DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. Jul 13, 2018 at 9:18 PM
    #121
    csuviper
    csuviper [OP] Moderator Staff Member
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    NUDRAT and GodlessPro like this.
  2. Jul 13, 2018 at 9:30 PM
    #122
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
    This is my next mod
    GodlessPro likes this.
  3. Jul 14, 2018 at 9:07 AM
    #123
    Travo60
    Travo60 New Member
    Travis
    Austin, TX
    2018 Limited CM Cement
    Anyone have a picture showing how they mounted the ARB behind the tail light?
  4. Jul 14, 2018 at 10:09 AM
    #124
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
  5. Jul 14, 2018 at 11:10 AM
    #125
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Exactly what mine looks like.
    GodlessPro and JMB[QUOTED] like this.
  6. Jul 14, 2018 at 4:11 PM
    #126
    Sunnier
    Sunny
    San Diego, CA
    I just moved the same that was attached to the rear diff, plugged it into the end of the tubing farthest from the diff.
    I've been reading along, about vaccuums and seals drawing in water... and that doesn't seem logical to me. Am I missing something?
    dcsleeper408 likes this.
  7. Jul 16, 2018 at 9:48 AM
    #127
    csuviper
    Broomfield, CO
    Heating up the gear oil will cause pressure on the inside of the axle housing. That pressure is released through the vent. When cooled quickly like taking a dunk in a stream will cause rapid cooling and pressure to decrease in the housing. Since the vent is only one way it will seal up which creates a vacuum effect. The air will try to get into the housing in the weakest link to even out the air pressure. The weakest link is the axle seals. This is how water can get in if you are submerged.
    I like the fuel filter idea because its splash resistant. Keeps the filter media dry. What vehicle is that one from?
    15whtrd and Sunnier[QUOTED] like this.
  8. Jul 16, 2018 at 10:29 AM
    #128
    Over the LINE
    New Orleans
    Here's mine. I just used a universal fuel filter, if that was your question.
    kparrow likes this.
  9. Jul 16, 2018 at 12:21 PM
    #129
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    With a filter at end the diff is open.
    Breathers act like a check valve. Reason for 1 way-2way breathing.
    Having that open end filter pointed down towards the bumper dissipates placing the breather at the highest point. It’s higher than normal, but I would be more concerned since it’s open at the end and pointing down.
    If I were to run a filter it would be more an in-line filter with a breather still at the end.
  10. Jul 16, 2018 at 12:35 PM
    #130
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I haven't gotten this done on my new truck yet, but I'm thinking of doing exactly that, filter inline with the 2-way breather on the end.
    dcsleeper408[QUOTED] likes this.
  11. Jul 16, 2018 at 12:41 PM
    #131
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    That works! My buddy did the same. For 60k nothing through filter. But for $10 I don’t see anything wrong adding the inline filter. I just wouldn’t leave a open end filter at the end.
    I believe the oem is 2way. When I pulled it off I was able to suck and blow through it. I have to look for it and try it again. Reason was for this mod is to relocate it.
    Sunnier and GodlessPro like this.
  12. Jul 16, 2018 at 1:49 PM
    #132
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    I've had my diffs submerged probably a dozen times, a few times were for a few minutes. There hasn't been any water seeping through my seals. I'm not saying it won't happen either.
    TTund16 and dcsleeper408 like this.
  13. Jul 16, 2018 at 1:56 PM
    #133
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Yeah. My Tacoma took a few dips before a few buddies explained to me how it works and what it does if not relocated.
    This is not necessary but it’s great insurance. Replacing seals are a pain in the ass.
    Shadowfax1 and trayday like this.
  14. Jul 16, 2018 at 1:59 PM
    #134
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Even with my diff breather I still had my tundra flushed out after it was submerged in mojave and no water made it through.. More peace of mind for me.
  15. Jul 16, 2018 at 2:06 PM
    #135
    csuviper
    Broomfield, CO
    Well if the OEM is really a 2 way then you can reuse it in a higher location and the whole vacuum thing through the axles is not accurate.
    Sunnier and dcsleeper408[QUOTED] like this.
  16. Jul 16, 2018 at 2:16 PM
    #136
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    if the breather is submerged(highly likely in oem location), where else would it breath through. Seals would be the next thing in line.So you have the right mindset. Relocating the oem one is fine. I know tons of people that did that no issues and they dive in a lot more often, some almost mid way of the door.
    It’s really not rocket science for the most part. You are just relocating the OEM breather up higher. At oem location they are prone to be submerged. Potentially sucking water through the breather it self and or through the seals.
    It’s a cheap mod.
    joonbug, Sunnier and GodlessPro like this.
  17. Jul 16, 2018 at 3:26 PM
    #137
    Over the LINE
    New Orleans
    If I start sucking fluid from the height of my breather relocate, I'll get the diff flushed and filled along with a few other things. That assumes I don't have fried electronics and a totaled truck.
  18. Jul 16, 2018 at 3:40 PM
    #138
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Also if you take in water from oem location seals can blow outward- as if over flowed. If that makes any sense.
    joonbug likes this.
  19. Jul 16, 2018 at 8:29 PM
    #139
    Pale_Horse
    Pale_Horse Sooooooooo White.
    FL
    White 2013 TRD OR 4x4 DC
    Cupcake chit.
    Thanks guys for posting the fuel filter idea. Genius. Saved me $60 on the ARB kit...
    Will Be sure to swap it out before next wheeling.
    NewImprovedRon and dcsleeper408 like this.
  20. Jul 17, 2018 at 5:28 PM
    #140
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    I had originally just relocated the factory breather to behind the taillight, but while relocating it, like others, I noticed it was just basically a check valve and didn't like that, so I used an intake air filter from a viair compressor. I found the filter online for something like $12-$15. In total I'm in it for about $30, for the fitting, hose, and filter.
  21. Jul 19, 2018 at 3:45 PM
    #141
    lionix
    I picked up an Arb one for $58 bucks. I can't beat that, and I get their breather.
  22. Aug 28, 2018 at 1:19 PM
    #142
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  23. Apr 6, 2019 at 1:26 PM
    #143
    jptshadow
    jptshadow New Member
    Does the front differential have breather like that too?
  24. Apr 6, 2019 at 1:34 PM
    #144
    Sas
    OKC, OK
  25. Apr 6, 2019 at 2:03 PM
    #145
    jptshadow
    csuviper[OP] and Sas[QUOTED] like this.
  26. Apr 6, 2019 at 2:52 PM
    #146
    Sas
    OKC, OK
    Yeah, it never ceases to amaze me what a treasure trove of information this forum is.
  27. Apr 6, 2019 at 3:50 PM
    #147
    Dr_Al
    Dr_Al New Member
    Al
    Wow, lots of overkill. First off the breather is not two way. It's nothing more than a rubber disk with a spring on top of it. The spring pushes up on the cap and down on the rubber seal against the metal base. It only vents pressure in the diff. Back in the day all we would do is remove the sheet metal cap and put a rubber hose on to the part that's left. The cap is sort of crimped on so the base already has a lip for a hose to go over. Put a hose clamp on it and the hose wont go anywhere. As for the other end we would simply make a full loop in the hose and then point the end going down as high up as possible. As long as the loop is vertical it's not going to suck up any water. That's when I was into mud and often had the rear axle a foot or more under muddy water.
    Now that I don't do that anymore I just simply twist the cap once a year until it spins freely is all that's needed. The cap should feel very loose.
    drew.c.114 and TTund16 like this.
  28. Apr 8, 2019 at 12:05 PM
    #148
    csuviper
    Broomfield, CO
    For my 2019 i was just going to buy this kit from Toytec rather than sourcing all the parts from various places again.
    lionix and 15whtrd like this.
  29. Apr 23, 2019 at 11:31 AM
    #149
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I was looking at that too but hose seems a little short. Did you get it?
  30. Apr 23, 2019 at 1:48 PM
    #150
    csuviper
    Broomfield, CO
    Have not got it yet. Might need to do some measurements to see how long we really need compared to what is provided there.
