Diy under seat storage
Discussion in 'General Tundra Discussion' started by saybng, Aug 30, 2018.
  1. Jul 1, 2019 at 8:41 PM
    #91
    Rockgate
    Rockgate New Member
    Terry
    Middle TN
    2022 CMLB TRD OR Prem. 4X4 and 2002 RCLBV65Spd
    Nice, I myself am also a cabinet maker and almost anything out of wood.
    saybng[OP] likes this.
  2. Jul 1, 2019 at 9:34 PM
    #92
    saybng
    saybng [OP] Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Well there u go..this is a walk in the park for u!..post pics..
    Rockgate[QUOTED] likes this.
  3. Jul 4, 2019 at 6:46 AM
    #93
    Double Badass
    Double Badass For Thoughs about to Rock we SALUTE you
    James
    Arizona
    2019 Cement Tundra Crewmax
    6 inch pro comp coilover lift, 20 fuel wheels 35 nitto mud grapplers, colorbomb blackout, rigid industries lights, amp steps
    Very cool
  4. Jul 4, 2019 at 8:06 AM
    #94
    jtaco11
    jtaco11 New Member
    Cool idea
  5. Jul 12, 2019 at 11:47 AM
    #95
    RDRunner
    RDRunner New Member
    2016 SR5 Crewmax 4x4 TSS Edition
    Nice job. I thought about doing that and also looked into purchasing a set of boxes that install the same way (saw them online and they were super expensive), but I like and use the flat carpet floor under the seat (when the seat is folded up) and do not want to give it up. Plus, you don't gain that much storage with these boxes for the trouble. If I were going to do it, I would prefer to use a thinner material to build the boxes (like the metal pan the other poster used or a top grade 1/4 baltic birch plywood) and I prefer to have lids on the boxes that are flush with the floor and maybe even carpeted with the same carpet as the floor, with maybe a small finger hole to open the lid with hinges. Of course, this design would hold even less (a lot less) and would require a lot of work, and thus it is probably not worth it. I also worry it would hurt the resell of the truck (that is always a big concern). After thinking about it for a while, I bought a camper shell and called it a day.
  6. Nov 3, 2019 at 2:36 PM
    #96
    prerunnerseth
    prerunnerseth New Member
    Apex, NC
    2015 MGM Limited 4x4
    Thanks for the inspiration. Here is mine. Have some finish and paint to do but I'm happy.
  7. Nov 3, 2019 at 2:57 PM
    #97
    saybng
    Gary
    Ventura CA
    Now that's what I'm talking about!! Well done.
    Trooper2 and Rabidllamas like this.
  8. Nov 5, 2019 at 1:16 PM
    #98
    prerunnerseth
    Apex, NC
    Painted with rustoleum spray on bed liner.
  9. Dec 31, 2019 at 4:54 PM
    #99
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    Wife and I did ours with plastic bins. Fun project and Great for under $20!
  10. Feb 21, 2020 at 1:52 PM
    #100
    niteowl100
    niteowl100 New Member
    tundra limited 2018
    IMG_0649.jpg IMG_0643.jpg IMG_0645.jpg IMG_0653.jpg Decided to make one without cutting carpet its not real deep but it holds a few items one mite need. Used scrape wood and small nail gun.
  11. Feb 21, 2020 at 3:51 PM
    #101
    saybng
    Gary
    Ventura CA
    Well done!
  12. Feb 21, 2020 at 4:12 PM
    #102
    JLS in WA
    JLS in WA New Member
    2008 White DC Limited 4x4
    Drahthaar Transport Unit
    I’ve been looking at these as well, they make on that fits around the factory sub woofer.
  13. Nov 20, 2020 at 5:48 AM
    #103
    Mr.Sandman
    Mr.Sandman New Member
    2019 voodoo blue tundra
    This is inspiring but I’ve got one question... if I’m building boxes from scratch, why not build them longer under the seat???? How far under the seat can you go? Is there something that would stop you from going 4-6 more inches towards the back?
  14. Nov 20, 2020 at 6:14 AM
    #104
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    You can go further back, but the floor starts to slope up, so you would not have the same depth all the way through.
    I would suggest cutting the 'standard' size out of the foam and then gradually cut back an inch or so at a time until you get to a point where you see that it would not be worth it anymore.
    Borrowed photo from an earlier post: here you can see how the floor changes to the back, but you do have a little more room to go.
    STR1, saybng[OP] and BlackSheep like this.
  15. Nov 20, 2020 at 7:04 AM
    #105
    Mr.Sandman
    Thanks for that picture, that’s just what I needed.
    saybng[OP] and Boerseun like this.
  16. Nov 20, 2020 at 10:01 AM
    #106
    niteowl100
    tundra limited 2018
    The way I built mine on top of the carpet, there is not much room in the back maybe 2 or 3 inches. When you close the seat it will hit if taller.
  17. Nov 20, 2020 at 10:41 AM
    #107
    Rabidllamas
    Phil
    WA
    not sure if this helps but I purposely used cheap plastic bins. I then used a heat gun to help them “mold” /fit to the ridges in the floor seen in the 1st pic. I could of gone with bigger bins but this fits my needs.
  18. Nov 20, 2020 at 10:47 AM
    #108
    Boerseun
    Ferdie
    Sarasota Florida
    Good idea.
  19. Nov 20, 2020 at 11:35 AM
    #109
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Something else to note - according to the ESP site, there is a wiring harness under the middle section on 2020 and 2021 that have the smart key. Even so, I'm thinking of doing this one. I've got a woodshop and plenty of 1/2" baltic birch.
  20. Nov 20, 2020 at 11:38 AM
    #110
    saybng
    Gary
    Ventura CA
    Awesome..please post pics..:thumbsup:
  21. Nov 30, 2020 at 10:04 AM
    #111
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    Seems to me that someone handy with a welder could box in those seat mounts to create a frame and open up a large area for storage. Maybe even fab a riser to increase the height under that rear seat?
    I sketched a doodle on that pic above, but can't figure out how to attach a file...
  22. Nov 30, 2020 at 10:16 AM
    #112
    RainMan_PNW
    Casey
    Clark County, WA
    The ESP single-piece box does just that (replaces the seat mount frames) - that's part of why it is so much more expensive than the other metal version or the plastic version. I've seen (but can't remember the brand) another version that did that AND raised the seat a little too.
  23. Dec 3, 2020 at 3:04 AM
    #113
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Keep 'em coming guys. This one is my favorite setup so far.
    BlueRibbon4x4 and Tundra2 like this.
  24. Feb 2, 2021 at 4:06 AM
    #114
    Gazinta
    Gazinta New Member
    2021 Tundra TSS Crewmax
    Your work is really cool. I have wanted to ask a question about these under-seat storage solutions and since you did this, perhaps you are a good guy to ask. Is there any reason your storage openings do not extend further back under the rear seats? Even the ESP’s and Tuffy’s do not attempt to make use of the space further back under those seats. I wondered if there was some obstruction that limited how far back you could open up for storage boxes? Did you happen to find any such limitation? Love what you did! Just wondering if the storage spaces could be bigger. Thanks for showing what you did.
  25. Feb 2, 2021 at 4:18 AM
    #115
    Boerseun
    Ferdie
    Sarasota Florida
    The floor starts to slope up further back. Just a gentle slope so you could use it, but it will not have a flat floor all the way back. Passenger side also has the jack there.
    saybng[OP] and Orracle like this.
  26. Feb 2, 2021 at 5:27 AM
    #116
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Anyone try something like this with a DC? If not, I suppose I could be the guinea pig...
  27. Feb 2, 2021 at 5:50 AM
    #117
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Dang I forgot all about this thread. Great ideas here! I’ll add mine to the list. It has a little less storage because of the lids, but I needed them. Added a Toyota Trucks emblem and wired in lights to the dome light. Color matched mine with Raptor liner. Pic in black with lights is before lids and liner. CD8F05F0-B357-44BB-BEAF-1D5E4D39217D.jpg 3B282305-24E9-4F63-BF00-8D40FC4FDFD1.jpg 680033B3-A712-4F4F-B1AF-FE8485D132C9.jpg
    Sleeper16plat, Trooper2, STR1 and 5 others like this.
  28. Feb 2, 2021 at 9:53 AM
    #118
    Gazinta
    Gazinta New Member
    Those are nice!
    BlueRibbon4x4 likes this.
  29. Feb 4, 2021 at 5:36 AM
    #119
    DIYDad
    DIYDad New Member
    2020 Tundra 1794
    I looked at that pic like 6 times before I noticed that you even put lights in the storage wells. Nice work!
    BlueRibbon4x4[QUOTED] likes this.
  30. Feb 4, 2021 at 5:49 AM
    #120
    BlueRibbon4x4
    Geno
    Thanks!!
