DIY pop and lock for a fraction of the cost
Discussion in '2.5 Gen Tundras (2014-2021)' started by jaredmillerdvm, Jul 18, 2018.
  1. Aug 10, 2018 at 4:45 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Don't rub it in:p
  2. Aug 10, 2018 at 4:48 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    Psshhh that and the Bedliner were the only ‘upgrades’
    4x4_Angel[QUOTED] likes this.
  3. Aug 11, 2018 at 6:08 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    Didn’t get a chance to remove the cover on the tailgate today but below is the link to the video I made of the operationfrom the exterior. I’m back at work tomorrow and will try and take a second video showing the actual actuator working with the zip-tie
    https://youtu.be/RMg0JpG1fHA
    thatsscience, Trooper2, chugs and 2 others like this.
  4. Aug 11, 2018 at 8:49 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    TreeCat and Pudge like this.
  5. Aug 12, 2018 at 6:17 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
  6. Aug 12, 2018 at 12:19 PM
    Danimal86
    Daniel
    Sacramento, CA
    I had emailed the guy that did the design. He said he said it only lasted 6 months and he used ABS which is one of the stronger printing materials. Bummer.
    Pudge likes this.
  7. Aug 13, 2018 at 6:18 PM
    InfernoToyo
    InfernoToyo New Member
    Barty
    Inland Empire
    2018 Inferno Limited
    After a week it came off the pin so I just zip tied it today. This hold looks stronger so I’m sure it will hold for a while2516849E-BA59-4DCA-A170-7F6BE9CAB2DB.jpg
    jaredmillerdvm[OP] and TundraLuv like this.
  8. Aug 14, 2018 at 2:36 PM
    Pudge
    CT
    Did mine today and it works great. Parts were just under $20 from Amazon
    To fix the issue of the actuator coming off the lock pin I drilled a hole down the middle of the plastic pin and threaded in a bolt, I used some plastic washers on top to allow some play for it to move smoothly. worked out great and I have no fears that it will ever come off.
    This was the perfect amount of wire and loom for this project. Used a few connectors and wire taps I had from previous projects.
    Very happy with this, its quiet and works flawlessly. I used @BlueBottle pop and lock write up to find my wires cuz they changed colors in 2018. Blue wire silver dash and and white with silver dash.
    Thanks so much for doing this write up.
    TreeCat, aperezsh, Grnjetta6 and 5 others like this.
  9. Aug 14, 2018 at 3:09 PM
    Pudge
    CT
    Thanks Ron
    I tried a few things. I tried to remove the metal lever and put it over the new plastic lever on the actuator but that wouldn't work. If the plastic pin was slightly taller you could drill a hole and use a cotter pin but it's just not long enough.
    I figured I'd drill it out and it worked great. Found the skinniest bolt I could and when I was looking for that I saw those plastic washers. I love it and have no worries that it would pop off. That pin is maybe 3/8" so the hole needs to be precise and very small. Best solution I can think of.
  10. Aug 14, 2018 at 3:10 PM
    chugs
    chugs New Member
    Ciao
    Central Cali
    2007 Tundra Blue Streaker
    Nice, thanks for sharing! On the to do list.
    jaredmillerdvm[OP] and Pudge like this.
  11. Aug 19, 2018 at 9:15 AM
    TundraLuv
    TundraLuv New Member
    Kent
    IA
    2018 Midnight Black Metallic Limited Crewmax
    I've got all the components bought and delivered from Amazon. For a rookie DIY, how long would something like this take? Any additional suggestions after having installed it?
  12. Aug 19, 2018 at 10:20 AM
    InfernoToyo
    Barty
    Inland Empire
    Take your time...if you have all the components should take 2 hours for a beginner. Zip ties are your friends in this install
  13. Aug 19, 2018 at 10:23 AM
    Pudge
    CT
    PM sent
  14. Aug 19, 2018 at 11:45 AM
    jaredmillerdvm
    jaredmillerdvm [OP] Mods will never end!!
    Anderson, SC
    2018 MGM CM SR5 TRD Off Road 4x4
    Rough Country 3in leveling kit, SCS Ray 10s, 295/70/18 Toyo Open Country AT2 Extremes. TRD Shift Knob, Console Safe, Driver Side Grab Handle, WeatherTech Laser Measured Floor Liners, Katzkin Heated Leather Seats, Remote Start, TundraTex Frac Harness, Radio Vinyl Inlays, LED Interior Lightening. MGM Color Matched Hood Bulge and Surround, 18% Tinted Front Windows, 90% Ceramic Windshield Tint, 5% Banner, AntennaMast Stubby Antenna, Predator Step Bars, Skid Plate with Integrated Step, Line-X Spray in Bed Liner, Blacked Out Badges, Mirrors and Door Handles, Black Bedside Decals, Bak Revolver X2 Tonneau Cover, Swing Case Tool Boxes, DIY Tailgate Lock, Deck Rail System, Recon Smoked LED Tail Lights With LED Reverse Lights, Smoked Vinyl Wrapped Cargo Light, LED License Plate, Cargo, and 3rd Brake Lights, Dirty Deeds 8" BAMuffler, Black Powder Coated Front and Rear Bumpers, TRD Rear Sway Bar.
    Give yourself 2 hours to be safe. Easy install for a beginner like myself.
  15. Aug 19, 2018 at 4:26 PM
    jaredmillerdvm
    Anderson, SC
    For those of you having issues with the actuator coming off the pin, did you drill out the hole on the actuator prior to installation?
  16. Aug 19, 2018 at 4:49 PM
    Guess this is on my list also.
    NewImprovedRon and Pudge[QUOTED] like this.
  17. Aug 19, 2018 at 4:53 PM
    neoflex
    neoflex New Member
    Charlotte. NC
    I did using the bit suggested in your write up. I think the bend in the bracket is what plays a factor in it popping off as well.
    InfernoToyo likes this.
  18. Aug 19, 2018 at 11:22 PM
    InfernoToyo
    Barty
    Inland Empire
    I did drill the hole bigger for it to fit. I think it’s angle and lack of support with one bolt holding actuator causing it to move a bit. The zip tie solved the problem for me. It’s been working great ever since
    TreeCat likes this.
  19. Aug 20, 2018 at 2:13 AM
    #49
    jaredmillerdvm
    Anderson, SC
    Gotcha. Maybe I got lucky with my angle or just haven’t given it enough time to fall off. Either way mine is still hanging on for now!
  20. Aug 20, 2018 at 10:03 AM
    #50
    PMG
    PMG New Member
    I hear the pop and lock is loud.. how is it?
    Randy Morton likes this.
  21. Aug 20, 2018 at 10:10 AM
    #51
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    It's a pretty good thump, but you definitely know it worked. I'll go out after work, record mine, and post it here.
  22. Aug 20, 2018 at 10:17 AM
    #52
    Steve6
    Steve6 New Member
    Tucson
    Sub'd
  23. Aug 20, 2018 at 10:41 AM
    #53
    neoflex
    neoflex New Member
    Charlotte. NC
    See my video above. It’s not too bad. The Pop N Lock I had on my Tacoma was louder but it’s probably because it was a smaller gate. You definitely hear it but I wouldnt say it’s intrusive.
  24. Aug 21, 2018 at 6:36 AM
    #54
    jaredmillerdvm
    Anderson, SC
    It’s noticable but not too loud! I like hearing it that way I know it’s still working properly!
  25. Aug 21, 2018 at 6:43 AM
    #55
    TheTripleLindy
    TheTripleLindy New Member
    I agree. Gives you a peace of mind knowing it locked. I do not think it is any louder than the door locks when you are inside the truck.
  26. Aug 21, 2018 at 6:53 AM
    #56
    Clompy
    Clompy New Member
    Battle Lake. MN
    2018 Superwhite TRD Sport Double Cab
    @moonshineheadache and I each worked on ours this weekend. We ended up drilling a hole through the ABS pin and used 14ga copper wire for the retaining pin. Candy cane style! this thread was the inspiration, thanks folks!:benchpress:
  27. Aug 21, 2018 at 1:31 PM
    #57
    Clompy
    Clompy New Member
    Battle Lake. MN
    I've been working on a huge project which has included lots of travel and motel over-nights, and having $1000's of tools. Knowing you can look out the window and hit the lock button (just to be sure) gives me peace of mind.
  28. Aug 22, 2018 at 8:09 PM
    #58
    Sharpienads
    Sharpienads New Member
    2018 Tundra SR5 TRD O/R
    I'm gonna have to add this to my mods list. Thanks everyone for contributing!
    jaredmillerdvm[OP] likes this.
  29. Aug 22, 2018 at 8:13 PM
    #59
    Pudge
    CT
    Put one in my buddies truck last night. Took about an hour. Did the same thing with his, as far as drilling down through the pin and using a bolt to secure the arm in place.
  30. Aug 22, 2018 at 8:15 PM
    #60
    Guess I may order the parts tomorrow.
    :spending:
    NewImprovedRon and Pudge like this.
