DIY: Painted Tail pipes
Discussion in 'General Tundra Discussion' started by boardude, Feb 21, 2017.
  1. Feb 21, 2017 at 2:14 PM
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I've had a few PMs and requests to share how I painted my exhaust and tail pipes so thought I would create a DIY.
    Disclaimer: As any DIY, this thread is not telling you how to do anything rather I am just sharing how I did it myself. If you attempt the mod and f*ck up something I am not responsible for anything.
    As any paint job the most work is in the prep.
    Parts list:
    Beer
    Very High Temp (VHT) Primer - VHT available at Autozone
    VHT Header paint - VHT available at Autozone
    Lots of painters plastic
    Beer
    Tape / Painters Tape
    100, 150 and 200 grit sandpaper
    Cleaner/Degreaser
    Isopropyl alcohol
    More Beer
    First I jacked up the rear and removed the rear tires. Then I cleaned the exhaust and tail pipes with a cleaner/degreaser. Using 150 grit I sanded the pipes down which helped loosen the remaining dirt, then I wiped down again with degreaser and isopropyl alcohol.
    For the chrome tip I scuffed it with 100 grit then 150.
    Then I began the protection of the truck. Used painters plastic to wrap the truck and added newspaper between the pipes and underside of the truck.
    Taped off where I wanted the paint to stop (about halfway up when the tail pipe angles upward right before the spare tire).
    Now the Primer. I added 4 light coats with about 15 mins between applications. Then sanded with 200 after 30 mins. 2 - 3 more coats and then 1 hour to dry
    Lastly the black VHT. Followed same application as primer and sanded with 200 after a few coats. Then applied a few more light coats until I was happy.
  2. Feb 21, 2017 at 2:21 PM
    J4RR3N4
    J4RR3N4 New Member
    South east Texas
    14 Tundra
    3” lift on 35’s
    Great job! I just finished doing this myself.
  3. Feb 21, 2017 at 2:31 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    Thanks for the right up. Getting ready to do this myself. What's with covering whole truck, (Beers) and a lot of them. Hahaha
  4. Feb 21, 2017 at 2:35 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
  5. Feb 21, 2017 at 2:40 PM
    TheBeast The Beach
    looks good.
  6. Feb 21, 2017 at 3:11 PM
    3RsDad
    3RsDad New Member
    Roger
    17 Tundra TRD OR
    Very nice, I like the detail in explanation. I kind of thought (Tucson guy) would have gone,behind rear end dump! I'm kidding. With the great weather there it should last you a good amount of time.
    boardude[OP] likes this.
  7. Feb 21, 2017 at 3:23 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Only thing better than modding your truck is doing it with beers!! I covered most of the truck just to be safe and glad I did cause I found traces of overspray that had floated towards the front. Its a cheap extra step.
    Yzed608, 1UPPER and rons23[QUOTED] like this.
  8. Feb 21, 2017 at 3:26 PM
    rons23
    Ron
    Kill Devil Hills
    Safe than sorry, good work looks great
    boardude[QUOTED][OP] likes this.
  9. Feb 21, 2017 at 5:20 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    Great job and write up. I like it! Good job....
  10. Feb 21, 2017 at 5:55 PM
    Peck1631
    Peck1631 New Member
    Terry
    2017 crew max
    Trd dual exhaust, cold air intake
    I actually went the expensive route and have mine down getting it ceramic coated black. I prob should have just did what you did instead.
  11. May 16, 2017 at 3:42 PM
    R-C
    R-C http://101financial.com
    Ryan
    Las Vega$
    2017 TRD Pro
    Follow the leader @boardude . Lol
    First coat of black and so far it looks sick!
  12. May 16, 2017 at 9:00 PM
    Great job!...I too did this but my tips were black already ...all I did was spray rear of pipe to muffler blacked out with header paint
    R-C likes this.
  13. May 17, 2017 at 1:50 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Nice, that looks BA! I still love the black tails especially with the TRD stamp and they are holding up great.
    Jsena and R-C[QUOTED] like this.
  14. Sep 3, 2017 at 3:49 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    I wan to do this as well.. thinking of getting stuff today ¯\_(ツ)_/¯
  15. Sep 3, 2017 at 3:51 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Nice job in this write up... where did you place the jack at when you jacked it up?
  16. Sep 3, 2017 at 4:47 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Thanks bud! I don't think I jacked up the truck as my lift gave me enough clearance to get under there. With your lift you should be able to just walk under there and paint lol
    R-C and Jsena[QUOTED] like this.
  17. Sep 3, 2017 at 4:48 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    :rofl::rofl:So you just put jack stands under it ad took the tires off then
  18. Sep 3, 2017 at 4:53 PM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Ahaha I guess I had to have jacked it up then lol. It's been awhile since I did this, not even running those tails anymore lol. Yeah I just jacked at the pumpkin and set on jacks.
    Jsena[QUOTED] likes this.
  19. Sep 3, 2017 at 4:54 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Gracias my friend
  20. Sep 3, 2017 at 5:23 PM
    R-C
    Ryan
    Las Vega$
    2017 TRD Pro
  21. Sep 3, 2017 at 5:47 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Nice mod!
  22. Sep 3, 2017 at 8:13 PM
    csuviper
    Broomfield, CO
  23. Sep 3, 2017 at 9:22 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Did this yesterday. They are still hanging in my garage. I did add a couple coats of VHT clear coat to match my tube steps.20170903_221750.jpg 20170903_222111.jpg
    Echo5Golf, R-C, Jsena and 1 other person like this.
  24. Sep 4, 2017 at 5:53 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Final product? Pics?
  25. Sep 4, 2017 at 7:43 PM
    Areith762
    Areith762 Go Avs!!!
    They are still hanging in my garage. :( Maybe within the next week or so I will install them if I can find the time.
    csuviper and Jsena[QUOTED] like this.
  26. Sep 17, 2018 at 7:24 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    They still hanging? I'd love to see the finished product!
  27. Sep 17, 2018 at 7:50 PM
    silverhack
    silverhack New Member
    Sacramento, CA
    2018 CrewMax Inferno
  28. Sep 17, 2018 at 10:12 PM
    Areith762
    Areith762 Go Avs!!!
    I just went through all my pics and sadly I have failed to take any pics of them after I installed them. It has been about a year now and although they are dirty, they have held up well.
    This was right after I installed them. You can see the drivers side tip... lol
  29. Sep 18, 2018 at 3:37 PM
    Runnerstrom28
    Runnerstrom28 Hail Hydra
    Derek
    14 limited blue ribbon tundra crewmax
    I wish there was an easy button and Bam! This mod would be done lol
  30. Sep 18, 2018 at 9:04 PM
    Silv333
    Silv333 Patriot
    NJ-NC-MD-NC
    Haha, well thanks for posting some pics. Did you just undo them at the U bolt and they slide off? I looked underneath today, doesn’t look like much holding them on. I’d rather remove them and paint them versus mask everything underneath. Thoughts?
    Runnerstrom28 likes this.
