DIY: Radium Oil Catch Cans
Discussion in 'General Tundra Discussion' started by nk1794, Apr 9, 2018.
  1. Apr 15, 2018 at 8:58 PM
    #61
    nk1794
    nk1794 [OP] Always torque to spec
    San Jose, CA
    Are you adding a picture to show us?
  2. Apr 15, 2018 at 8:59 PM
    #62
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Ok. Now we need a month long test. See how much is in there after a month of driving.
    nk1794[QUOTED][OP] likes this.
  3. Apr 15, 2018 at 9:00 PM
    #63
    nk1794
    San Jose, CA
    I'll be checking monthly anyway.
    Baja Mike[QUOTED] likes this.
  4. Apr 15, 2018 at 9:02 PM
    #64
    nk1794
    San Jose, CA
    Yeah, a few drops I saw were black like that. It looked disgusting. :) I was making a video to show everyone and then I found out I was talking to myself the whole time. The freakin camera said SD Card error and I didnt notice it until I was done. Too late for take 2 because I've already clean the freakin can. Disappointing.
  5. Apr 15, 2018 at 9:15 PM
    #65
    LEKS
    LEKS Truck name “Sancha”
    Makaha
    2013 Rockwarrior Supercharged
    It definitely works and sexy as hell. LolD28EA5D1-8A63-4B3F-A957-94406BF98B23.jpg
    GAknight and nk1794[OP] like this.
  6. Apr 15, 2018 at 9:17 PM
    #66
    nk1794
    San Jose, CA
    Very nice! But I'm drooling over the SC.
    LEKS[QUOTED] likes this.
  7. Apr 25, 2018 at 7:48 PM
    #67
    nk1794
    San Jose, CA
  8. Apr 25, 2018 at 7:55 PM
    #68
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Thanks for the update. I'd be curious to see after a full oil change cycle (around 5K - 7K).
    On another note, are those the DEI wraps on your tubes?bhow you like them?!
  9. Apr 25, 2018 at 8:07 PM
    #69
    nk1794
    San Jose, CA
    I can do another update at 5K.
    Yes, those are DEI fire sleeves. They are well made but I don't like the way they look. I bought a 5/8" for the smaller 1/2" hose but I couldn't put it on, too tight. The one you see here are 1" on the 5/8" hoses. Maybe they are too big but I think a 3/4" would probably be too small. I think the sleeves should be a bit stretchable for ease of installation. If you know of any good technique let me know. I made a video on that but as I was editing it I felt bored so I gave up on it. LOL
  10. Apr 25, 2018 at 8:11 PM
    #70
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    I'm not sure on all the sizes they make. I've used them in the past for the spark plug wires, which were smaller. I also know them for thei header wrap. I'm sure they make basic sizes to fit multiple hose types.
    Did you check their website?
  11. Apr 25, 2018 at 8:11 PM
    #71
    15whtrd
    15whtrd Mr. Blonde
    No experience with those sleeves but you need to measure the outside diameter (OD)
    of your hoses before buying the wrap/sleeves.
    Most likely for the half-inch you need 3/4 and for the 5/8 you needed 7/8-1”.
  12. Apr 25, 2018 at 8:16 PM
    #72
    nk1794
    San Jose, CA
    Yes I did check their website. I measured the outside diameter of the hoses and they are slightly bigger than 3/4" so I went with 1". I will look for different type. Perhaps the one with velcro would work better, just wrap them.
    15whtrd likes this.
  13. May 11, 2018 at 4:49 PM
    #73
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    @LEKS, did you any issues with getting the PCV hose onto the intake manifold barb on your supercharger? I noticed during my install that the hose ID is slightly larger than the barb OD resulting in the hose sliding on/off the barb without friction. For now, I have 3 zip ties holding the hose onto the barb (ie. the stock hose clamp doesn't fit over the new hose). I may try and put a worm-drive hose clamp on instead of the zip ties but I still feel like having a smaller ID hose is the right solution. Below are photos of my install..
    LEKS[QUOTED] and nk1794[OP] like this.
  14. May 29, 2018 at 7:30 AM
    #74
    LEKS
    Makaha
    No issues with mine. It was just as snug as the factory hose.
  15. May 29, 2018 at 11:04 AM
    #75
    Spvrtan
    Kris
    San Diego, CA
    Damn, they must've changed something for the '14 kit then.
  16. Jun 11, 2018 at 3:49 AM
    #76
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    Bumping this to see if the dual set up is necessary. I want to order a can this week for my sc truck. I think either moroso or radium!
  17. Sep 21, 2018 at 8:56 AM
    #77
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    @nk1794 Do you have any updates on your catch can? Is it worth installing?
  18. Sep 21, 2018 at 4:44 PM
    #78
    nk1794
    San Jose, CA
    It's been about 3400 miles since the last time I checked. I'll check again and let you know in a couple of days. I think it's worth the install.
  19. Oct 20, 2018 at 3:10 PM
    #79
    nk1794
    San Jose, CA
    Sorry for the delay. At around 3600 miles. It collected about 70ml from the PCV can. The crankcase can was empty.
    Hbjeff, Flyinryank and 15whtrd like this.
  20. Apr 19, 2019 at 7:48 PM
    #80
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Thanks for the update and advising that the crankcase can didn’t catch anything.
  21. Sep 2, 2019 at 4:28 PM
    #81
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    Just bought one...PCV only tho...
  22. Oct 31, 2019 at 5:10 PM
    #82
    stuckinohio
    stuckinohio MGM Crue
    Mark
    oHIo
    2018 SR5 Crewmax
    In my experience Climate/seasons plays a huge factor in volume collected by catch can.
    Summer time, i noticed the collected fluid was black oil colored and uniform, no separation. ( dry season)
    Winter season doubled the volume, latte colored heavy stratification of fluid significant amount of water. (wet season)
    As a cold engine warms up with the Air injection system, the heat builds up from cylinder walls and spreads outward. The catch can is at ambient meaning it is colder than the air inside the block.
    Condensation occurs in the catch can and collects before being dumped back into the engine.
    BrandonL812 and HulkSmurf14 like this.
  23. Nov 11, 2019 at 12:54 PM
    #83
    TransNone13
    TransNone13 New Member
    I had the Radiums on a turbocharged car, and would recommend them for a forced injection car. The biggest reason for these is primarily to limit fouling of the back of the intake valves on gasoline direct injection engines, although with the add-on effect of improving emissions and a minuscule amount of power due to better combustion within the cylinder. As the stock Tundra is naturally aspirated and port injected, this isn't really an issue. Those cans are great but expensive, I wouldn't do this myself.
  24. Feb 5, 2020 at 5:28 PM
    #84
    AZTundra
    Paul
    Phoenix, AZ
    Did you end up replacing the hose or just stick with the zip ties or clamp? My Magnuson is going on this month and I have the radium dual catch can kit going on at the same time. Just wondering if I will run into this also.
  25. May 13, 2020 at 11:11 AM
    #85
    Sickining
    Sickining New Member
    Che
    San Francisco, CA
    2019 tundra CM Ltd
    What’s the difference with two vs one catch can. I’m thinking about buying one of these. Your input would help me. Thanks
  26. May 13, 2020 at 11:13 AM
    #86
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
  27. May 13, 2020 at 5:59 PM
    #87
    stuckinohio
    Mark
    oHIo
    2018 SR5 Crewmax
    One can is for the PCV the other can is for the crankcase. They are closed loop systems meaning they don’t vent. It will throw a CEL if vented. systems are separated so they don’t interfere with each other. IMO the PCV is really the main line to catch. The supercharged guys seem to indicate the crankcase vent can doesn’t collect much. I have actually been considering a vibrant catch can since it is large volume and priced fairly.
    AZTundra likes this.
  28. May 13, 2020 at 6:23 PM
    #88
    Sickining
    Che
    San Francisco, CA
    2019 tundra CM Ltd
    Thank you. I’ll probably just get the PCV can. Save some money.
  29. May 13, 2020 at 8:00 PM
    #89
    AZTundra
    Paul
    Phoenix, AZ
    That's correct from what I've seen so far. I installed both pvc and crankcase at the same time as the supercharger. I've only put on about 3k miles since then so not much time to accumulate anything. I checked the cans a couple times just to see what's in there and the crankcase side doesn't appear to get much of anything.
    GAknight likes this.
  30. May 14, 2020 at 1:34 PM
    #90
    Sickining
    Che
    San Francisco, CA
    2019 tundra CM Ltd
    From what I read. The 5.7 liter engine is a direct injection engine. Others say their not. If it is direct inject. We would definitely need this catch can, but if it’s not catch can isn’t necessary.
    AZTundra[QUOTED] likes this.
