DIY pop and lock for a fraction of the cost
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmillerdvm, Jul 18, 2018.
  1. Aug 6, 2021 at 3:03 PM
    #151
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Yep I'm on my 2nd metal bracket on mine. Need to find something stronger.
    Mater[QUOTED] likes this.
  2. Aug 6, 2021 at 3:16 PM
    #152
    biebs96
    PA
    I found the bracket shakes from the unlocking. I secured mine with a zip tie to the inside tailgate frame and it stopped the moving.
  3. Aug 6, 2021 at 3:18 PM
    #153
    biebs96
    PA
    did you ever buy a replacement? Message me I have an entire tailgate handle assembly
  4. Aug 6, 2021 at 6:27 PM
    #154
    parkerbows
    parkerbows New Member
    Jack
    2017 crew max sr5 trd off road
    Firestone air ride air bags
    actually I did. sucks to have an extra key but oh well. serves me right thinking I don't need glasses
  5. Aug 6, 2021 at 6:56 PM
    #155
    biebs96
    PA
    you should be able to reuse the original cylinder.
    and if not, at least you can leave the tailgate key in the console, since you now have a power locking one.
  6. Sep 20, 2021 at 10:44 AM
    #156
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Found at Lowe’s in the hardware aisle in the drawer bins.
    parkerbows and Ebeast like this.
  7. Sep 26, 2021 at 8:16 PM
    #157
    Alabear45
    Alabear45 New Member
    2016 Tundra TRD-Off Road
    Like the picture taken from this thread below of what is I assume is a 2017.. I am wondering what color are the correct wires for a 2016 Tundra double cab TRD Off Road ? I am trying to find the front passenger door lock wire pair color code for a tailgate remote release DIY install. YouTube vids for the the later years show a white w/silver and a red being used but my 2016 has no red wire. I think it might be one of the blue wires. I tried testing with a 12v light bulb on those pairs to se if a pulse would light it up. Also a voltmeter but no cigar. I am wondering if this is a fast square wave pulse with an opposite polarity for the other action that is too fast for the 12v incandescent taillight bulb I am using for the test.
    Anyway I sure could use a hand finding the schematic with wire colors for the lower blue connector in the front passenger door pillar.
  8. Sep 27, 2021 at 3:18 AM
    #158
    parkerbows
    Jack
    looks like my pic. I would assume it would be the wires in the same location as mine. bottom on either side
  9. Sep 27, 2021 at 9:13 AM
    #159
    Alabear45
    Thanks. that's what I was thinking...So pins 2 and 12 on that M1 blue conn. (found this in those wiring diagrams by searching for 'door lock' ) I was prewiring while waiting for the actuator so I was trying to test and wondering what the signal looks like. Must be polarity switching to send the solenoid the other way.
  10. Nov 16, 2021 at 5:44 PM
    #160
    campergf23
    campergf23 2021 TRD Sport Premium DC
    Quebec, Canada
    Hi all, bumping this thread back up. I recently installed my DIY remote tailgate lock thanks to everyone here.
    Toyota wanted $250CAD for the part, and the pop lock kit on Amazon was around the same. I ended up spending $40CAD in parts, and about an hour this evening putting it all together. I added an extension on the lock actuator mechanism, and a quick disconnect incase I ever need to remove the tailgate. I also used a rubber washer under the 10mm bolt holding the actuator. Its not too loud, but louder than the other door locks.
    This was on a 2021, the blue wire on the actuator went to the red in the truck, and the green/white goes to the white in the truck.
  11. Nov 18, 2021 at 10:09 AM
    #161
    wv00097
    wv00097 New Member
    Wes
    AZ > GA
    2011 SR5 TRD OR
    BDS 7 w/ Fox 2.5 OME Dakar leaf pack CB +2 shackles 18x9 Method 308 +18mm 37x12.5 Toyo AT3 TRD intake/exhaust Infinity Kappa w/ Pioneer HU
    Done. This is a six pack job. Hardest part was definitely getting the supplied bracket in the proper shape/angle to allow for smooth operation. My main issue was the actuator not extending the latch far enough forward (unlock position), not allowing the handle to pull the tailgate side latches properly. Lot of back and forth there. But I had four beers left at this point, so I was in good shape.
    Used the screw method in post 38.
    Confirmed the wiring in post 79 is proper for the 2011.
  12. Jan 25, 2023 at 12:58 PM
    #162
    SnrDisregardo
    Wade
    IL
    Bump to one of the best threads on here for the 2.5g.
  13. Jan 28, 2023 at 8:49 AM
    #163
    Redline870
    Redline870 New Member
    Ian
    Central NY
    2021 Super White TRD Pro
    2 Rolls of 16awg wire: $15
    1 Roll of split wire loom: $15
    1 pack 16-18awg posi taps: $10
    1 Chinesium actuator: $19
    Several hours of your time and money spent driving around and sourcing various hardware, then making/bending brackets.
    The juice doesn’t seem worth the squeeze when you can get a more reliable plug-n-play OEM Toyota option that comes with everything you need and only takes an hour or two to install for $143. https://www.sparksparts.com/oem-parts/toyota-tailgate-power-lock-standard-wheelbase-pk3b634js0
  14. Jan 28, 2023 at 8:52 AM
    #164
    SnrDisregardo
    Wade
    IL
    Amazon you don’t have to go anywhere
  15. Jan 28, 2023 at 9:15 AM
    #165
    parkerbows
    Jack
    Yeah thats what i did. only took me an hour and 1/2
  16. Feb 1, 2023 at 8:51 AM
    #166
    Sergicalmaneuver
    Sergicalmaneuver New Member
    So Cal
    2019 Platinum Crewmax
    Just found this. Great write up. It’s a must for me now
  17. Jul 8, 2023 at 11:40 AM
    #167
    mzim
    mzim New Member
    Max
    Waterloo, Iowa
    2015 Tundra DC Silver Sky
    275/65/20 Goodyear Wrangler Duratracs (May2024) Full ARH long tube system Bilstein 6112 Front +2.7" Bilstein 5160 Rear & Icon 1.5 AAL & +2.0 Shackles Fender Flares 1D6 White Knuckle sliders TRD Grille Morimoto LED Headlights with LED DRL/sequential amber switchback turns Rigid Fogs with Square TRD Bezel 4x LED bed lamps wired in OV Tune base load with iterations coming Tech12Volt remote with 2 way fobs and range extender antenna 4.88s with Auburn TRD skid plate Koyo radiator - FAILED REINSTALLED OEM Tyger tri-fold bed cover Bed mat from Boss 4x4 Front bumper spacers 0.5 inch by Boss 4x4 Pop n Lock tailgate wired in Black badging all around Classico Faux Leather Seat Covers Rough Country Floormats Halo 9 HU Underseat kicker sub JRT upgraded speakers
    Thanks for the writeup.
    I had a pop and lock unit go bad and needed to replace it.
    I used DEIs switch same as you.
    This wasnt too bad to install after studying the positions shown in your photos.
    The most difficult installation problem was starting that 10mm bolt under the hand bent bracket.
    But I eventually got it.
    Thank you for your post. Very helpful and save me time.
