DIY rock slider project
Discussion in '2.5 Gen Tundras (2014-2021)' started by kevine0001, Mar 8, 2020.
  1. Oct 21, 2020 at 12:53 PM
    kevine0001
    kevine0001 [OP] New Member
    Kevin
    Nice job there. The detached outer tube IMO looks cleaner. I attached as I was copying the Demello sliders. But I used same tubing. 1/8" but with 1/4" plate for brackets and gussets. Actually, you going to gusset the inner tubes going to the mounting brackets? I did, only because I am NOT a fabricator so to be safe, I overbuild most of my stuff.
    Rica25 and BravoDeltaRomeo like this.
  2. Oct 21, 2020 at 12:58 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Fantastic job
    As a woodworker, I don't think I could pull off a DIY version. o_O
    Rica25 and Sweepcity like this.
  3. Oct 21, 2020 at 1:02 PM
    kevine0001
    Kevin
    I do some wood working also. It's not a DECKED system, but works for me. The center board comes out so that my 120 qt marine cooler fits perfectly in there without strapping down. Plus, by being at bed height, I don't have to lift a full cooler up another 8-10". Perfect for hunting and fishing.
    Rica25, Sweepcity and saybng like this.
  4. Oct 21, 2020 at 2:03 PM
    Sweepcity
    Sweepcity New Member
    Jeff
    2016 tundra limited
    Yes my plan is put gussets on the mounting tube to the bracket. The only reason is, like you, I am bolting them on. So to provide more strength and to prevent flexing I am doing the same.
    Rica25 likes this.
  5. Oct 21, 2020 at 2:05 PM
    Sweepcity
    Jeff
    2016 tundra limited
    hahahhahaha as a woodWorker you have got to be spot on all the time. Working with steel I can always bring it back to life when, not if, I screw up!
  6. Oct 21, 2020 at 4:51 PM
    Sweepcity
    Jeff
    2016 tundra limited
    Well I have them mocked up to the body. Ready for some final measurements before making making a mistake on its lines and what not. image.jpgimage.jpg image.jpgimage.jpg
    Rica25 and saybng like this.
  7. Oct 21, 2020 at 4:56 PM
    Sweepcity
    Jeff
    2016 tundra limited
    I am no fabricator. So measuring where I should be measuring and looking where I should be looking I guess I don’t have the eye or in my head I thought it was different. I kind a like it now that I’ve been looking at it but it comes out quite a bit it’ll definitely stop a shopping cart from hitting my truck within the area of them.image.jpg
  8. Oct 22, 2020 at 9:17 AM
    kevine0001
    Kevin
    Oh, I thought the longer tube would be the outer tube. No?
    Rica25 likes this.
  9. Oct 22, 2020 at 11:00 PM
    Sweepcity
    Jeff
    2016 tundra limited
    No I wanted the longer tube to run the length of the body from front of rear fender well, to the rear of the front fender well. With the shorter tube to the outside for a solid platform to step on to exit and enter .
    Rica25 likes this.
