DIY skid/cat plate
Discussion in 'General Tundra Discussion' started by Sumo91, Aug 4, 2021.
  1. Aug 4, 2021 at 11:01 AM
    Sumo91
    Sumo91 [OP] Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    Hey guys! I'm almost finished making my own skid/cat plate, just have to weld the flat bar on the side and drill some cooling holes, used a 4x8 piece of 3/16 steel that I cut in half, so the entire skid plate is 4ft long and covers both the front and rear cats. (front skid is coming soon with the extra 4x4 plate) and I was weighing my options on coating. I figured there are 3 options here.
    1. Powder coat -$150
    2. Spray paint -$50?
    3. Roll on or spray on bedliner -$75?
    While I'd like to powder coat it, I do a good bit of off roading and driving gravel roads, If it gets scratched, I'd have to touch it up with spray paint. The biggest upside for me is having someone else do the work coating it
    If I spray paint it, it will obviously be the cheapest option, and the least durable, but touch ups will be super easy.
    Bedliner would hold up good, but will also gouge on rocks and such, but touch up will also be easy to match
    Any opinions on this?
    20210802_180704.jpg 20210802_184657.jpg 20210803_124323.jpg 20210803_133051.jpg 20210803_133058.jpg
  2. Aug 4, 2021 at 11:09 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Nice work! I would go the spray paint route. I sprayed my valhallas sheild plates myself and it was cheap and actually came out nice. Just make sure to clean well and use a self etching primer then some kind of rust preventative spray. It would go nicely with your DIY spirit with the project. Plus like you said touch ups would be super easy, fast and cheap.
  3. Aug 4, 2021 at 11:11 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    Looks great! I just picked up a big scrap sheet of aluminum, so I'm watching. What did the width end up being?
    Is there just the 4 bolts holding it up? And is that crossmember by the lower control arms threaded, or did you run all the way through and put a nut on top?
    I'd do spray paint too, easy touch ups is a big thing for me.
    Sunnier and Sumo91[OP] like this.
  4. Aug 4, 2021 at 11:11 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    18' Toyota Tundra MGM Crewmax (Saibot)
    Toyota Tundra Pro Grill Lace On Steering Wheel Cover Garmin Tandem and Mini Dash Cam. Center Console Safe Compustar Remote Start with DM ESP Rear under storage VLED Front & Rear foot well LED Lights Sound Deadened Cab Toytec Boss Alumna lift at 2 inches C4 Hybrid Front Bumper with four sets of Baja Designs. AlphaRex Novas Valhalla's Skid Plates Switch Pro-9100 SPC Upper Control Arms 35" tires on RRW Agressive BMC/CMC to fit larger tires. Minor bumper and fender liner trimming.
    Powder coat is usually nice to have on anything that's not making a lot of contact. I'd say spray paint it and save yourself the time. You can save yourself the time doing the touch ups each time you do your oil change.
  5. Aug 4, 2021 at 11:11 AM
    Sumo91
    TN
    Thanks for the input! It's been a fun project, it also gave me a good excuse to get a new cordless Milwaukee grinder :D it took 8 danger dics, I mean, cut off wheels to get the job done.
  6. Aug 4, 2021 at 11:13 AM
    MadMaxCanon
    haha nice. still come out cheaper doing it yourself. I hope you were wearing safety glasses though!
    Sumo91[QUOTED][OP] likes this.
  7. Aug 4, 2021 at 11:13 AM
    OhEmmBee
    OhEmmBee Rick
    Richard
    Denver
    Agreed! Rust-Oleum or Steel-It in a can from SDHQ will have to be my best bet.
    Sumo91[OP] likes this.
  8. Aug 4, 2021 at 11:15 AM
    Sumo91
    TN
    It's 4ft wide near the rear of the truck. I took a sheet of corrugated plastic from home depot to pull measurements and make a template, definitely get a long straight edge if you wanna do this, I didn't have one so I had to use a chalk string. All the bolts go straight through the cross members with nylon lock nuts on top, the fronts are 1/2in x 4in, the rears are 3/8 x 4in. I'm still fabbing it up, so ill probably have more bolts and supports by the end of it.
    Sunnier and RepeatPete[QUOTED] like this.
  9. Aug 4, 2021 at 11:18 AM
    Sumo91
    TN
    Oh hell yes, safety glass, face shield, heavy duty jeans, and a long sleeve. I don't fuck around with cut off wheels. I also had the blade guard and handle attached. Just wish I hadn't left my respirator at home, that dust is terrible for you.
  10. Aug 4, 2021 at 11:28 AM
    MadMaxCanon
    Nice, safety first always. Theres been more than one matrix moment for me and those damn discs.
    BlueRibbon4x4 likes this.
  11. Aug 4, 2021 at 2:32 PM
    BrakeDust
    BrakeDust New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    I vote roll-on. Spray paint is pretty weak.
  12. Aug 4, 2021 at 2:45 PM
    Sumo91
    TN
    For anyone interested, I'm in Houston for the next few weeks, I should have everything complete by the end of today or tomorrow. If anyone wants to bring some cardboard, or anything to make a template of my plate, feel free to contact me. I know the guys who make these are really backed up with orders, so for anyone that doesn't want to wait and wants to make their own, just let me know and I'll provide my template. It's not perfect, but it works, and it's a skid plate, something you'll rarely ever look at, so looks aren't that important. I paid $316 after taxes for my 4x8 sheet of 3/16. And it's enough to make full skid plates for you truck. I'm sure 1/8 is even cheaper for those that don't off road.
  13. Jan 5, 2022 at 3:08 AM
    hotrod3367
    hotrod3367 New Member
    Rodney
    I know this an older thread, but could you post dimensions for your plate please. Im gonna give it a go.
  14. Jan 5, 2022 at 3:14 AM
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    A official welcome for your first post.... Welcome to the Tundra forum..
  15. Apr 28, 2022 at 5:18 PM
    homie817
    homie817 New Member
    Tuan
    TX
    TRD sport
    could you please post some measurements. Thinking of fabricating one. Thanks
