DIY: Unistrut Bed Rails - Cheaper option than OEM
Discussion in 'General Tundra Discussion' started by csuviper, Jun 8, 2015.
  1. Dec 28, 2016 at 6:54 PM
    #61
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Awesome, glad to help.
    #61
  2. Dec 28, 2016 at 8:25 PM
    #62
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Just did this one as well. For my CM one 10' length of superstrut from Lowes was enough to do the sides. I used M6 - 1.00 x 16 screws and 1/4 x 1 fender washers. Painted it all with bed liner paint. A total investment of maybe $30. I've not done the rail behind the cab. Don't know if I will. Working on the ammo cans - one completed and installed so far. Also painted with bed liner to make it a little less conspicuous. Not a ton of storage but great for tiedowns and a few tools. Thanks for posting. It's an easy mod, useful, and saves money vs OEM.
    Painted superstrut, washers and screw heads with bed liner
    Fit like they are from the factory!
    One ammo can installed so far
    And you can't see the can unless your looking for something!
  3. Dec 29, 2016 at 6:06 AM
    #63
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    Much better. The doctor took me off most of the restrictions. I can sit up and look straight ahead most of the time now. Distance vision is 20/20 in both eyes (except for a little of the bubble that hasn't cleared out yet), and I can watch TV and drive without a problem. There's still a little glare from the bubble, but a good pair of sunglasses takes care of that.
    Thanks for asking, and I hope the holiday season is treating you well.
    NewImprovedRon likes this.
  4. Dec 29, 2016 at 10:03 AM
    #64
    jeffw6236
    Jeff
    San Antonio
    Thanks! I've never done much in the way of mods in prior vehicles. This one was easy and fun. I like the way it turned out.
    I used rust-o-leum. Under $8 a can at Home Depot. 2 simple lessons learned. It says shake the can for a minute I think. You gotta do that. Also buy one of those can holder-trigger attachments for a couple of bucks. Well worth it.
  5. Jan 2, 2017 at 2:04 PM
    #65
    Randy Morton
    Randy
    If you're considering adding Unistrut (or Superstrut as Home Depot calls it), there are a couple of gotchas to be aware of. First, the holes don't line up. I cut a piece of strut the right size and a grand total of 2 holes lined up on each side. Be prepared to drill extra holes in the strut. Second, if you have a toolbox, be prepared to pull it before you start. It may block one hole at the front and you'll need that for strength at the front of the rail. I put the project aside for now, I'll get help pulling the box and finish up later.
    zcarpenter92 likes this.
  6. Jan 2, 2017 at 2:09 PM
    #66
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Definitely a thread hi jack but jogging is also stressful on the knees.
    driverdog likes this.
  7. Feb 20, 2017 at 6:43 PM
    #67
    Randy Morton
    Randy
    I finally removed the toolbox and installed the Unistrut rails. I also upgraded the toolbox mounts when I put it back in. Installing the rails isn't a simple bolt on process. Only a couple of the bolt holes line up. I pulled out the reciprocating saw and made some slices to lengthen the existing screw slots on the unistrut. It was much easier after that. I had already retapped the screw holes, they had just enough rust in the threads to keep the bolts from starting. For those interested, Unistrut and it's clones come in two sizes. 13/16" and 1-5/8". The 13/16 version is slightly recessed when you bolt it on, the other sticks out a little. Choose what works for you. I chose the 1-5/8".
  8. Apr 12, 2017 at 11:15 PM
    #68
    Toyota4x4
    Toyota4x4 New Member
    Vancouver, WA
    2017 Magnetic Grey Tundra, SR5 4x4, TRD offroad
    SR5 upgrade package, toyota nerf bars, velcro for morale patches, salex organizers
    For those installing the ammo cans, what type of nut/ bolt combo are you using to attach to the unistrut? Any pictures? I was thinking that of using the taller 40mm cans...
  9. Apr 14, 2017 at 10:17 AM
    #69
    csuviper
    Broomfield, CO
  10. Apr 14, 2017 at 12:04 PM
    #70
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    I cut my unistruts with the intention of putting a tool box in my pickup, glad to see my theory about it was correct. Luckily the length I cut mine made it to where I didn't have to drill any holes in it.
    Randy Morton[QUOTED] likes this.
  11. Apr 14, 2017 at 12:50 PM
    #71
    Randy Morton
    Randy
    I'd attribute the lack of drilling to the brand of unistrut you used. There was no alignment in the stuff I bought from Home Depot that would allow all of the holes to line up. I'm glad yours was more hassle free.
    zcarpenter92[QUOTED] likes this.
  12. Apr 14, 2017 at 12:51 PM
    #72
    csuviper
    Broomfield, CO
    Yep with typical unistrut you have to extend a few of the holes to allow the use of the existing threads.
  13. Apr 14, 2017 at 2:20 PM
    #73
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Ace Hardware unistrut must be the golden ticket lol.
  14. Nov 25, 2017 at 3:55 PM
    #74
    zcarpenter92
    Zach
    NE Colorado
    In sig
    What'd you do as far as the toolbox mounts? Mine's mounted with J-hooks, but I can't replace the cut unistrut for full length without possibly Dremeling the top lip of the strut for the J-hook or finding a different mounting solution.
    I'm thinking of putting a unistrut on the front of the bed, and drilling a few holes on both the front and sides of the box, then running bolts through the holes and securing them with knuts on either side of the toolbox. Is that what you did?
  15. Nov 25, 2017 at 5:46 PM
    #75
    Randy Morton
    Randy
    I used two sets of these. https://www.amazon.com/gp/product/B00FGJHG3E/ref=oh_aui_search_detailpage?ie=UTF8&psc=1 The struts reach from the back of the bed to a little under the toolbox. That way the front of the strut is held by a screw.
  16. Dec 4, 2017 at 9:45 AM
    #76
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Hey guys, the factory spray on liner covered up the holes that you'd attach the unistrut or OEM deck rail system to. Any suggestions to help me out?
  17. Dec 4, 2017 at 9:49 AM
    #77
    csuviper
    Broomfield, CO
    All i can think of is buy a tap and die kit and clean up the threads yourself.
    driverdog and NewImprovedRon like this.
  18. Dec 4, 2017 at 9:25 PM
    #78
    Nickj619
    Nickj619 New Member
    Nick
    San Jose, ca
    2014 tundra trd crew max
    This is a great idea, I use this stuff all the time at work. Would be nice to use solid channel strut without the holes in the back and paint with some plasti dip
  19. Dec 4, 2017 at 9:29 PM
    #79
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    I would avoid plasti dip if you're going to be using the rails. use some real paint so you don't mess up the dip
  20. Dec 4, 2017 at 9:47 PM
    #80
    Nickj619
    Nickj619 New Member
    Nick
    San Jose, ca
    That works too haha
  21. Jan 5, 2018 at 12:17 PM
    #81
    Worriedman50
    Worriedman50 New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    What is the actual depth of the unistrut needed for this application, it appears to be about half as deep as it is wide. Comes in two flavors, 13/16" depth or 13/32" in depth. Looking at the pictures it appears the 13/32" is the type to use?
  22. Jan 5, 2018 at 12:44 PM
    #82
    csuviper
    Broomfield, CO
  23. Jan 5, 2018 at 1:10 PM
    #83
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
  24. Jan 5, 2018 at 1:16 PM
    #84
    csuviper
    Broomfield, CO
    I think home depo only sells two different unistrut
    1. 1 5/8" x 13/16"
    2. 1 5/8" x 1 5/8"
  25. Jan 5, 2018 at 1:22 PM
    #85
    Randy Morton
    Randy
  26. Jan 5, 2018 at 1:55 PM
    #86
    Worriedman50
    Richard
    West TN
    2015 Tundra Crewmax
    Thanks guys!
  27. Apr 15, 2018 at 6:44 PM
    #87
    LKSR5-14
    LKSR5-14 New Member
    Chicago Northwest suburbs, Illinois
    2016 Tundra SR5 DC
    Tundra SR5 DC 2016 Upgrade: pro wheels, headlights retrofit, head unit Kenwood 694s, bed cover, lineX, Viper security and starter system, pro grille, tinted windows, LED lighting, black wrap on all end chrome corners, ceramic coating
    Would I be able to use these rails to modify undercover flex cover brackets install or it's different sizes?
    Drive me crazy that those brackets got loose often and top oem plastic on the edges of the truck bed pops up so eventually will damage them.
    Any good solution who have undercover flex cover?
  28. Apr 15, 2018 at 7:04 PM
    #88
    LKSR5-14
    LKSR5-14 New Member
    2016 Tundra SR5 DC
    Can someone provide oem vs fabrication rail measurements before I started buying things?
    I'm about to pull trigger and buy new brackets for rail installation but not sure if I do fabrication one from home depot would work with undercover flex brackets?
    Here is the brackets I'm talking about https://www.undercoverinfo.com/i-30124835-undercover-flex-clamps-rsfl7536hk.html
    Can someone please suggest who is maybe done it already?
  29. Apr 16, 2018 at 10:26 AM
    #89
    csuviper
    Broomfield, CO
    One of these
  30. Apr 16, 2018 at 10:27 AM
    #90
    csuviper
    Broomfield, CO
    The one i purchased is listed as
    • 14-Gauge metal construction with half-slot holes
    • Channel is 10 ft. in L and measures 1-5/8 in. x 13/16 in.
    That would be the BSC-500.
    LKSR5-14 and NewImprovedRon like this.
