DIY: Unistrut Bed Rails - Cheaper option than OEM
Discussion in 'General Tundra Discussion' started by csuviper, Jun 8, 2015.
  1. Jul 13, 2016 at 5:35 PM
    sam_i02
    sam_i02 New Member
    Sid
    2010 Tundra Roack Warrior
    Gene - did you find a way to make it work with the flipbak? I have one of those covers too.... helps keep the snow out in the winter.
  2. Jul 16, 2016 at 11:37 PM
    medicgio
    medicgio New Member
    2016 Silver Tundra TRD
    Can anyone out the size the rails need to be cut too? And possibly explain how the install went? I just want to make sure I do this correct this first time. And what size channel did you guys use to get the stock tie downs to work? Thanks all
  3. Jul 29, 2016 at 9:45 PM
    FumundaTundra
    FumundaTundra Director of civil unrest
    Wayne
    Central WA.
    2009 5.7 Tundra Double cab
    Many to come.
    The "channel" they're using is called uni-strut. Electricians and pipe fitters use it to put up elect. conduit and pipes in industrial applications. You can find it at most any large hardware store or electrical or pipe supply warehouse.
  4. Jul 31, 2016 at 2:24 PM
    medicgio
    medicgio New Member
    I know but it comes in long sticks. How long does each rail need to be cut too and how do the actually install it? Are their nuts on the backside already
    And just need to be screwed in to the bed?
  5. Jul 31, 2016 at 2:58 PM
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    The nuts are already a part of the besides. Just screw them on. As af as the length, would have to measure.
  6. Jul 31, 2016 at 6:31 PM
    medicgio
    medicgio New Member
    I have a buddy w factory I'll make him measure em when he is back in town thanks man! I appreciate the offer
    NewImprovedRon likes this.
  7. Aug 29, 2016 at 11:15 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    Doing this
  8. Nov 26, 2016 at 12:35 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I bought M6x1 bolts, but they don't fit. I even drove back to the hardware store and checked to make sure they're M6x1. It has a spray in bed liner, but the holes appear to be clear. Any ideas about why I can't get a bolt in any of them before I try cleaning the threads with a .22 caliber bore brush in a drill?
  9. Nov 26, 2016 at 1:12 PM
    csuviper
    Broomfield, CO
    M6x1 were confirmed by several to be the correct bolt.
  10. Nov 26, 2016 at 1:25 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    My 2011 is definitely M6 x 1
  11. Nov 26, 2016 at 3:26 PM
    Randy Morton
    Randy
    Time with a drill and a brush (bronze .22 caliber bore brush) let me get a couple of them started, but it's going to take a while. I'll pick up an M6x1 tap and clean the threads when I get them clean enough to start. They look OK, but there must be enough crud in the threads to keep the bolt from starting.
  12. Nov 26, 2016 at 3:55 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Subbing. I gotta do this to the Tundra. My taco had bed rails. Used them all the time
  13. Nov 26, 2016 at 5:41 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
  14. Nov 26, 2016 at 7:17 PM
    xtyfighterx
    Ty
    North Idaho
    Will the oem cleats fit on with this size strut?
  15. Nov 26, 2016 at 7:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    No I am sure they won't.
    You will need to be a bit of a fabricator and expect to make your own stuff.
    If you're not familiar with unistrut do some googling and see what questions you still have.
  16. Nov 26, 2016 at 7:34 PM
    xtyfighterx
    Ty
    North Idaho
    Ok im looking to buy some bed bars that attach with the oem track system so I'm just curious if this will work I'm guessing the strut is to wide then? Anyone know a size similar to oem deck rails
  17. Nov 26, 2016 at 7:54 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Strut is shallow (3/4") or std (1 5/8)
    Not sure about how wide. It's common stuff so get a bit and check it out. The main thing is that it's universal with easily modified fasteners. Toyota rail only works with the factory cleats. The main use for strut is running conduit and/or pipes so most accessories facilitate this. Making an adapter to mount a hi-lift jack would not be hard.
    I tore apart a Toyota factory cleat to see if it was something to modify and it looked pretty limited.
  18. Nov 27, 2016 at 8:19 AM
    csuviper
    Broomfield, CO
    Yes they will but require a fender washer to hold them on.
    gosolo likes this.
  19. Nov 27, 2016 at 8:23 AM
    #49
    csuviper
    Broomfield, CO
    Check out the top quote here...
  20. Nov 27, 2016 at 8:48 AM
    #50
    xtyfighterx
    Ty
    North Idaho
    Ok thanks I'm sure I can just find hardware that will work the the unisteut
    what size washer?
  21. Nov 27, 2016 at 9:48 AM
    #51
    TheBeast The Beach
    btw free shipping at toyota of cool springs in case you need parts. free shipping on bulky parts is nice.
  22. Nov 28, 2016 at 2:56 PM
    #52
    Toddanddaneen
    Toddanddaneen New Member
    Wv
    2015 Silver Sky Tundra crewmax
    Just wanted to add the Nissan tie down cleats work with the unistrut without any modification and are very stout.
  23. Nov 28, 2016 at 2:57 PM
    #53
    Toddanddaneen
    Wv
    Had some left over from my frontier so thought I would give it a shot works perfect. Doing this mod as soon as I get a good day.
  24. Nov 28, 2016 at 3:33 PM
    #54
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Good information!
  25. Dec 4, 2016 at 2:19 PM
    #55
    dragon_coma
    dragon_coma New Member
    Sky
    2008 CrewMax 4x2 5.7L
    Can we add a list of things installed to these struts? I've seen a lot regarding Tacoma or Tundra or Titan rail pieces fitting, but did anyone innovate something else? I know some D-rings were mentioned - any other nifty ideas?
    jeffw6236 likes this.
  26. Dec 4, 2016 at 2:59 PM
    #56
    Randy Morton
    Randy
    I picked up an M6-1 tap and cleaned the holes. The main problem was rust. It wasn't much, but it was enough to keep the bolts from starting. If you decide to add rails, this tap works well. https://www.lowes.com/pd/IRWIN-Tap-and-Die-Set/3732947
    Fortunately, a used a Q-Tip and put a light coat of oil on the threads. It'll be a while until I can add the unistrut, one of my retinas decided the holidays would be a good time to detach and my activities will be seriously limited for the next couple of months. Look up "vitrectomy with gas bubble and laser" on youtube if you're curious.
  27. Dec 4, 2016 at 6:06 PM
    #57
    PMG
    PMG New Member
    God speed with the vitrectomy. Did you already have it done, what was the reason, get 2nd opinions etc.. Just curious as I'm in the business. If to personal then no worries.
    PMG
  28. Dec 4, 2016 at 6:38 PM
    #58
    Randy Morton
    Randy
    I had cataract surgery a month ago (the left eye was on 10/29, the right on 11/3) and the detachment (also left eye) started the weekend after Thanksgiving. I went back to the doctor that did the initial work, he checked it out and immediately referred me to a retina specialist. The specialist concurred with his diagnosis and scheduled me for surgery the next day. Both agreed that it was due to my over abundance of floaters and thickening fluid. Most have been there all my life, but a couple of new ones appeared after the cataract surgery. So far, things are going well. The bubble is a tad smaller now (it was 90% air, 10% fluid) and there's been no pain other than my back from sitting with my face pointed down all day. If all goes well, I'll be able to see properly by Christmas. Thanks to all who've sent well wishes.
  29. Dec 4, 2016 at 11:40 PM
    #59
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    We are praying for a speedy recovery brother
  30. Dec 28, 2016 at 12:05 PM
    #60
    BlueFalconActual
    Kevin
    29 Palms, CA
    Tundra-less
    Awesome write up. Saved me a bunch of $ and gave me a project to do. you can find the cleats on eBay for around 45 bucks for a set of 4.
    #60
