DIY Supercharger install 2016 5.7 ffv
Discussion in '2.5 Gen Tundras (2014-2021)' started by ZPMAN, May 26, 2018.
  1. May 27, 2018 at 4:05 PM
    signalbobby
    signalbobby New Member
    Robert
    AZ
    16 Tundra PRO & 4R PRO
    top side creeper. seriously.
  2. May 27, 2018 at 4:07 PM
    signalbobby
    Robert
    AZ
    FYI, i dont know what kind of fuel you have. but i have an updated tune file that helped the low mid end pinging on 91.
    beungood and ZPMAN[QUOTED][OP] like this.
  3. May 27, 2018 at 4:08 PM
    signalbobby
    Robert
    AZ
    i used a 1/4 drive socket, swivel and extension to get the manifold bolts in. what did you use?
  4. May 27, 2018 at 7:33 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Newburgh toyota
  5. May 27, 2018 at 7:34 PM
    darkknight2014
    Phil
    New york
    2014 tundra sr5
    Mine is the regular non ffv 5.7
  6. May 27, 2018 at 8:40 PM
    trdprobped17
    trdprobped17 New Member
    I’m definitely going to get a few more specialty tools before I get started. Thanks for the info.
  7. May 27, 2018 at 11:10 PM
    ZPMAN
    ZPMAN [OP] 2nd place is the 1st looser
    Minnesota
    You goy that right, i took the off the hood, grille, and lower grille mount. I took out the air box along with the windshield wash reservoir then used the SC packing foam for comfort.
    Watt maker likes this.
  8. May 27, 2018 at 11:30 PM
    ZPMAN
    Minnesota
    Yep i used the same but the two circled in red xspecially the one on the left you could not get a scoket or wrench on.
    This is what i used, i put a pice of electrical tape over the T40 torx bit then pushed it into the 1/4 ratchet then put a flait screwdriver against the bolt washer for resistance.
    Nick T and Watt maker like this.
  9. May 27, 2018 at 11:43 PM
    ZPMAN
    Minnesota
    I have the latest file from bully dog if thats what your using, i have not heard any low to mid range ping yet.
  10. May 27, 2018 at 11:50 PM
    ZPMAN
    Minnesota
    Well im pretty sure you will be doing a fuel pump, @dirtydeeds might know about injectors or give Sparks a call.
  11. May 28, 2018 at 2:49 AM
    koditten
    Kirk
    Midland of the Mitten
  12. May 28, 2018 at 7:37 AM
    ZPMAN
    Minnesota
  13. May 28, 2018 at 8:03 AM
    koditten
    Kirk
    I got the part for working under the truck handled...IMG_20180521_172728.jpg
    Need to take care of working in the engine bay now.
    Baja Mike and Watt maker like this.
  14. May 28, 2018 at 8:28 AM
    ZPMAN
    Minnesota
    Yes it comes with a Sparks top plate, no offense to Sparks but wish is was a TRD one or Magnuson.20180528_101653.jpg 20180528_101714.jpg 20180528_101736.jpg
  15. May 28, 2018 at 8:34 AM
    ZPMAN
    Minnesota
    Sweet! You can take off all four and put her wear you want, kinda like Bill Cosby
    Watt maker and darkknight2014 like this.
  16. May 31, 2018 at 5:45 PM
    Nick T
    Nick T New Member
    Nick
    Thanks for the t40 torx tip, had the hardest time removing that rearmost passenger side intake manifold bolt the first time using an offset wrench and ratcheting wrenches..plus unhooking the clips that hold the harness behind the S/C
    ZPMAN[OP] likes this.
  17. Jun 1, 2018 at 1:36 AM
    ZPMAN
    Minnesota
    Thats very true on the rear main wire harness clips, what i did was remove bolts from the back of the intake manifold, then after you remove the manifold unclip the metal brackets from the harness and install them them on the rear of the supercharger, then recliped the main wire harness after all the SC botls were tight.
  18. Jun 1, 2018 at 1:53 AM
    ZPMAN
    Minnesota
    To make installation of the aftercooler radiator easier i removed this bolt and it simplified the install of the radiator.
  19. Jun 1, 2018 at 2:59 AM
    #49
    ZPMAN
    Minnesota
  20. Jun 1, 2018 at 3:06 AM
    #50
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    Thanks ZPMAN for posting up those interesting pics.The supercharger club is definitely exclusive. Lots of folks on here would love to be members.Congrats!
    Duneflyer and ZPMAN[OP] like this.
  21. Jun 1, 2018 at 4:45 AM
    #51
    ZPMAN
    Minnesota
    Thanks, Magnuson could sell alot more products if they would simplify there manual or make a video to make it easier for a person to install. Cost of product + install puts it in don't touch me or I'll be signing divorce papers.
  22. Jun 1, 2018 at 5:11 AM
    #52
    koditten
    Kirk
    No.
    They could sell allot more of the price was actually reasonable.
    You can't tell me there is $6000 in machining, parts and labor to build the things.
    The profit on the things has got to be amazing.
    They are doing something that is unheard of.
    Usually when a branded part becomes available in a generic form, the price goes down.
    Once the TRD branded SC become just a Magnusen charger, the price should have dropped. It actually increased. I've not seen that before.
    I like this thread.
    darkknight2014 likes this.
  23. Jun 1, 2018 at 7:03 AM
    #53
    ZPMAN
    Minnesota
    Yep it was a hard pill for me to swallow eaven without the cost of installing , but i am very happy that i did now.
  24. Jun 2, 2018 at 5:53 AM
    #54
    ZPMAN
    Minnesota
    Just some final touches i had to do for the Bully Dog tuner.
    They give you a little a little clip that your suppose to clip to an exsisting fuse under the dash on the drivers side. Only problem is the Tundras are using a newer style fuse and cannot be used. I was however able to use temporally an older style fuse that i shorted out then installed in one of the blank open spot on the fuse block that powers on with the ignition. I shorted the fuse out because i not sure what it was used for if anything. Pluged the BD into the OBD, installed the Velcro on the unit and mounted it, pulled the weather strp away then ran the wire to the unit. I wanted the unit to be to be removable to change mods an updates.
    I will have to pick one of these next time in town
  25. Jun 2, 2018 at 5:58 AM
    #55
    ZPMAN
    Minnesota
    The only thing i hate about the Bully Dog is it's hard to read with 53 year old eyes.
    Would love to mirror it to my head unit to look like this.
    4Runner, Watt maker and koditten like this.
  26. Jun 6, 2018 at 5:11 PM
    #56
    ZPMAN
    Minnesota
    Just to let everyone know about about what kind of mileage I'm getting now. Just befor the install i toped off the tank and reset trip meter and after a heavy foot and a few races my mpg came in at 11.83 city with a little hwy and i was very surprised at that, was thinking it was going to be about 9 at best, im hoping for a road trip it should be around 16 to 17
  27. Jun 6, 2018 at 5:13 PM
    #57
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    There is a YouTube where a Toyota shop installs the SC. They removed the entire hood.
  28. Jun 6, 2018 at 5:23 PM
    #58
    ZPMAN
    Minnesota
    Yep im sure any shop that installs one would want to take the hood off.
  29. Jun 6, 2018 at 5:29 PM
    #59
    Nick T
    Nick T New Member
    Nick
    2007 rcsb 4x4 trd tune, leveled with pro suspension, bed cover. 16mpg flat AZ highway @75mph. Might get more if i remove the bed cover, would get more if i cruise at a slower speed. I can't cruise at 60mph to gain 2mpg though....
  30. Jun 6, 2018 at 5:42 PM
    #60
    ZPMAN
    Minnesota
    Olny other thing bothering me is the bully dog, been trying the performance test and all i get after the test is this screen.20180606_192719.jpg
    Looks like it has results but it has the testing screen sticking around blocking results. Have no problem switching builds, a word of caution picking builds you can view (click on)A,B,C but if you pick stock it will start the install. If anyone knows what I'm doing wrong give me a shout about the performance test. Might have to give Keith or bully a call tomorrow.
