DIY: Rear Differential Breather Mod
Discussion in '2nd Gen Tundras (2007-2013)' started by csuviper, May 25, 2016.
  1. Sep 8, 2022 at 3:56 PM
    #271
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    csuviper[QUOTED][OP] likes this.
  2. Sep 8, 2022 at 4:09 PM
    #272
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Thank you! I ordered 25 of them from Amazon and they fit perfectly.
    ToyoD[QUOTED] and bulldog93 like this.
  3. Sep 16, 2022 at 7:44 AM
    #273
    CaptRussia253
    CaptRussia253 New Member
    Ruslan
    Just ordered the oem housing and filter.
  4. Sep 16, 2022 at 7:59 AM
    #274
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Those are nicer than my zip-ties... but I dont want all of the other zip-ties under the truck to feel inferior, so they shall remain
    Army_of_One and PomDad[QUOTED] like this.
  5. Sep 16, 2022 at 9:35 AM
    #275
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    I mean, realistically... it's pretty overkill. I'm pretty sure even if the hose was free floating it would probably be fine for a very long time.
    ...however, you do get to look cool to a bunch of truck bros on your favorite forum though... :yes:
    D4x4TRD, Hotwire and CaptRussia253 like this.
  6. Sep 16, 2022 at 7:54 PM
    #276
    Spyker
    Spyker I’m a dude,playin a dude,disguised as another dude
    do you have a link to that clamp?
  7. Nov 4, 2022 at 6:18 AM
    #277
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    FIY gentlemen/ladies.. I wanted to find out what is the thread pitch of the OEM rear differential breather. It is M10-1.0 pitch. I wanted to find out because I wanted to get a brass coupler/nipple to run the breather tube up to the rear tail light or the gas cap.
    My thought is to get a M10-1.0 8mm brass coupler and use a 5/16'' ID rubber/vinyl tube to run to the rear tail light or the gas cap. Probably need 6ft max in tube length.
    My truck btw is 2007 Toyota Tundra SR5 4x4 5.7l Crewcab. I think all the other trucks would be similar, at least for this Generation.
    Also to take the breather out you need a 14mm long socket.
    OEM Toyota Breather thread pitch -
    What the Brass Coupler looks like. You need a M10-1.0 8mm (5/16'' = 7.9mm)
  8. Nov 4, 2022 at 6:22 AM
    #278
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    I thought that fitting was an MPT (Male Pipe Thread)?
    Toyotadoug likes this.
  9. Nov 4, 2022 at 6:25 AM
    #279
    baraynavab
    Atlanta
    @Gaston It might be Male Pipe thread.. dont know.. does it matter if its Male pipe thread and a M10-1.0? I don't have any idea on pipe thread standards...
  10. Nov 4, 2022 at 6:33 AM
    #280
    Gaston
    Gaston New Member
    Gary
    SE MI
    It would matter if that fitting is in fact a pipe thread, I didn't looked when I did mine but I can look at the old fitting when I get home a bit later. An M10x1.0 is a standard fine pitch straight thread while a pipe thread is tapered. A pipe thread is tapered and as you tighten it the threads seal the fitting. A straight thread doesn't seal itself and instead uses flat mating surfaces to create a seal. Again, I didn't pay attention to the fittings when I did mine as I just bought OEM Toyota fittings but I will look at my original fitting when I get home.
  11. Nov 4, 2022 at 6:48 AM
    #281
    baraynavab
    Atlanta
    @Gaston I appreciate your explaining to me what is the difference between M10-1.0 and Male pipe thread.
    Btw is Male pipe thread also = NPT or BSP?? just asking for a friend :anonymous: ;)
  12. Nov 4, 2022 at 6:54 AM
    #282
    Gaston
    Gaston New Member
    Gary
    SE MI
    No problem!
    yes, MPT and FPT are the same as NPT. NPT is actually the standard by which these threads follow, MPT and FPT are just used to denote if they are male or female.
    As for BSP, I don't recall off the top of my head but I'm pretty sure the angles of the threads are different between BSP and NPT, not meaning the tapered amount but the actual thread form itself. I don't think they are interchangeable either, I'd have to look through my handbook if you'd really like to know. I work more with straight threads than anything.
    baraynavab likes this.
  13. Nov 4, 2022 at 4:19 PM
    #283
    Gaston
    Gaston New Member
    Gary
    SE MI
    @baraynavab I looked at my original vent valve and the threads are tapered. I checked the threads with a 1.0 pitch gauge just for fun and it is close but it’s not quite the same, probably close enough you were able to thread it in. It checks really close to a 1/8” NPT thread so if I was buying a fitting that’s what I would get and double check it against the original.
  14. Nov 7, 2022 at 2:09 PM
    #284
    baraynavab
    Atlanta
    Gaston, Spyker and WVI like this.
  15. Nov 8, 2022 at 4:15 AM
    #285
    Gaston
    Gaston New Member
    Gary
    SE MI
    So can I ask why not just go with the OEM part at that point? I can get it from my local dealer for $8.83 + tax.
  16. Nov 8, 2022 at 5:25 AM
    #286
    baraynavab
    Atlanta
    LOL I need a few of them which is why.. need them for my Land cruiser as well.. its got 3..
    BTW the Tundra 4x4 only has 1 or will it have one up front on the transfer case as well? if it does I'll need another one...so in all I may have to get 5..
    also I am thinking of doing the 1/8 NPT to 5/16 barb.. dont think it makes any difference but its just a little bit bigger than 1/4 size hose.
  17. Nov 8, 2022 at 5:37 AM
    #287
    COTundie
    Trey
    Pretty things
    4x4 tundra has two breathers under the hood for the front differential and either the transfer case or tranny, but they are allegedly up pretty high on the firewall already.
    Don't imagine a larger barb would be an issue. Just need larger tubing I suppose.
    baraynavab[QUOTED] likes this.
  18. Nov 8, 2022 at 5:47 AM
    #288
    baraynavab
    Atlanta
    Hey @Gaston and others - Question on breathers - Do the breathers allow air to go in and out? when hot and cold.. like really breathe like they way humans do? or is the breathing only done one way? to exhale out? so when the differential is hot the breather only allows the air to exhale out?
    I am asking because if breathing is only one way there is a one way valve (see below) that can be put in to further ensure you are not getting any water from entering the differential system. These valves are pretty cheap as well and come in different sizes so you can put them in line.
  19. Nov 8, 2022 at 6:05 AM
    #289
    Gaston
    Gaston New Member
    Gary
    SE MI
    gotcha
    as already started, the front already has them relocated as seen by this post
    https://www.tundras.com/threads/diy-rear-differential-breather-mod.5253/#post-75244
  20. Nov 8, 2022 at 6:22 AM
    #290
    COTundie
    Trey
    Pretty things
    The factory breather seems to only be a 1 way valve. Out not in.
    Some people replace the 1-way with those little crank case breather filters (at the end of their extension). I kinda figure Toyota made it a 1-way for a reason and just kept the factory piece on the termination behind my taillight.
  21. Nov 8, 2022 at 6:33 AM
    #291
    Gaston
    Gaston New Member
    Gary
    SE MI
    My understanding is they are more of a check valve than an actual breather. They allow air to escape from the diff housing as it heats up and builds pressure.
    WVI likes this.
  22. Nov 8, 2022 at 6:17 PM
    #292
    WV_Warrior
    WV_Warrior New Member
    Cody
    West Virginia
    2021 CM TRD Sport
    Thanks for the write up!
    csuviper[OP] likes this.
  23. Nov 20, 2022 at 5:43 AM
    #293
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
  24. Nov 20, 2022 at 5:55 AM
    #294
  25. Nov 20, 2022 at 6:47 AM
    #295
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    OH! I just bought a 5/8" hose clamp from Lowes! They come in two packs. I used 3/8" oil hose, so ymmv if you used something of a different ID.
    Here's a link to the one I got!
  26. Nov 20, 2022 at 6:50 AM
    #296
    Thanks for that!
    PomDad[QUOTED] likes this.
  27. Nov 20, 2022 at 6:57 AM
    #297
    PomDad
    Conrad
    Atlanta
    2021 Cement Limited
    You're welcome!
    Better late than never lmao
  28. Nov 20, 2022 at 3:42 PM
    #298
    I picked up some at ACE. I put a rear diff kit on my Frontier. Zip ties will be gone shortly. Thanks PomDad!
  29. Dec 18, 2022 at 12:24 PM
    #299
    catus
    catus New Member
    Centennial, CO
    '19 MGM DC Limited, stock for now
    Done. Great catch by @1794TX on the threaded tab above the diff!
  30. Jan 12, 2023 at 9:28 AM
    #300
    M_RED
    M_RED New Member
    Thanks all for the detailed instructions and part numbers.... I figure the sequoia version of this should be the same..
    Any recommendations for easy routing on the sequoia?
    This is added to the list of weekend things to work on...
