DIY: Move the Crewmax rear window switch
Discussion in 'General Tundra Discussion' started by BrakeDust, May 30, 2021.
  1. May 30, 2021 at 8:07 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Yes there are endless threads on this. But they lack one thing: Pictures. So here's how to do it yourself, 100%. Mine is a 2021 Crewmax SR5. YMMV but the procedure is similar for all years.
    Do you like to cheat? There's a harness available. (I wanted the 44" version and it's $40 - so I didn't get it)
    https://www.12volt.solutions/produc...cation-harness?rq=yr_2015~mk_toyota~md_tundra
    OR
    https://accessorides.com/products/r...ra-2010-2017-plug-play?variant=32416113524782
    Dash disassembly inspired by this classic video. You only need the first 5min:
    https://www.youtube.com/watch?v=xu1C1AapaAI
    I didn't use these, but if I had to do it again I would:
    https://www.homedepot.com/p/Ideal-Insulation-Displacement-Wire-Connectors-25-Pack-85-925/100192058
    Situation. Window switch location is suboptimal, to the lower left of the driver.
    Remove the Driver's floor trim panel, it pops right up from each end
    Remove the Driver's kick panel, there's a plastic nut you can undo by hand, near the dead pedal. Then pull the panel toward you about a half inch, then out.
    Remove the two black 10mm bolts, one one the left, another on the right
    Now the bottom dash panel can be dropped, just pull from a corner and work your way around
    Tow/Haul panel removal is easy, just pull.
    Remove the plug from the Window Switch, small tab
    Wires exposed. (This is where you say *crap* maybe I should have spent that $40)
    Note: They are very thin, like telephone wire, likely 22 gauge
    The gel-filled telephone connectors would work well to splice these
    My home made 'harness' in place.
    I cut off the OEM plug and soldered the wires on my bench.
    The plugs don't fit in the panel cutouts.
    One must make new openings with a dremel or knife. It is very easy.
    Panel & plugs after modding
    Spliced window wires
    This is where I would use the telephone connectors next time or Posi-Tap butt connectors from Amazon. I used 20ga single strand wire from ACE, they didn't have either of those.
    Final Product. Move the tow/haul out of the way.
    2mchfun, bulldog93, coldcanuk and 8 others like this.
  2. May 30, 2021 at 8:28 AM
    AT x AT
    AT x AT Trooper Transport
    Jimmy
    State 48 - East Basin of Arizona
    2021 Wind Chill Pearl Platinum
    Mods, what mods?
    Thanks for putting this together. I have been meaning to do this, but a little under the weather to actually work on ATxAT.
  3. May 30, 2021 at 8:47 AM
    ZiaTundra
    ZiaTundra New Member
    Nice write-up! Looks like my 2008 already has it in that spot.
  4. May 30, 2021 at 8:56 AM
    gladecreekwy
    gladecreekwy Wyoming
    J
    Jackson Wyoming
    2014 trd silver tundra
    6" lift, bumper and winch.
  5. May 30, 2021 at 9:01 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Because the current location sucks.
    If I did mine, I'd move it to just below the center arm console, where the dead space is, so the passenger could lower it.
    Medinasmoke likes this.
  6. May 30, 2021 at 9:03 AM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    Just for an FYI. If you order the 8” harness from Accessorides in the notes section you can specify any length you want.
    They made me a 20” and did not charge anymore than the 15.99 and shipping.
    Very good customer service/response from them.
    Think mine was like $22 shipped. Well worth it not to have to cut or splice.
    Because on the left side it is in a craptastic location.
    bulldog93 and BravoDeltaRomeo like this.
  7. May 30, 2021 at 1:32 PM
    BrakeDust
    Hill Country, TX
    I use that back window daily, it's nice to have the switch right by my hand.
    Good to know. Would have made this into a half-hour job.
  8. May 30, 2021 at 9:34 PM
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Was worth the $40 for me to move it down here...
    Otherwise the process is the same, just a different final location.
    saybng, bulldog93, MaxMB and 2 others like this.
  9. May 30, 2021 at 10:00 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    I miss my roll down rear widow of my 2005 DC.
    My 2014 DC has a manual slider.
    I have not opened it in 6 years..
    If I had that rear window switch in my dash, I'd pay $100 minimum to move it to the center console.
    That is where it belongs in the first place...:thumbsup:
    bulldog93 likes this.
  10. May 31, 2021 at 4:31 AM
    BrakeDust
    Hill Country, TX
    Great idea. I think you just volunteered to find out! Seems like one could tap off all the wires and connect the 2nd switch in parallel. The window wouldn't "know" which switch is driving the signals.
  11. May 31, 2021 at 4:47 AM
    GELCW
    GELCW New Member
    Erik
    Northern Virginia
    2018 Gray Tundra Platinum
    How do you make it work for platinum models that do not have that credit card storage in the center console?
  12. May 31, 2021 at 6:04 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Nice write up! Great pictures. :thumbsup:
  13. May 31, 2021 at 6:21 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Just put in an order for a 8' and added the request in hopes of a 20' but did not see my comments listed on the checkout section so had to follow up but with an email. Not really hopeful as these "nice" things never happen to my orders, but the other part that sucked was the site would not let use the discount code either... nevertheless i don't expect great customer support and would just have to eat the cost, it ran me about $25 shipped for the 8".
  14. May 31, 2021 at 6:31 AM
    nhw544
    nhw544 Food fight!
    RVA
    2019 Black Tundra 4x4 Sport
    I’m assuming I would just need the 8” one if I move the switch over to the right of the steering column?
  15. May 31, 2021 at 6:32 AM
    Norfolk757
    Tom
    Norfolk, VA
    Im not sure it will be long enough, that is why i asked for at least a 20'. They are all sold out of the 44'
    nhw544[QUOTED] likes this.
  16. May 31, 2021 at 6:36 AM
    nhw544
    nhw544 Food fight!
    RVA
    Ok thanks!
  17. Jun 1, 2021 at 6:15 AM
    Black
    Not sure if you mean you did not see the notes section when ordering but here is a screenshot of the section.
    If you mean once you got an invoice email that the special order length was not anywhere in the email, my invoice email did not mention anything about the length change but it arrived the 20” as I requested
  18. Jun 1, 2021 at 6:19 AM
    Black
    8” is too short. Not sure what the 8” length is for.
    They used to have about 5 or 6 length options to choose from in the drop down.
    But now they are down to 8” and 44” which is weird because 8” won’t get you to the other side of the steering wheel and the 44” is a bit short for folks using the new 3D printed switch holder in the center console. Some have made it work but it is pretty close with no extra.
    Tebuu and nhw544[QUOTED] like this.
  19. Jun 7, 2021 at 7:54 AM
    Norfolk757
    Tom
    Norfolk, VA
    Never got the longer cable even as I requested it when purchased, so I would not recommend buying from this vendor at all. Also the 8” cable is absolutely useless unless you are going to cut it and extend it on your own not to mention never got the “holiday” discount. Overall not happy with my business with this vendor and I would not recommend them to anyone in this forum A37C1E81-20C2-450E-AF85-0848C07486B3.jpgECFBEFBF-9CF0-4C6B-A475-D7A3C9B726FA.jpg
  20. Jun 7, 2021 at 8:00 AM
    BlueRibbon4x4
    Geno
    Damn, that’s a bummer. If you want, you can add your experience to this thread.
    https://www.tundras.com/threads/the-do-not-buy-thread.82812/
    Norfolk757[QUOTED] likes this.
  21. Jun 7, 2021 at 10:33 AM
    Black
    That is a bummer. I had the complete opposite experience with them. They were awesome. What did they say about the mix up?
  22. Jun 7, 2021 at 10:43 AM
    OnespeedTRD
    Don
    San Diego
    That’s strange that you got this kind of service from them. Plenty of folks here when used them with great results.
    Hopefully they get you sorted out and make it right for you.
  23. Jun 7, 2021 at 6:57 PM
    sportrider
    sportrider New Member
    Stephen
    2017 White Crewmax Limited
    I just came across this thread today, and like others, I have to ask why? I understand having it closer to your hand, but I can honestly control mine without even looking. The same way I have to reach over and put any other window up or down. I also use the moonroof on a daily basis but never thought to move those switches elsewhere. Please don't jump all over me here, just trying to understand why some of you go to the trouble to relocate this switch other than having it next to your hand. I personally wouldn't want it where other people could play with it, especially kids. JMO
  24. Jun 7, 2021 at 9:02 PM
    OnespeedTRD
    Don
    San Diego
    Because window switches don't belong on the left front knee panel on any vehicle, for any reason, ever?
    Its just more convenient in this spot, and the passenger can reach it. I don't have kids anymore, so not worried about that, and even if I did, its just a window, not a missile launcher.
  25. Jun 8, 2021 at 4:56 AM
    sportrider
    Stephen
    I guess we could all go round and round on this. Bottom line is, we do whatever we like to our trucks to make them our own. I get that. Maybe since I'm left handed it doesn't seem to bother me as much either. I dunno. Thanks for the input Don. And I appreciate the missile launcher idea, haha. Wouldnt that be cool to have at times!!
    BlancaLaGordita likes this.
  26. Jun 8, 2021 at 5:22 AM
    Norfolk757
    Tom
    Norfolk, VA
    Unfortunately, their customer service is non-existent. I don't feel like being a dick for $24 dollars, just learned my lesson not to do business with that outfit again.
  27. Jun 8, 2021 at 9:15 AM
    Black
    That is disappointing. They were Johnny on the Spot for me. All emails answered in under 30 minutes.
    Custom harness made a shipped the day I ordered and in the mail box 2 days later.
  28. Jun 8, 2021 at 3:12 PM
    nhw544
    nhw544 Food fight!
    RVA
    This may be a dumb question, so apologies in advance if I missed it earlier in the thread. But where is the connection to the rear window module? I’m curious before I commit to this project.
    Norfolk757 likes this.
  29. Jun 8, 2021 at 6:47 PM
    OnespeedTRD
    Don
    San Diego
    The connection is just behind the switch. All you're doing is pulling the switch out, plugging an in-line harness into the original harness, and then plugging the switch back into the new harness. All the ends are OE type fittings, so its plug and play. You're just making the wiring harness longer so you can move the switch further away.
  30. Jun 9, 2021 at 5:11 AM
    nhw544
    nhw544 Food fight!
    RVA
    Ok thanks!
