DIY: Replace Clockspring/spiral cable + remove steering wheel
Discussion in 'General Tundra Discussion' started by csuviper, Jun 3, 2018.
  1. Jun 1, 2019 at 7:30 PM
    Supertundra2014
    Supertundra2014 New Member
    2014 SR5 Double Cab
    So if anyone with a 3rd generation tundra is wondering, this DIY is an excellent guide. Now my horn works again!!!
    831Tun and osidepunker like this.
  2. Jun 3, 2019 at 4:46 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    Well I just realized that the clock spring and steering angle sensor are two different parts. My horn doesn't work so I definitely need to replace my clock spring, but my VSC problems are the real priority.
    831Tun likes this.
  3. Jun 27, 2019 at 8:07 AM
    Bgsxrunner
    Bgsxrunner New Member
    New Mexico
    2012 Black Toyota Tundra Crewmax Platinum 5.7 4WD
    Pretty much everything
    Call a dealer with your vin and confirm part numbers before ordering. Toyota likes to change shit in the middle so even though an 07 looks the same as a 13 sometime they change pin locations and shit like that. The process will be the same but the pins may be different. Plus it’s free to call the dealer and ask. Return shipping not so free
  4. Jul 5, 2019 at 8:54 PM
    MoabDaveRules
    MoabDaveRules New Member
    I just changed mine and the hardest part was unhooking the yellow airbag plug on the clock spring. The second video had a great blow up of the 2 step process( thanks deamon machine!) I was about to break the plug so I went back to directions and watched the "helpful videos". Horn works again, tomorrow the test drive.
    Excellent step by step.
  5. Sep 6, 2019 at 2:58 PM
    Dominator391
    Dominator391 New Member
    Kevin
    2013 Crewmax
    None
    My gown works part of the time. Would it still be this part, or if it was the clockspring would it not work at all?
  6. Sep 6, 2019 at 3:20 PM
    MoabDaveRules
    As my gown, or possibly horn, autocorrect and all that, was going it, I would open the hood, fiddle with wires up there, and it would work again. Finally that didn't do it so I replaced the clock spring a month or so ago and it's still working fine. Be sure and watch the video that shows you how to unplug the wires underneath, the yellow plug needs a push from the back...
  7. Oct 22, 2019 at 8:54 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Looks like I get to add this to my list of stuff that has failed early on my Tundra. Horn only works when the steering wheel is turned to the left. I am first going to see if the dealership will do this under my platinum warranty, which expires in May of next year. If they don't do it, I will replace it myself with a cheaper unit. Thanks to the OP for the write-up.
  8. Oct 27, 2019 at 5:43 PM
    68vert
    68vert New Member
    AZ
    2011 Rock Warrior
    csuviper[OP] likes this.
  9. Nov 1, 2019 at 8:40 AM
    showtime240
    showtime240 New Member
    Just a heads up, the Clock Spring is also connected to your SRS/Airbag
    For some reason, I do not trust a $8 - $40 Chinese replica Clock Spring to be in charge of my Airbag that is in my face hahaa
    I just ordered the OEM Clock Spring part from Roman @Toyota of Cool Springs. The total was $230 shipped.
    I know it is a big difference.... :spending:
    Bong808 likes this.
  10. Nov 1, 2019 at 9:28 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    For those that have removed steering wheel/clock spring - do you have to pay attention to the alignment of the clock spring for the reinstall?
  11. Nov 1, 2019 at 10:01 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    I paid like $7 on ebay. It's an oem Toyota part. Probably a pirated shipping container haha but I don't know that for sure...
    831Tun likes this.
  12. Nov 1, 2019 at 11:53 AM
    showtime240
    Haha no way it is an OEM part for $7..... you can not even get a OEM TRD decal for $7 :notsure:
  13. Nov 1, 2019 at 11:58 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You can decide for yourself:
    20191101_115637.jpg 20191101_115656.jpg 20191101_115701.jpg 20191101_115707.jpg
  14. Nov 1, 2019 at 12:07 PM
    showtime240
    Definitely looks legit.
    But I cant trust if it is a replica.
    I'll take pics of the OEM one I ordered once it comes in next week
  15. Nov 1, 2019 at 12:15 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    For $7 I'm gonna plug it in and see what happens
    Jrharvey02 likes this.
  16. Nov 22, 2019 at 2:57 PM
    Terrye
    Terrye New Member
    Hey, really could use some help. Lost the screws for the clock spring and new one doesn't come with them. Can anyone tell me the width and length of the screw possibly with a pic?
  17. Nov 27, 2019 at 11:31 AM
    glowblue
    VA
    Do you mean the screws for the steering column shroud/cover? The clockspring doesn't require screws - it snaps into place via 3 alignment tabs.
  18. Dec 14, 2019 at 10:05 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
    Thanks for the write up. Made that an easy job.
  19. May 26, 2020 at 10:47 AM
    #49
    Bloomjtundra
    Bloomjtundra New Member
    Josh
    2011 Tundra DC 4x4
    Does anyone happen to know what the torque spec for the steering wheel nut should be? I’m about to put mine on and would like to torque it properly.
  20. May 26, 2020 at 7:52 PM
    #50
    BRMTex
    BRMTex New Member
    Craig
    2014 BRM Tundra TSS Off Road
    I found this in an earlier post. Looks like it should be 37 ft lbs.
  21. May 27, 2020 at 1:37 AM
    #51
    Bloomjtundra
    Josh
    2011 Tundra DC 4x4
  22. Jul 22, 2020 at 2:51 AM
    #52
    Bong808
    Bong808 New Member
    Bo
    2008 Tundra Dbl Cab
    Thank you to the OP. It made this job much easier. I went with the $230 part. Don't trust an $8 to $40 part with airbags. The reason I changed it was my cruise control had stopped working. Hope it goes another 200,000 before I have to do it again.
  23. Jul 22, 2020 at 4:02 AM
    #53
    Rubberdown
    Just a tech tip. After you take the nut iff, but before you remove the wheel. Draw a straight line with a sharpie from the center of the steering shaft Out onto the metal surrounding the splines. Easy to realign wheel and That way the wheel will be EXACTLY where it shouOf be when you put it back. I have now done this twice on my wife’s 4Runner. I was one spline off, which was annoying and I didn’t figure it out till I drove it.
  24. Aug 14, 2021 at 1:21 PM
    #54
    Thumper_6119
    Thumper_6119 I've seen things you people wouldn't believe.
    2011 Toyota Tundra SR5 Texas Edition (Crewmax) 4x4
    Just did this today using @csuviper ‘s instructions. Took me 25 minutes, start to finish. Thank you for the write up!
    My horn stopped working, and I had it tested with TechStream. Horn actually works, but the clock spring finally wore out. Rented a steering wheel puller from Advanced Auto (KEEP YOUR RECEIPT! You buy the kit, then they give you a refund if/when you return it. $32). Got my clock spring off of PartsGeek. Followed csuviper’s instructions to the letter. Horn works, and all steering wheel controls work. Inspection due next month, and I’m good to go. Saved $650+ by doing it myself instead of taking it to a shop.
  25. Aug 14, 2021 at 5:02 PM
    #55
    glowblue
    VA
    Hats off to you for searching the forum and using the vast wealth of information available! Glad you got it working. :thumbsup:
    NewImprovedRon and Thumper_6119 like this.
  26. Aug 15, 2021 at 3:04 PM
    #56
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    My volume up on my steering wheel is intermittent, gonna see if this can fix it. Has anyone taken their old one apart to see if it could be repaired?
  27. Jun 27, 2022 at 1:02 PM
    #57
    Seafury
    Seafury Kickin names, and takin ass!
    Agent K
    SC Low Country
    2014 White 1794 "SnowWhite aka the Frost Queen"
    Bilstein 6112/5160, 3 CB front shims, SPC UCA's, CB +3 rear Shackles, total 3/2 lift, Dif drop, CB Carrier bearing drop, Fortin Evo One remote start from Tech12volts PnP, AMP research Powersteps PnP, Vent shades, Tinted windows, Black/Red lined cupholder inserts, Proclip USA dash phone mount with Scosche Magic Mount wireless magnetic phone charger, Stock wheels/tires for now.
    Hello gang.
    Sorry, I need to resurrect this thread!
    Out of the blue my horn only works when the wheel is turned sharply, as of about a week ago.
    It does nothing when the wheel is straight (which is most of the time)
    Needless to say, this is a major problem as I need my horn (and to upgrade my actual horn) almost daily where I live.
    Those who have used these cheap knock-offs, anything to report?
    I am in a financial jam atm and don't have $250 to pay Toyota for their ripoff part that should never have failed.
    I am about to order one of these knock-offs, but hoping someone can tell me some good news (or bad) before I waste the effort to do this repair.
    Also the postings for these knock-offs all seem inaccurate, most say they do not work for my 2014 1794 edition 4x4 gas engine.
    Yet the part numbers seem to match OEM Toyota parts listings for my exact truck.
    https://parts.sparkstoyota.com/p/To...L-SPIRAL-WITH-SENSOR/62968498/843060E010.html
    2004-2018 Toyota Cable Sub Assembly Spir 84306-0E010 | Toyota of Cool Springs vParts
    This is one of the listings I am considering buying.
    https://www.ebay.com/itm/175258735154
    Any feedback and advice is welcome, thank you.
    #57
  28. Jun 27, 2022 at 1:24 PM
    #58
    PSYCHO WHITE TUNDRA
    PSYCHO WHITE TUNDRA Still Gonna Send It...
    Jake
    New Mexico
    White 2011 Tundra SR5 TRD (Psycho White)
    Chopped and dumped dual exhaust; 6" fully adjustable ProComp lift w/ FabTech rear shocks, 12.5x20 Pro Comp rims on 37x12.50x20 tread wright mud tires, pedal commander throttle programmer and sound system from hell which consist of Sony double din headunit, 4 Morel Maximo Ultra 603 component door speakers w/ 4 tweeters ran on a Rockford fosgate P500-4 punch amp under drivers seat then the bass comes from a custom 15” 4000rms sub made from a Skar 15” Skar basket and motor with sundown x series components made by Patrick @ Robot Underground in Mesa AZ which is powered by 2 C.A.B. Audio 2000.1D amps strapped together at .08ohm which produces just under 5000rms. Also installed 100sq.ft. 10mil dynamat sound deadening on all 4doors (both exterior and interior chambers) double layer on roof and back wall as well as inside side mirror covers and behind side mirrors
    The only issue I had with mine was it only lasted approx 16 months but hell for $8 I don’t mind replacing it every 16 months. Other than that it worked flawlessly
    #58
    Thumper_6119 and Seafury[QUOTED] like this.
  29. Jun 27, 2022 at 4:39 PM
    #59
    Thumper_6119
    I am at 1 year in with mine, and mine is still doing fine.
    I paid considerably more for mine than others did, apparently. Lol. I got mine here: https://www.partsgeek.com/gbproducts/WC/26814-01379741.html. (I still made out better than going through the Toyota parts house or having someone else do the work).
    #59
  30. Jun 28, 2022 at 8:46 AM
    #60
    Seafury
    Agent K
    SC Low Country
    Thank you both for your advice and experiences.
    I will likely go with one of these cheap knock-offs for now out of necessity.
    I will let you all know how it goes in a week or so once I get this done.
    Thanks!
