Diy under seat storage
Discussion in 'General Tundra Discussion' started by saybng, Aug 30, 2018.
  1. Feb 4, 2022 at 8:29 AM
    #121
    jhowat
    jhowat New Member
    St. Petersburg FL
    2018 Tundra SR5
    Bilstein leveling shocks, 20” XD Grenade Wheels, Cooper Discover 275/65/20 tires, Bushwacker extend-a-fender flares
    I ended up going the route mentioned by some other people. 2 layers of 3/4” plywood and catering trays. Sprayed everything with bedliner. Ended up being very inexpensive and a great solution. I prefer the raised bins for deeper storage and the seats act as lids when they are down. Took a bit of tweaking here and there to get everything squared up and tucked under. Works like a charm now!
  2. Feb 4, 2022 at 9:02 AM
    #122
    saybng
    saybng [OP] Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Well done!!!
  3. Feb 4, 2022 at 9:27 AM
    #123
    Sundog
    Sundog Zoom Zoom
    MNSP
    2014 Red CM Tundra
    I like it. With the exception that it will be a PITA to take the floor liner out to clean or just in general.
  4. Feb 4, 2022 at 11:21 AM
    #124
    jhowat
    jhowat New Member
    St. Petersburg FL
    2018 Tundra SR5
    With it being a truck and have kids, inside the bed and the back seat are the two areas I’ve given up trying to keep clean. Lol. Love the Weathertech floor trays. I just wipe them down or wait for the kids to spill a water bottle to clean them. I had a lockable cover on my previous Tundra that allowed me to have a tool box strapped down inside the bed for storage. Haven’t decided if I want to bite the bullet and buy another cover, so this was the best way for me to keep my stuff secure and organized.
  5. Feb 4, 2022 at 1:08 PM
    #125
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Since everything just drop in and is not bolted down, it is actually fairly easy to remove.
    Cthulhu and saybng[OP] like this.
  6. May 14, 2022 at 4:23 PM
    #126
    MULLI63
    MULLI63 New Member
    Southern California
    2015 Tundra Platinum, SnugTop Shell, Gray
    Bilstein 5100 all four corners - front at top setting Ready Lift 1” rear block 295/70R18 Falken Wildpeak Method Roost R18 Under Seat Storage Boxes - Rear Seats - see post LED Interior Lights LED Mirror, Back-Up and License Plate Lights Added Auxiliary Fuse Box and Battery Switch Plasti-Dip Chrome Mirror Covers and All Badges to Black WeatherTech Bed/Tailgate Liner Replaced tailgate strut Working On Modifications: Add Oh Sh!t Handle To Driver Side A Pillar LED Head and Fog Lights
    Been wanting to do this mod since I got my “new” 2015 Platinum a couple of months ago.
    Started on it today.
    Outer dimensions that I cut carpet and foam to:
    Driver Side - 12” Wide x 14”
    Center - 15” wide x 14”
    Passenger - 11” wide by 14”
    - Used yellow crayon to mark carpet.
    - Made cardboard templates. An improvement I would recommend is connecting the three templates to align properly. Like saybng shows earlier in thread.
    - Cut carpet with utility knife (new blade). Cut as deep as you can to get carpet and first layer of soft foam.
    - Cut thick layer of hard foam with a multitool with wood blade. Mostly made it down to the metal floor. It was a snap to cut and make straight cuts.
    - Used metal ruler to chop any foam sections still connected before I could remove the foam in one piece.
    - Trimmed up the carpet and soft foam with scissors.
    - Used multitool to clean up any hard foam to form nice boxes.
    - See pics attached.
    Next steps are:
    - Make wood walls for each box
    - Run wood strip to connect the front of the boxes
    - add wood divider to make the small areas in front of the seat bolts
    - paint black
    => will publish next phase when done
    C393C83E-003E-4924-9A51-DAEF76C8A029.jpg 3949EC3C-148C-4819-9823-A204FD438D33.jpg CE0409E7-B2D5-460F-830A-3807F61FBDC5.jpg A8A4BFEB-F83E-49DB-A42B-57CD2859282B.jpg
    saybng[OP] and Trooper2 like this.
  7. May 15, 2022 at 5:24 PM
    #127
    MULLI63
    MULLI63 New Member
    Southern California
    Phase Two: Today I made the boxes, painted them and installed them. While I have the skill and tools to make the boxes with some kind of joinery, or glue and nail, I was getting lazy on this mod when I remembered I had my Kreg pocket hole jig. Boom, 3 boxes in 20 mins.
    Box sizes were not exact to what I listed above since I was not 100% accurate in cutting to the crayon outline. So, I measured each box wall separately and cut to that size to fit the hole. I decided on 4” height, but could have done 4 1/2” height to meet up with the bottom of the seat.
    After installing each of the boxes, I realized why the original poster put the front and side extra wood. It is like a trim and I was considering doing that. I did not think the extra little space was worth the additional effort.
    When I put my WeatherTech back down, it kind of hides the storage, but does not really look good near the door, as the liner is raised about 2” from the door sill. I will cut the liner to open up the holes and then I will not have to make the “trim”, as the liner will hide the carpet to box wall transition.
    Worst part? Getting the soft foam that was under the carpet out of the carpet in the truck. It seems like it got everywhere!
    2EB4CE5C-A3CD-4E97-8F2A-AE330DBBA24F.jpg AA398130-1858-4E18-A22B-6DF3D7831A83.jpg 509972CA-9F5E-4B89-AB97-A47FDC88EAEA.jpg FD791F06-8813-4ACC-B405-57EF584630C0.jpg 58EE0D75-B71B-46F4-921B-54426D30CE65.jpg DD4EC752-E199-45C9-852D-C203F49D837F.jpg
    Sleeper16plat and BlueRibbon4x4 like this.
  8. Mar 31, 2024 at 6:23 PM
    #128
    Openroad928
    Openroad928 New Member
    2020 Tundra Limited
    none
    I think the weather tech or similar mat is the way to go for me. I travel with my dogs and was trying to figure a way to have a lid on the storage. Initially considered a hinged lid across the entire length to accommodate a long gun. Bu think I will have to go with the bin strategy. New to the group (2020 platinum) so pleased with all of the help available.
