DIY oil change 5.7
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pudge, Jun 2, 2017.
  1. Jun 2, 2017 at 1:00 PM
    Pudge
    Pudge [OP] Super Secret Elite Member #7
    CT
    2015 Blue Ribbon Platinum
    I'm planning on changing my oil tonight or this weekend. Haven't done it before on this truck. I got a new oem filter with a few washers thrown in by the dealer. There's a little plastic "tool" in there to to drain the filter cartridge too. I picked up 2 jugs of 0w-20 synthetic oil and a wrench for filter. Any tips or tricks here or is it pretty straight forward?
    SouthBoundSteve likes this.
  2. Jun 2, 2017 at 1:03 PM
    xj2202009
    xj2202009 New Member
    x
    Lutz, Fl
    2017 tundra sr double cab v8 5.7L black 4x2
    looking to replace factory Radio with a pioneer avix588bhs
    1.beer..2.beer..3..a couple of curse words..4..beer..what were you doing..5.beer..the usual..
  3. Jun 2, 2017 at 1:10 PM
  4. Jun 2, 2017 at 1:14 PM
    Pudge
    CT
  5. Jun 2, 2017 at 1:15 PM
    I forgot someone posted a link to the other valve for filter drain
    Jsena likes this.
  6. Jun 2, 2017 at 2:37 PM
    Pudge
    CT
    Before I get into this. Is this the correct filter cartridge wrench? 64mm?
    Bear likes this.
  7. Jun 2, 2017 at 2:39 PM
    millerstone and GNTundra like this.
  8. Jun 2, 2017 at 2:41 PM
    Also... someone on here said to change out the plastic filter cartridge to the metal one it sells on Amazon
  9. Jun 2, 2017 at 2:43 PM
  10. Jun 2, 2017 at 2:45 PM
    They make a metal one stead of the plastic one
  11. Jun 2, 2017 at 3:21 PM
    Pudge
    CT
    That's 64mm? Can't see in pic
  12. Jun 2, 2017 at 3:45 PM
    Hold on
  13. Jun 2, 2017 at 3:56 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    How much oil does our truck hold? And is it really worth changing it? It's $80 at Toyota, how much $$ does that save you...
  14. Jun 2, 2017 at 4:20 PM
    Pudge
    CT
    If you can it done with full synthetic, reliably then I'd go for it. I spent $55 on 2 5qt jugs of Mobil 1 oil and an oem filter.
    Jsena[QUOTED] likes this.
  15. Jun 2, 2017 at 4:21 PM
    tye
    tye New Member
    tye
    2016 TRD Pro DC
    Diamondback cover, flowmaster exhaust, n-fab sliders
    It's more about making sure the job is done right than saving money. The most inept tech is the one who does the oil changes.
  16. Jun 2, 2017 at 4:26 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Lmao hahaha, I trust Toyota for sure when it comes to that stuff.. never had an issue with them the last 6 years.$25 is not that much to do it myself..! Gotta keep employment up for these guys :D
    USCG2005, Luckydog and PermaFrostTRD like this.
  17. Jun 2, 2017 at 4:36 PM
    wspearce3
    wspearce3 New Member
    Will
    2023 Platty
    I just did it on mine and it's kinda a pain the first time.
    First off, one of my bolts was missing on my skid plate. The plug on my oil drain pan was obviously tightened with an impact. The filter drain plug wouldn't come out without the filter coming with it. To top it off, I busted the shit out of my finger and am currently losing my nail.
    All changes were done at the dealership prior to this one because I switched to amsoil. Mine took 8.0 quarts. I plan on changing the filter in six months and the oil again in one year.
  18. Jun 2, 2017 at 4:58 PM
    Pudge[QUOTED][OP] likes this.
  19. Jun 2, 2017 at 4:59 PM
    millerstone
    millerstone New Member
    2017 TRD Pro DC Cement
    I think I spent about $50 on oil (Mobil 1 synthetic, Walmart has 5 quart jugs cheap. My truck took about 8 quarts.), $25 on a Fumoto, and $6 on a filter. Now all of my upcoming oil changes will be easier and I know it was done right the first time. Plus, it's kinda fun to work on your truck.
    USCG2005, Meltz, N3skridge and 3 others like this.
  20. Jun 2, 2017 at 4:59 PM
    wspearce3
    Will
    2023 Platty
    That's the exact one I used for my truck. It'll work just fine.
    Jsena likes this.
  21. Jun 2, 2017 at 5:04 PM
    Pudge
    CT
  22. Jun 2, 2017 at 5:08 PM
    Motor71 likes this.
  23. Jun 2, 2017 at 5:23 PM
    Here's the other tool to use instead of plastic tool that comes with filter Screenshot_20170602-192126.jpg
  24. Jun 3, 2017 at 4:00 AM
    R0CKETMAN
    R0CKETMAN IG: @rocketmanmtb
    NGAMTNS
    '17 TUNDRA TRD PRO CEMENT ‘15 TUNDRA SR-5 WHITE
    fwiw
    My dealer has an express oil change. I stay in truck. I provide mobile 1 from Wally. Stealer provides filter.
    $18 per oil change
  25. Jun 3, 2017 at 6:05 AM
    millerstone
    That is epic. Wish I had that option.
  26. Jun 3, 2017 at 8:18 AM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    I'm thinking about changing my own as well, does the pro skid plate need to be removed?
  27. Jun 3, 2017 at 4:13 PM
    millerstone
    The pro skid has an access panel to pull the filter
    bigoltater[QUOTED] and Pudge[OP] like this.
  28. Jun 3, 2017 at 4:36 PM
    robie56
    robie56 New Member
    Steven
    New Hampshire
    2011 white cm rock warrior
    mbrp exhaust, afe dropin filter, stubby antenna, Readylift leveling kit, ICI magnum RT sidesteps, weather techs front & rear
    Pudge 1 trick I found is to take the plastic tool provided for draining oil filter,and place it in the top of a plastic 2 quart soda bottle.Then push up into place and oil drains into soda bottle! No fuss no mess! My truck takes 8 quarts of oil with a new filter. Hope this helps you out!
    Pudge[OP] likes this.
  29. Jun 6, 2017 at 3:52 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    I did the math minds well sit down at the stealership and drool over the other tundras and let them do it comes out almost the same price plus if something happens Toyota's problem that's how I see it
    138thBatista and Jsena[QUOTED] like this.
  30. Jun 6, 2017 at 3:55 PM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Kinda the same for me.. and I don't have to worry about getting rid of the oil or the mess or anything.. also I can't change the oil anyways.. maybe if I was good at it and quick I might have a different perspective but w/3 to each their own right
