DIY: Replace Clockspring/spiral cable + remove steering wheel
Discussion in 'General Tundra Discussion' started by csuviper, Jun 3, 2018.
  1. Jul 4, 2022 at 1:47 PM
    #61
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I replaced my clockspring with an OEM 300.00 unit, followed the videos & instructions I found 100% spun the clockspring until there was resistance, spun it back, counted 5 turns (it said 5 turns on it) & spun it back 2.5. Need to figure it out, I have a total of 3 16.00 eBay CS coming but prefer to only use 1.
    Has anyone used these eBay CS? it looks like it has a lock I'm hoping is the center.
    #61
  2. Jul 5, 2022 at 2:18 AM
    #62
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    I only paid like $13 bucks for mine off ebay. It was the cheapest option and it worked. I had horn and cruise not working. But after putting the clock spring in both worked flawlessly. I would get the absolute cheapest one you can find. I am sure they are coming fron the same factory.
    Install was easy.. You can see the many videos online. Loosening the steering bilt was easy. Just mark it before you pull your steering wheel for realignment. Good luck.
    #62
  3. Jul 6, 2022 at 1:28 PM
    #63
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Thanks guys.
    I just installed the one I linked previously.
    It is already pre-aligned using that break off tab and went right in straight.
    OEM one should also be pre-aligned with a break off tab I would think, you shouldn't need to turn or adjust anything if your wheel is straight during install, all plug and play for mine.
    Some of the plugs shown in videos did not even need to be removed for the clock spring part itself.
    Didn't even need a wheel puller, just wiggled it and it popped free.
    It took longer to go to the store and find some whiteout to mark the wheel/spindle alignment than it did to change this part.
    Just unplug your battery first ;)
    Now my horn works as normal again, and all my other steering wheel controls still do also.
    We will just have to see how long this knock-off part lasts :thumbsup:
    #63
    Thumper_6119 likes this.
  4. Jul 6, 2022 at 8:19 PM
    #64
    baraynavab
    Atlanta
    Bro.. @Seafury just use masking tape on the steering wheel and put the alignment marks using a pen/pencil on the tape.. no need to go to the store for whiteout.. also now that I think about it.. just use a pencil to mark the two... that would work too..
    ooh for sure before doing anything make sure your steering is 100% straight and accurate.. and you are absolutely sure you have disconnected the battery and turn our your lights after just to ensure you have no residual charge from the battery.
  5. Jul 9, 2022 at 9:21 AM
    #65
    Seafury
    Agent K
    SC Low Country
    You are right, hindsight is 20/20 lol
    I could have used a sharpie I already had, but anything less permanent I would worry the marks get wiped away by accident.
    I needed the whiteout for marking stuff anyway, no worries :thumbsup:
    baraynavab[QUOTED] likes this.
  6. Nov 10, 2022 at 11:53 AM
    #66
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    I'll be undertaking this DIY soon cause my horn is toast. The write up seems perfect and i'm sure i could figure it out once i get started but where are you all making your marks to make sure the steering wheel lines back up for reinstall.
    Edit:
    Is this the correct part number?
    OE/OEM Part Number:
    84306-0E010
  7. Nov 10, 2022 at 1:39 PM
    #67
    baraynavab
    Atlanta
    Lol just see some videos on YouTube man.
    The mark is between the steering wheel and steering column. Once you are done replacing the clock spring. You need to align the steering wheel with the mark on the steering column so your steering alignment isn't off.
  8. Nov 10, 2022 at 1:51 PM
    #68
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    Yeah I watched a few plus the ones on the 1st page of this thread, still wasn't quite clear from anything i saw. Appreciate the clarification.
  9. Nov 10, 2022 at 1:55 PM
    #69
    baraynavab
    Atlanta
    Also
    You'll probably say that you cannot make a mark since it's plastic/metal. So to easily put a mark on it just put a tape on the steering column & steering. And put the mark on the tape via pencil or pen. Easy peesy lemon squeeze.
    GSil[QUOTED] likes this.
  10. Apr 20, 2023 at 10:18 PM
    #70
    steelgtr
    steelgtr New Member
    Bob
    Is there a tutorial like this for a Gen 1 (2000) Tundra?
    thx
    bob
  11. Sep 10, 2023 at 7:22 AM
    #71
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    So i ordered my replacment and after installing, the first time i turned the steering wheel it seems the new clockspring broke. Any ideas why?
  12. Sep 11, 2023 at 8:25 AM
    #72
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    Nevermind, im fairly sure i know what i did wrong.
    Note to others:
    Don't pull the orange tab that locks the rotation of the clockspring until after you install it onto the column. if it is not in the right position when installed it will break and unravel once you turn the steering to full lock.
    baraynavab likes this.
  13. Sep 12, 2023 at 6:42 PM
    #73
    BeardedTundra
    BeardedTundra Shr3k
    Justin
    2006 Sequoia Limited 4x4
    Big mods are coming soon, but not too soon.
    Good write up and information. Thank you.
  14. Jan 8, 2024 at 11:58 AM
    #74
    Kamyoda17
    Kamyoda17 New Member
    British Columbia
    ‘21 sr5 off-road
    Bilstein 5100s. 285/70r18
    Does anyone have a listing on Amazon for 2018-2021 clock spring?
    I keep finding the 84306 which lists up to 2014 tundra/tacoma/corolla/camry.
    Toyota lists 2018-2021 as 84307.
    Or should they all be the same?
    pretty sad this thing didn’t even make it 3 years.
  15. Jan 8, 2024 at 5:22 PM
    #75
    baraynavab
    Atlanta
    Seeing your picture.. it looked like it was a botch install.. and you caught your mistake. Good going..
    At least your honest about your mistake.
  16. Jan 14, 2024 at 3:30 PM
    #76
    SF1973
    SF1973 New Member
    2013 Tundra Rock Warrior
    Know this is a really old thread, but thank you to the OP for this. Just did mine in a "new to me" 2013 Rock Warrior. Was hesitant to buy without a working horn, but this went smoothly.
    GSil likes this.
  17. Jan 14, 2024 at 6:11 PM
    #77
    Darren509
    Darren509 New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Has anyone here taken the steering column apart any further than the clock spring? I have to replace the shifter and was hoping to see a how to first?
  18. Feb 9, 2024 at 4:32 PM
    #78
    supermansam2
    supermansam2 New Member
    Wish me luck!
  19. Feb 13, 2024 at 3:55 PM
    #79
    steelgtr
    steelgtr New Member
    Bob
    If I pull back on the bottom of the wheel and keep pressure, my horn works perfectly. If not pressing like that, it's very intermittent, mostly not at all. Ideas?
  20. Feb 13, 2024 at 3:56 PM
    #80
    steelgtr
    steelgtr New Member
    Bob
    Does this seem like a clock spring issue?
  21. Feb 14, 2024 at 9:14 AM
    #81
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    Possibly, does the horn work fine when you hold the alarm button on your key fob?
  22. Jul 2, 2024 at 5:58 PM
    #82
    Jamesmay85
    Jamesmay85 New Member
    James
    2008 Toyota Tundra LTD
    I found on on Amazon and just ordered it, I replace my stock today and my cruise still won't come on so guess this is the next "poke and hope" (saw it on a other post) if this doesn't work guess I'll have to find a mechanic
  23. Jul 8, 2024 at 11:48 AM
    #83
    GSil
    GSil New Member
    2013 SR5 DC Tundra
    this should do it, good luck
  24. Jul 9, 2024 at 11:40 AM
    #84
    Jamesmay85
    James
    Thanks a bunch I hope this fixes my cruise control, I'm just waiting for it not to be 90° outside to do it
    GSil likes this.
  25. Mar 1, 2025 at 8:56 PM
    #85
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    another pat on the back for OP, this was a great write up with great photos. made it super easy. i bought an OEM unit, followed OP's directions, then watched a video to confirm everything. super easy job. dude in the video was throwing his airbag piece around without a care in the world. i was a bit nervous! all good. i have my cruise control back, but my airbag light is still on. any thoughts?
    thanks again!
  26. Jun 12, 2025 at 2:06 PM
    #86
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Is there a way to troubleshoot down to the clockspring without replacing it? More so, if the clock spring is faulty, what other things could potentially be affected? The "low tone" horn went first on mine, then the "high tone".
  27. Jun 12, 2025 at 3:44 PM
    #87
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Mine was "diagnosed" when I took it to a shop for state inspection. The horn wouldn't work from the steering wheel, so the guy connected a tablet (I'm assuming TechStream or the like) and fired off the horn from there. It wasn't the horn or a fuse. He said it was the clockspring most likely, and he said that it was easy to switch DIY rather than paying someone else to do it. He was correct on all counts.
  28. Jun 13, 2025 at 2:28 PM
    #88
    grave
    grave New Member
    SD CA
    2007 4.7 SR5 4X4
    just be sure to check your steering wheel placement before you take the rental back to o'reilly!
