaWorld to make that.
    J&ATundra and Cidertom like this.
  2. Jan 3, 2021 at 10:59 AM
    #242
    Alex21DC
    Alex21DC New Member
    2021 Gray DC SR5 TRD-OR
    Jeff, what depth of unistrut did you use on this build?
  3. Jan 3, 2021 at 12:37 PM
    #243
    Cidertom
    Cidertom Chionophile
    Tom
    2017 longbed
    On mine I used 13/16 nominal. I used unistrut P4100. Which is solid back.
    NewImprovedRon likes this.
  4. Jan 3, 2021 at 5:15 PM
    #244
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    FINALLY got this mod done !!
    Still need D-rings and such
    98955691-75FB-4A65-A1F3-73CE8D712F1D.jpg CB48CDCE-70CA-4B2A-AD04-9AF2CD58AB5B.jpg
    Next up bed light kit install
  5. Jan 7, 2021 at 6:08 PM
    #245
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Oh man. I don’t remember. I think it was 1 5/8 by 13/14 or 14 gauge
  6. Jan 20, 2021 at 9:09 AM
    #246
    paulbk
    paulbk New Member
    Question for those using OEM cleats.....
    1. How are you able to have OEM cleats fasten onto itself? I have the fender washer in place like above, but the "T-head" spins freely and will not grab unless I attempt to hold the "T-head" in place using a flathead screwdriver or pliers. In short, the more narrow OEM channel hold the "T-head" place allowing the cleats to fasten vs the wider channel on the strut.
    2. Are you mounting the "feet" of the OEM cleats inside the channel? The "feet" are too small to mount outside the strut, unless utilizing a washer....so does that mean using 2 washers?
    Pics added for reference...OEM tundra cleat mounted on unistrut.
    ThURD F3rguson likes this.
  7. Jan 27, 2021 at 10:19 AM
    #247
    Lobodog1
    Lobodog1 New Member
    I finally did this mod. The hardest part was finding the holes through the bed liner, but once I found the first one the rest were easy to locate. One 10' piece was perfect for both sides so it was cheap and works great.
    IMG_20210123_153603.jpg PXL_20210117_172554290(1).jpg PXL_20210117_174044566.jpg
    Zebruaj, kbark, R65 and 5 others like this.
  8. Sep 2, 2021 at 5:20 PM
    #248
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    Resurrecting an old thread...
    I am using 16mm long M6x1.0 pan head screws. They only go in a short distance (few threads) and stop cold. I do not see that there is anything obstructing the holes other than some minor surface rust. Any recommendations? Did anyone have trouble with the bolts/screws. I can get a tap if needed, but not sure why it should not just screw in.
  9. Sep 2, 2021 at 7:07 PM
    #249
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Bed liner?
  10. Sep 2, 2021 at 7:42 PM
    #250
    3rdTundra
    Central Texas
    I have a spray-in bedliner, but the holes look clear. It seems like the thread pitch does not match or the hole is very short. I think i may have to pickup a tap, but I don't want to mess up the threads...
  11. Sep 2, 2021 at 7:45 PM
    #251
    TundraPHX
    Jared
    Fairly common for the bed liner to gunk up those threads. Double check correct pitch on screw. If so, it’s a quick fix. I knocked it out w a HF tap kit in about 20 mins.
  12. Sep 2, 2021 at 7:52 PM
    #252
    Shanet421
    Shanet421 (Semi) New Member
    San Diego,CA
  13. Sep 3, 2021 at 6:54 PM
    #253
    3rdTundra
    Central Texas
    Cleaned out the bolt holes with a tap without issue. i decided to go with individual tie down points rather than the unistrut since I did not want to figure out how to mount with my BAK Revolver cover. Used tie down anchors with 16mm M6-1 stainless bolts and 1/4"x1" stainless fender washers.
    https://www.amazon.com/dp/B07WQSYWN2?ref=ppx_yo2_dt_b_product_details
  14. Sep 20, 2021 at 6:01 PM
    #254
    Parksareforever
    Parksareforever New Member
    2020 TRD DC 4x4
    Went to Ace, Home Depot, and Lowe’s. Nothing in stock. Finally went to an electrical supply store. Employee said due to covid the suppliers haven’t been making or stocking a lot of this stuff. Paid about $31 for each 10ft section. All in about $130. Still cheaper than OEM and feels a lot more solid.
    Easy to install. Only had to drill a few holes in the strut. Spray on Bed liner was surprisingly thick. F4011233-C6D3-4C55-8671-41A3BF9C4C12.jpg397FD8DF-54F4-4AF2-8F7C-9CD21BAB1F87.jpg
    Barrett50 likes this.
  15. Sep 28, 2021 at 12:23 PM
    #255
    Retired...finally
    Thanks for the idea. The holes were covered before the bedliner was sprayed but they are easily located by gently probing with an ice pick. Unistrut was the perfect solution for my ugly top box mount.20210927_101842.jpg 20210927_101833.jpg
    Tony_h likes this.
  16. Oct 4, 2021 at 12:28 PM
    #256
    Parksareforever
    2020 TRD DC 4x4
    Strut channel nuts and d rings from Amazon. Stainless steel hardware from Ace.
    F0DCF517-29B6-4DC5-88DD-83645C063FCE.jpg A08C89BA-1AC7-4675-B6FC-60148D946782.jpg
    Retired...finally likes this.
  17. Oct 10, 2021 at 7:37 PM
    #257
    cd121082
    cd121082 New Member
    chris
    Washington State
    2016 Silver Tundra TRD OffRoad
    none yet
    wonder if you can do this to the clamps with OEM rails.
  18. Jul 8, 2022 at 3:26 PM
    #258
    Tundra Lou
    Tundra Lou New Member
    ‘16 1769 Tundra CM
    I had to make an account for this post because I am in love with this mod! I wanted to share my (ultimate in my opinion) version of this mod!
    Pics will show everything!
    I will be applying bedliner and making additional quickmount stuff such as lockable ammo box for tie down gear since the eye hooks are removable by a simple 1/4 left turn (but don’t move at all under any pressure!)
    I used:
    •1 10ft shallower unistrut (yielded a 2” leftover piece, I only did the sides)
    •unistrut cone nuts
    •vehicle grade m6 x 1.0 (thread pitch) x 15mm long bolts
    •Additional pieces in the receipt below
    Let me know what y’all think!
    2B29C8A3-3BB5-426B-B4A5-66033AB3D24E.jpg AA3C2AE4-FEE8-424A-B47B-C3EBF1292A33.jpg 06136C3A-6F00-4F92-85EC-CB9C1146094C.jpg 526FC5FD-223D-4663-942B-4471BDDB72CA.jpg 2E0372E9-941B-49AF-9CBC-56AEE195B196.jpg
  19. Apr 5, 2023 at 9:37 AM
    #259
    Woocawachie
    Woocawachie New Member
    Dickens
    Philadelphia
    2023 Tundra Limited CM 6.5. WindChillPearl
    I think you just provided me with a solution for my 2023 tundra SR that did not come with bed rails. Thanks!
  20. Sep 10, 2023 at 12:31 PM
    #260
    17sr54x4
    17sr54x4 New Member
    Clint
    17 Sr5 trd 4x4 super white
    Stock
    Can anyone who has done this mod help school me a bit..
    I have a 17 sr5, trd off road with factory bed liner.
    I see some holes in my bed that appear to be there to mount the bed rail kit.
    My issue is according to many photos the hole closest to the tailgate is not there on my truck and then the next hole forward of it does not have any nut to screw anything to, I can take an ice pick and put it in that hole and touch nothing, not even the inner bed side.
    So I'm looking for a photo of how many holes by double cab should have and their location, same thing across the front of the box above the stamped tundra logo .
    I want to do this mod but want to make sure I can, I'm thinking that there might be bed liner over my holes needed but I'm clueless to where they should be. As you can see by photo added the hole highlighted by the flashlight is my first hole I see.. any ideas?
    Thanks guys.
  21. Sep 10, 2023 at 12:59 PM
    #261
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    On my 2012 DC, the first hole is 8" from the tailgate (with it closed) and the rest of the holes are 13" apart. I suspect that the problem with yours is the spray in bed liner. Whoever installed it simply sprayed over the holes. The ice pick might help you find the holes by poking through the liner. Once you find the holes, this will help clean them up. https://www.lowes.com/pd/IRWIN-HANSON-2-Pack-Metric-Tap-and-Drill-Set/3732947
  22. Sep 11, 2023 at 5:59 PM
    #262
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia Limited 4x4
    Big mods are coming soon, but not too soon.
    Great idea! I like what I see. Hardware store here I come...
  23. Sep 20, 2023 at 5:08 PM
    #263
    3rdTundra
    Central Texas
  24. Jan 19, 2024 at 12:03 PM
    #264
    meniscus
    meniscus New Member
    I know this is an older thread, but has anyone tried to cut relief into strut channel (cutting a triangle to bend) and weld to get vertical angles? A week ago, I added L-Track to the bedrails of my truck and also made some crossbars out of superstrut where the L-Track fittings allow the crossbars to be positioned anywhere down the length of the L-Track. Now I'm considering making a removable headache rack out of superstrut. (The reason why I need it easily removable is because I often end-up in parking garages where I'm already very close to max height and the taller headache rack I make would make would accommodate my 16+ foot canoe over the cab.)
    Sorry, I'm not a Tundra owner, but by far, the Tundra and Tacoma guys are doing more interesting DIY than some other owners and brands.
    Kiddnapped Tundra and Tony_h like this.
  25. Jan 23, 2024 at 8:45 AM
    #265
    HartysTundra
    HartysTundra New Member
    Great write up
  26. Jan 28, 2024 at 2:17 PM
    #266
    jimmyfu
    jimmyfu New Member
    N. California
    2014 Tundra DC SR
    does anyone have a solution to minimize the height of the screws/bolts? reason why i ask is i'd like to use the unistrut as an actual track system, but with so many bolts securing the rail, i'm not really able to slide things down the track at length...
  27. Feb 27, 2024 at 8:30 PM
    #267
    NTX_Tundra
    NTX_Tundra New Member
    Has anyone tried installing a bed rack that normally utilizes the factory toyota system? I'm curious if this could work.
  28. Mar 17, 2024 at 11:33 AM
    #268
    DCLarston13
    DCLarston13 New Member
    2020 Tundra Magnetic Gray TSS
    I just installed a Rola rack on my truck, if you have unistrut instead of the Toyota rail I think the Nissan fittings would work as they are closer in size to the unistrut.
  29. Mar 22, 2024 at 4:59 PM
    #269
    d33pt
    d33pt New Member
    For those of you that added the unistrut to the cab-side bed rail, how did you space out the unistrut? It's too wide to fit in that recess that's made for the toyota rail. Just stack a few washers?
  30. Mar 25, 2024 at 5:26 PM
    #270
    HartysTundra
    Wanted to give a shout to OP. Was looking into buying the OEM railing kit but couldn’t justify the $250+ to spend on it. So I went the DIY route.
    Was able to install my waterport tank, some tie down anchors as well as a board rack to keep my board from rolling around. Stoked!
    OldGuy03 and 4x4WarriorOfRocks like this.
