DIY Spring Compressor
Discussion in '2.5 Gen Tundras (2014-2021)' started by Cdorman, May 1, 2019.
  1. May 1, 2019 at 8:28 PM
    jtdunc
    jtdunc New Member
    2014 Tundra Double Cab - Magnetic Gray
  2. May 1, 2019 at 9:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    On a car coil its no big deal using threaded spring compressors. On a heavy truck coil it's pretty sketchy, a wall mounted unit is better. I bent one of those rental units doing a BMW spring, couldn't have been more than 400lbs.
    For $40 I would gladly pay a shop.
    Squatting Pigeon likes this.
  3. May 2, 2019 at 1:01 PM
    Cdorman
    Cdorman [OP] New Member
    Oklahoma
    2015 - SR5 - CM - MGM
    Color match MGM Bulge/Grille Trim Pro Grille TRD Pro Headlights(black) OEM led fog lights upgrade Headlight Revolution HID upgrade TVD vinyl decals Fog lights Always MOD Bilstein 5100’s 12Volts remote start kit PowerBass plug/play speaker upgrade
    Gonna have to purchase a new floor jack and couple jack stands. Any particular, quality, brand you DIY’ers like to use?
  4. May 2, 2019 at 2:21 PM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    You don’t need a compressor use the weight of the truck it’s fast easy and safe....there’s videos online.
    Darkness and (deleted member) like this.
  5. May 2, 2019 at 2:24 PM
    xtyfighterx
    Ty
    North Idaho
    This on a Tacoma but it’s the same steps except you need to remove your skid plate and either sway bar end links or sway bar mounts.
    I’ve done dozens like this.
    https://youtu.be/vkVLBOnAifc
    Darkness, Pudge and (deleted member) like this.
  6. May 2, 2019 at 3:36 PM
    Cdorman
    Oklahoma
    xtyfighterx
    Thanks for that! That honestly looks easier & quicker than the other methods I’ve seen.
    xtyfighterx likes this.
  7. May 2, 2019 at 3:45 PM
    xtyfighterx
    Ty
    North Idaho
    About 30min a side is what I do them in it’s super simple and safe. Good luck let us know if you run into anything else.
    LS3 and Cdorman[QUOTED][OP] like this.
  8. May 2, 2019 at 3:47 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I’ve done quite a few with the YouTube method... but for $40.00 I’m taking to a shop! You can done a bunch of crazy stuff in the shop and get away with it... but sooner or later it’s going to catch up to you!
    Cdorman[OP] and Squatting Pigeon like this.
  9. May 5, 2019 at 1:10 PM
    Runnerstrom28
    Runnerstrom28 Hail Hydra
    Derek
    14 limited blue ribbon tundra crewmax
    I took my truck to a local shop to have them install my Bilstein 5100s to lift the front of my truck and they said they couldn't do it because they didn't have a spring compressor big enough. So why didn't they just do what y'all are talking about?
    Hammerdog likes this.
  10. May 5, 2019 at 2:04 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Because it’s dangerous... go to a different shop. Most legit shops have a floor mounted or wall mounted spring compressor.... it’s not that special of a tool.
    Runnerstrom28[QUOTED] likes this.
  11. May 5, 2019 at 2:39 PM
    xtyfighterx
    Ty
    North Idaho
    It’s not dangerous at all I don’t see why you think that? You are releasing the energy of the spring while it’s still bolted on to the truck the spring has no where to go at all.
  12. May 5, 2019 at 3:10 PM
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    Yep, but one slip of a jack or lapse in judgement could be the end, ive done it many times on Tacoma’s ... but I still remember the first time. Most people don’t have a lot of quality tools or knowledge and this job can be dangerous. A shop probably ain’t going to do it this way because of liability.
  13. May 5, 2019 at 4:11 PM
    xtyfighterx
    Ty
    North Idaho
    You should have jack stands supporting the truck under the cross member and frame rail....if the jack gave out the only thing that will happen is your spring decompresses faster which again is still bolted to the truck and won’t go anywhere your LCA wouldn’t even hit the ground.I personally find more people using spring compressors wrong or getting hurt by them then this method. To each their own if I ran a shop I’d do it this way every time.
  14. Mar 2, 2022 at 6:31 PM
    kidked888
    kidked888 New Member
    Kansas
    2004 Tundra Double Cab 2WD
    Do you need to loosen lower control arms or steering rack on first Gen tundra?
  15. Mar 2, 2022 at 7:59 PM
    xtyfighterx
    Ty
    North Idaho
    I’d say everything from that video I’d do the same on a first gen. Shouldn’t be any different. Only thing different on the new tundra is the sway bar mounts I unbolted and took the skid off vs the Tacoma.
  16. Mar 2, 2022 at 8:06 PM
    kidked888
    Kansas
    I think on the Tacoma it was 2 bolts on the lower ball joints where’d it be all four on a tundra. I might see if that will give the lower control arm enough reach to get the decompressed strut assembly out.
  17. Mar 2, 2022 at 8:26 PM
    xtyfighterx
    Ty
    North Idaho
    Not sure on a first gen never worked on one but my 2015 is two bolts like the Tacoma.
  18. Mar 2, 2022 at 8:43 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    There is no debate. Best option, take them to a shop, easy and safe. If you must do it yourself - you tube, truck weight as a compressor. Or buy a used wall mounted compressor for $600, normally 1200.
    Amazon and rental strut compressors are a recipe for disaster on truck springs. I don't care who survived. You may not.
